Question about Nintendo Wii Console
Wii Remotes can turn on but no arrows.
Hi, neither of our wii remotes are working. They turn on and I can press the menu button but there are no arrows to select anything. Our Wii is fairly new and we use rechargable batteries. They are in protective cases. Recently we unplugged our tv and remotes due to painting but since then they have been charged for 2 days, tv is hooked up again...Please help.
I had the same problem. When I looked at my system, I noticed the sensor was turned sideways with my tv remote in front of it. When I turned my sensor around correctly, and moved my tv remote away from it, the arrows suddenly appeared! Make sure nothing is blocking your sensor!
Posted on Jan 07, 2009
OK, i got a new wii remote, set it up, and now none of my wii remotes are working including the one i just set up.
Try these two synchronization processes and if it still doesn't work than contact me:
  1. Press the Power button on the Wii console to turn it on.
  2. Open the SD Card Slot cover on the front of the Wii console. Remove the battery cover on the back of the Wii Remote you wish to sync up.
  3. Press and release the SYNC button just below the batteries on the Wii Remote; the Player LED will blink. Quickly press and release the SYNC button on the inside of the SD Card compartment on the console.
  4. When the Player LED blinking stops, the syncing is complete. The LED that is illuminated indicates the player number (1 through 4).
  5. This procedure must be followed for each additional Wii Remote added to your system.
    One Time Mode Synchronization
Press the HOME Button on a Wii Remote that is synchronized with the Wii console.
  1. Select the Wii Remote Settings option from the Home Button menu.
  2. Select the Reconnect Option.
  3. Press the 1 and 2 Buttons at the same time on the Wii Remote that you want to synchronize with the console. If you are syncing multiple Wii Remotes, press the 1 and 2 Buttons on each Wii Remote immediately (without a significant pause) in the order you want them synced. The order in which you synchronize Wii Remotes determines the player order (1 through 4) for multiplayer games. The Player LED will blink during the syncing process. When the blinking stops, the connection is complete.
PCHELPSTER007 from youtube. If I helped you than please rate me up and if you have any other problems please feel free to contact. Thank you.
Jul 06, 2011 | Video Game Consoles & Games
Wii hand will not show up we tried syncing, taking out batteries, unplugging and plugging sensor bar and nothig works
Synchronizing the Wii Remote with the Wii Console Synchronizing the Wii Remote to a Wii console allows the Wii Remote to communicate with the console. The Wii Remote included with your system should already be synchronized to your console. However, all additional Wii Remotes you use with your system also need to be synced in order to function properly..
There are two different modes of synchronizing (syncing):
  • STANDARD MODE - The Standard Mode procedure is used when adding additional Wii Remotes to your system or if you want to re-synchronize your original Wii Remote. Once synchronized, the Wii Remote will stay synced to the console unless you overwrite the settings by syncing the remote to a different console. For instructions on Standard Mode syncing, please click here.
  • ONE TIME MODE - This mode allows you to temporarily use your remote on a Wii console other than your own, or to use a friend's remote on your console. It can also be used to change the order of the Wii Remotes, without the need to turn off the Wii console. One Time Mode does not delete the Standard Mode setting stored in the Wii Remote. In this mode, the Wii Remote will only communicate with the Wii console while the power is on. When the power is turned off, the Wii Remote will lose its sync with the Wii Console. For instructions on One Time Mode setup, please click here.
Note: Only a Wii Remote in Standard Mode can turn the Wii console power ON or OFF.
    Standard Mode Synchronization
    Note: Make sure you have placed batteries in the Wii Remote (how to).
  5. wiiremotesynchstandard.gifThis procedure must be followed for each additional Wii Remote added to your system.
    Go to the Next Step (Playing Game Discs) >
    One Time Mode SynchronizationNote: This mode temporarily removes Standard Mode synchronization setup for all Wii Remotes until the power of the Wii console is turned off. When the power is turned back on again, the Standard Mode settings will return.
  1. Press the HOME Button on a Wii Remote that is synchronized with the Wii console.
  3. Select the Wii Remote Settings option from the Home Button menu.
  5. Select the Reconnect Option.
  7. Press the 1 and 2 Buttons at the same time on the Wii Remote that you want to synchronize with the console. If you are syncing multiple Wii Remotes, press the 1 and 2 Buttons on each Wii Remote immediately (without a significant pause) in the order you want them synced. The order in which you synchronize Wii Remotes determines the player order (1 through 4) for multiplayer games. The Player LED will blink during the syncing process. When the blinking stops, the connection is complete.
