Equipment fails after hub is used
I have a USB204N-F 4-port USB Hub .. over time i have plugged all my usb equipment into it at on point or another. the problem is now my computer will not reconize the equipment unless the equipment is plugged in to the Hub!!!
''USB DEVICE NOT RECONIZED!!'' device has malfunctiond and windows does not reconize it for help click the box.
help all i want to do is plug my stuuf in directly again.
  • smko Jan 24, 2009
    After much searching and reading i found my solution!!!!
    if your usb ports dont want to work what i did was:
    1. shut down computer
    2. unplug computer from wall
    3. let sit for minimum 5 minutes
    4. plug computer back in
    5. turn on computer
    6. let it completly start so that it is just idling
    7. plug in usb device and it should work.
    President:
  • 8,637 Answers
If you need additional USB ports, the best way to go is to get a USB card that fits into the computer. That way it comes with a CD software program and can be updated. They are now USB 2 configured and work great. I have had to remove a number of USB hubs to fix other computers that have had the same problem.
Hope this info is of some help. Bud
Posted on Jan 24, 2009
Toshiba Canvio 2TB USB 3.0... wireless mouse problem
Get a USB 3.0 Port hub at walmart or any place that sells electronics. They normally have 4 usb ports on the hub and that should allow you to have both the mouse and the hardrive running since the hub would be plugged into your usb 3.0 port on your computer.
Feb 25, 2014 | Computers & Internet
Usb port hub does not recognize external hard drive
w7
First, please disconnect all USB devices and then perform the following steps:
Click "Start" button, type "devmgmt.msc" (without quotation marks) in the "Search" bar and press "Enter". Click "Continue" if necessary.
In Device Manager, double click to expand "Universal Serial Bus controllers", right click on the Host Controller, click "Uninstall" and click "OK".
Repeat the step 2 to uninstall all items under "Universal Serial Bus controllers".
Then, restart your computer and Windows 7 will reinstall all USB controllers automatically.
for xp
click start control panel administrative tools computer management device manager scroll down universal serial bus controllers you could see a yellow question / exclamation mark? ! or a red X
you will need to update/reinstall drivers
right click to reinstall drivers
if you can see your usb but its not working
ports(com&lpt)right click update driver
sometimes the wires inside the cable will be damaged due to bending or stretching or placing heavy equipment upon the cable
just replace the cable of the hard disk, when you plugged the external disk drive you got that windows could recognize the USB device change the cable everything should work fine again,
if you can see your usb drive but its not working
ports (com&lpt) right click update driver if this fails to fix the problem
check the USB leads that attach to the motherboard usually red white green black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems to a computer and its parts
Downloads to Recover Your Files and Save Your Bacon and 10 Best Free Hard Drive Utilities.
Some addition links found on Google
http://www.datarecoveryreview.net/
http://www.cleverfiles.com/
http://www.easeus.com/resource/hard-disk-data-recovery.htm
hope this helps
Jul 05, 2012 | Rocketfish 4Port HiSpeed USB Hub
I have a model m01517 5 port usb hub. It has 2 usb cables to the computer, do I use the blue or black connector? I can only get one port to recognize a device plugged in the other four seem to be dead,...
Not sure I understand this hub either. Looks like only one port is a USB 2.0 port, but here is a snippet from the manual......
This iConcepts USB Hub provides the electronic interface between USB devices and the host, It allows up to five USB devices or Hubs to connect an upstream USB Hub or Host port.
Features
• One USB 2.0 port
• 4 Port USB 1.1 and support high speed (480 mbps) and 4 port full speed (12 mbps) operations.
• The USB 2.0 port can operate both USB 2.0 & 1.1 Devices
• USB 2.0 port supports self powered mode and bus - powered mode, indicated by a powered LED .
• Over current detection and protection
Manual is provided here: http://www.sakar.com/p-1124.aspx?categoryid=182
Sep 09, 2010 | Sakar (M01517) 5-Port USB Hub
My Mouse Fails To Work On One Of the USB Ports
I have had several ports go bad for no apparent reason. its happened on internal and external devices.
Frankly, unless this is a thing of principal for you I would just go and order a new hub from Amazon for a few bucks and be done with it. Even if its under warranty you would probably be required to ship the dead one back so that would cost more than getting a new one.
Just my 2 cents
Apr 01, 2017 | Micro Innovations (USB204N) 4-Port
Targus Travel USB 2.0 4-port Hub
sometimes usb hard drives will not work through a usb hub.
if the drive works connected to the laptop but not the hub then that's how you'll have to use it.
it's also possible the laptop cannot power both the hub AND the drive, in whaich case you'll need a powered hub (one you plug in to the mains).
Sep 21, 2009 | Targus PAUH217U 4-Port USB Hub
4 port USB hub not working...
Try connecting the hub to another USB port. You may even connect this same device to another computer and check if that works. This will help isolate the issue better.
Jun 23, 2009 | Dynex 4-Port USB 2.0 Hub
My dynex usb hub is not working
You need to unplug the power adapter from the wall, and disconnect the usb cord from the PC/laptop for at least 30 seconds. Then plug everything back in. Apparently this model suffers from static electricity from time to time. I have this hub also and it works every time.
Apr 06, 2009 | Dynex 4-Port USB 2.0 Hub
USB hub
Do you have Windows XP and at least Service pack 2 installed.
Service Pack 2 comes bundled with the neccessary drivers for USB 2.0
In device manager under the USB heading you must have:
PCI to USB Enhanced Host Controller
In the list.
Jul 12, 2008 | Micro Innovations (USB204N) 4-Port
When I plug a device into the hub, I can't locate it.
for usb hubs some of the port could fail any time so test all the ports to identify which one is working
Mar 02, 2008 | GE JASCO (HO97878) 4-Port USB Hub
USB204N Micro
im using vista too, when i had 2 hubs only one was working. but i did have the hub plugged into the other hub once i linked it directly to the pc's usb port, it worked... the problem was i wanted that port for an external hard drive, but now i just plugged that into one of the hubs!! problem fixed
Oct 25, 2007 | Micro Innovations (USB204N) 4-Port
Computers & Internet Logo
83 people viewed this question
David Payne
David Payne
