Question about Cingular Wireless 8125 Smartphone
Will not power up on AC or usb adapter
Cingular 8125 will not run on AC or usb adapter. Works ok with charged battery. Have taken the phone apart and get power at the charging port.
What else can I check?
  • josh_wingler Jan 14, 2009
    i have the same problem. but mine will not power on with a battery either.
I had the same problem with my 8125, until I saw the posting by: randaleb2002 , I didn't want to cut my power cord but I did have an extra USB cable, I cut the cable in half and striped the red and the black wires, the red is the positive and the black is the ground (negative). I held these to the red and black terminals on the battery for aprox. 3 min. and sure enough when I put the voltage tester on the terminals it read aprox. 3.1Volts and the device powered on I now have the phone charging, and it seems to work great, I also had a battery for the 8125 that I thought was fried I did the process on it however and it to works great,
so thanks to who ever
randaleb2002 is.
Posted on Jan 27, 2009
  • 4 Answers
If you have an extra charger for the phone remove the end take the exposed copper wires hold them to the positive and negative post's on the battery for about 3 minutes and then plug into the normal charger.
I know this works I did it to my phone last night.
Posted on Jan 21, 2009
HiSense Sero 7 tablet. Why no charge, no power?
About 1,620 results (0.80 seconds) Search Results
    HQRP USB to micro USB Cable / USB Charging Cable for ...
    www.amazon.com > ... > USB Cables
    Amazon.com, Inc.
    Rating: 2.9 - ‎22 reviews
    1A AC Wall Power Charger Adapter Cord for Hisense Sero 7 LT Lite E270BSA .... If you try to use the tablet while it is being charged, no charging will take place.
    HQRP AC Adapter / Battery Charger / micro USB Charging ...
    Amazon.com, Inc.
    Rating: 3.7 - ‎6 reviews
    HQRP USB to micro USB Cable / USB Charging Cable for Hisense Sero 7 LT E270BSA / Hisense... ... HQRP Micro-USB AC Adapter rapidly charges your Cell Phone / Tablet PC ... This one does not. ... Yes No Sending feedback. ... $3.91. 1A ACWall Power Charger Adapter Cord for Hisense Sero 7 LT Lite E270BSA Tablet.
    HQRP AC Adapter Dual microUSB Charging Cable for ...
    www.amazon.com/HQRP-Adapter-microUSB-Chargin...
    Amazon.com, Inc.HQRP AC Adapter Dual microUSB Charging Cable for Hisense Sero 7 LT E270BSA... Do not wait until charging one of your devices to charge the second.
Feb 09, 2016 | Tablets & eReaders
Dell inspiron 1300 does not see the battery
remove battery check if laptop works fine with ac adapter, if not then download the latest bios version first if fails then replace ac adapter. If laptop works fine with ac adapter. but cannot work with battery alone, download the latest bios then charge the battery for 6 hrs. if still batt not charging then replace batt. but as you mentioned you already replaced the batt and your still getting the same issue. replace motherboard.
Sep 24, 2009 | Dell Inspiron 1300 Notebook
My phone only works when it's plugged into the charger
New batteries are shipped partially charged. Before you start using your device, it is recommended that you charge the battery. Some batteries perform best after several full charge/discharge cycles. You can charge the battery in two ways: • Charging the device’s battery by connecting the power adapter. • Connecting your device to a PC via the provided Mini USB cable. Note: Only the AC adapter and USB cable provided with your device should be used to charge the device. Charging is indicated by a solid amber light on the left LED indicator. As the battery is being charged while the device’s power is on, a charging icon will be shown on the title bar of the Today screen. After the battery has been fully charged, the left LED becomes green and a full battery icon appears on the Today screen’s title bar. Warning! Do not remove the battery from the device while you are charging it using the AC or car adapter. As a safety precaution, the battery stops charging when it overheats. When the low-battery warning appears, do the following: • Immediately save your current data. • Synchronize with your PC or connect the power adapter to charge the battery. • Turn off your device.
Hope this helps, let me know if I can help you with anything else.
JimmyC
Jul 14, 2009 | UTStarcom Blitz Cell Phone
Cingular 8125, dead as a doornail.
u can take a usb cable that not being used by any thing . save the end that plugs in to your computer . the end you would plug in to the device you can cut off and you need to use the red and black wires to jump start the battery so it will charge . on your battery you will see the - and + the black goes to the - and red to + can use electric tape to hold the exposed wire to it and plug the other end in to your computer for about a 5 to 10 mins and then put it in your phone and turn it on and charge it .if didnt work you might have to leave it hocked up to the usb cord on the battery longer what i did to mine and it turns on and works fine now had the same problem battery got to low and dead . so phone was froze and wouldnt start
Jun 12, 2009 | Cingular Wireless 8125 Smartphone
The screen on my cingular 8125 is white.
open the phone (radioshack sells the tiny screwdrivers) and, reseat the video screen connector that came loose
Jun 01, 2009 | Cingular Wireless 8125 Smartphone
Need to replace small battery on main board for cingular 8125
there is a guy that repairs cellphones in Maryland call him and he can fix it for you and send back. i don't know what he will charge you will have to ask him. his # is !-240-595-7669
Jan 07, 2009 | Cingular Wireless 8125 Smartphone
HTC 8125
you have to contact T-mobile technical support and have them guide you through programming their internet settings on the phone. although the phone is unlocked the internet settings currently on the phone is for cingular. have them program the same settings as the t-mobile MDA phone (same phone as 8125, shipped for t-mobile)
Aug 20, 2008 | Cingular Wireless 8125 Smartphone
No power
Make sure you have an original OEM charger for the MDA. Many of the knock off chargers don't provide the right amperage for the device. What happens is that since the phone is completely dead, it can't regulate how many amps the battery should get during the charge and an incorrect charge current won't charge the battery. I'm guessing that someone sold you a Motorola RAZR charger or another knockoff made for the RAZR. This might charge your phone when the battery is working, but not when it's DEAD. Also you won't have luck plugging it into a computer USB cable because, again, the phone can't tell the computer what charge to send and most computers only produce <0.5 amps in the USB port.
Get a charger that states it is an OEM (original eqipment manufacturer) device or one that is specifically designed for the MDA (or Cingular 8125). eBay is full of them.
Bad charger (probably won't work for a dead battery)
Good Charger (correct amperage and designated for the MDA)
Jul 08, 2008 | T-Mobile MDA
8125 will not reboot
You need to jump start the battery.. The phone's charging capability is controlled by software (pretty dumb) so without enough juice from the battery it won't charge.
Grab an old USB cable (or other 5 volt source) and cut off one end.. take the red wire and put it on the battery contact on the end with the red plus sign. Put the black wire on the other end. Hold the wires there for about 3 minutes. Be careful not to switch the positive and negative.
Now reinsert the battery into the device, and without turning it on, plug in your charger. the charging light should come on shortly, and just leave it off charging for about an hour before turning it on..
Thats all Folks
Dec 04, 2007 | Cingular Wireless 8125 Smartphone
Cingular Wireless 8125 Smartphone Logo
183 people viewed this question
Top Cingular Wireless Computers & Internet Experts
Jim Goldsmith
Jim Goldsmith
fordexpert
Erik Walters
Are you a Cingular Wireless Computer and Internet Expert? Answer questions, earn points and help others