Jan 27, 2011 | Nintendo Wii Console
Pressed red button for more than 10 seconds remotes not working help
hai. I am one of the user of wii....... i also got many problem like this..... i solved my problem using wii repair guide....click here to help you........
Dec 08, 2009 | Nintendo Wii Console
My wii remotes aren't working
First unplug the AC adapter from power cord and wait 10 min.Then plug it again and open the front cover on your Wii, then push the red button there, then open the batteries cover on your Wii Remote and push the red button there.Do the same for second Wii Remote.If this not help press and hold
the red SYNC button on the console for 15 seconds. This will clear all synced Wii Remotes from the console.Then try sync the Remotes again.
Nov 09, 2009 | Nintendo Video Game Consoles & Games
My wii counsel turns on fine, my remotes are with new batteries and flash when pressed the red light, but yhe remotes don't seem to be able to connect to the screen?
if your Wii Remote is not responding It may need to be synced up. I have given you both ways of syncing your Wii. After doing this Please don't forget to rate me as " Very Helpful" & feedback is appreciated - thanks
  • STANDARD MODE - The Standard Mode procedure is used when adding additional Wii Remotes to your system or if you want to re-synchronize your original Wii Remote. Once synchronized, the Wii Remote will stay synced to the console unless you overwrite the settings by syncing the remote to a different console. For instructions on Standard Mode syncing, please read below.
Standard Mode SynchronizationNote: Make sure you have placed batteries in the Wii Remote
  3. Press and release the SYNC button on the inside of the SD Card compartment on the console. Press and release the SYNC button just below the batteries on the Wii Remote.
Sep 22, 2009 | Nintendo Wii Console
Wii remotes cant get synchronized
Press the red button near the SD card slot then press the red button undre the Wii remote's battery cover to synchronize again.
Feb 28, 2009 | Nintendo Wii Console
We have been playing gutar hero band and now our remotes only work on side how do i fix
  2. Select the Wii Remote Settings option from the Home Button menu.
  3. Select the Reconnect Option.
    1. Press the 1 and 2 Buttons at the same time on the Wii Remote that you want to synchronize with the console. If you are syncing multiple Wii Remotes, press the 1 and 2 Buttons on each Wii Remote immediately (without a significant pause) in the order you want them synced. The order in which you synchronize Wii Remotes determines the player order (1 through 4) for multiplayer games. The Player LED will blink during the syncing process. When the blinking stops, the connection is complete.
  • this may reset the remotes for you
    info from nintendos customer service
    Jan 01, 2009 | Nintendo Wii Console
    Our wii remotes do not connect to the wii but the wii works just not the remotes
    you have to reset your remotes. and to do this you sync it, to connect them to your wii .. click on this link and it will show you what to do!
    http://www.bellaonline.com/articles/art41832.asp
    I really hope I know what you mean :P best of luck!!
    Aug 16, 2008 | Nintendo Wii Console
    Connecting 2nd remote
    There are 2 ways to connect remotes on Wii. The way that the remotes sync permanently to a Wii system and the second one that connects the remote temporarily.
    To connect the remotes pernanently, open the flap on the front of the Wii and press the red sync button. Then take the remotes and press the buttons 1 and 2 at the same time.
    Do the same with the other controllers
    The second way can be done via the Home menu. Go to home menu pressing the home button and then point the remote to the bottom of the screen (where a wii remote is iconized) Then go to the synchronization menu to synchronize the remotes. Press 1 and 2 of the remotes to get synchronized.
    The time you press the buttons on the remotes determines the player assigned to it. For example, the first remote you synchronize is the first player, the second is the second player etc.
    Also, I strongly advice you to READ THE MANUAL
    seriously... do it.
    May 24, 2008 | Nintendo Wii Console
    Nintendo Wii Console Logo
    241 people viewed this question
    Top Nintendo Video Game Consoles & Games Experts
    Raj Patel
    Troy Gorman
    Troy Gorman
    phil
    Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
