Question about Saws
I was using my Delta TS220LS table saw and it quit running.
The motor does not even hum. The motor was not hot. I was only using it for about 1 minute before it quit. The blade does turn by hand with only slight resistance.
The schematic for this saw which you can see here:
shows a circuit breaker associated with the motor. I do not know exactly where it is, you must find it and re-set it, problem solved.
Posted on Feb 18, 2009
Try taking out your brushes and clean them, also clean the brush holders. (make sure the brushes slide all the way in and out freely and that they are not worn down past the ware mark) Also make sure you put the brushes back in the same way or the electric break may not work properly because of the ware pattern it makes.
While you have the brushes out look into the brush holders and look at the armature. The copper blocks are called the commutator if it does not look smooth you might want to take it somewhere and have it tested.
Also make sure your are getting power through your switch to the motor.
More than likely it is your brushes or brush holders.
Posted on Jan 08, 2009
I own a Delta Shopsmart table saw model TS220LS and I have not used it for years and it still work but I don't know how to get the saw to rise above the table level. thanks.
On pos 75 page A turn the depth adjustment clockwise otherwise if its blocked by wood or other trash control the mechanic and clean it dry .
  • Delta TS220LS TYPE 1 Bench Table Saw Parts
Sep 17, 2016 | Delta Saws
If the blade turns freely by hand,check the motor brushes.Most high quality power tools have easily replacable brushes,and they usually only cost a few bucks.
Sep 15, 2012 | Delta Saws
My table saw will not start. the power source is good.
If the motor is using a single phase supply there will be a capacitor which could have reduced in value- open.
If so try and use a capacitor in parallel to see if the motor works-- in this case the motor might hum and get heated up.
Mar 11, 2011 | Delta 36 982 10 Inch Left Tilt 1 1/2...
I have a 10" Delta Table saw Model 34-670. I was
Check nameplate on motor for amp draw, and then check that against your breaker and wire size.
If table saw worked on the breakers before and suddenly stopped working, then see if you can lubricate motor bearings >> look for oil cap on each end of motor and use 3-in-1 oil.
Clean the saw and make sure there's nothing rubbing against drive belt and that saw blade rolls easily when saw is turned off.
Mar 02, 2011 | Delta Saws
I have a delta contractors table saw that wont start. It has a Marathon Electric Motor 62-044 that hangs off the back. It has capacitors rather than brushes. When you turn on the swithch it does nothing. I...
Most likely to quit suddenly is the switch.
My table saw switch broke recently, and at first I thought it was the motor.
Over the years I remember seeing table saws fitted with a handy box and ordinary light switch to replace the table saw switch.
Check for power at motor: Sometimes the wire connection from switch has access box on the motor where you can get in and check for power.
Feb 01, 2011 | Delta 36-979 10" Left-Tilt Contractor's...
I have a delta 36-600 table saw that the clutch or drive has quit working . the motor was rebuilt about a year ago now the drive slips is there a simple or easy fix or adjustment to the clutch for this...
If you have a motor with the no.1313314 and the motor runs ,but the blade spindel does not turn try removing the backcover plate . With this removed you might find that the toothed gear belt has broken. If this ,in fact, is the problem the belt is a Bando syncro,link 100xl.
Hope this rectifies your problem as I am waiting for a new belt myself.
Oct 10, 2010 | Delta 10"Hybrid Tablesaw with 30"Unifence
My table saw stops after a minute or two i replaces the capacitor and still does the same the breaker pops out
This means it's drawing high amp. Could be just packed with saw dust, getting hot. The breaker is probably thermal. Clean it up good. If it still trips, check for name plate current on motor and test.
Jun 22, 2009 | Delta 36-716B 10" 1-3/4 HP 120/240V...
Delta Table Saw stopped running
I have a table saw that the cord from the motor plugs into the the back of the on/off switch. I yours is configured like that, unplug the motor cord from the back of the switch and plug it in to the wall and see if the motor will run. If so replace the switch.
Jun 21, 2009 | Delta 10"Hybrid Tablesaw with 30"Unifence
Motor stops after about 5 minutes of running
What are you cutting? What type of blade, power supply, etc are you using. It sounds like the thermal overload is cutting out.
Try looking for a little (red) button on the motor itself that pops out slightly when the motor cuts off.(due to overheating). If you push that in, will the saw start running again?
Mar 23, 2009 | Delta Saws
I was using my Delta TS220LS table saw and it stopped running.
Confirm there is power to the plug that you are using to power the saw.
Reply back your finding and I can help you further.
Jan 07, 2009 | Saws
Saws Logo
199 people viewed this question
Top Saws Experts
Tom Chichester
ray gallant
Are you a Saw Expert? Answer questions, earn points and help others
