Question about Hitachi Televison & Video
Hitachi CM87C monitor does this unit have a vidio input
Would this be compatable with the out put of a tr 40cra tv converter
Jim
4 Suggested Answers
SOURCE: assigning inputs or selecting the type of vidio stream i want to use for my dvd player.
Not sure if I understand completely, but if you want to watch a source on DVD then then it needs to have its a/v outputs connected to the DVD inputs on the rear of the receiver.
Posted on Oct 31, 2008
carldc3
  • 82 Answers
SOURCE: Blue Ray Hookup
i have a ps3 hooked up to mine and the blue ray works very good connected using hdmi cable, converters work good also just purchased Hisense HDTV Tuner for mine
Posted on Jan 05, 2009
ionStorm
  • 50 Answers
SOURCE: Describe your LL-T1520-B LCD monitor
Your monitor does not have composite/component inputs. You can however use a composite-to-VGA converter. Kworld makes some great converter products. Here's one...
http://global.kworld-global.com/main/prod_in.aspx?mnuid=1248&modid=6&fcid=2&pcid=199&ifid=104&prodid=410
Posted on May 07, 2011
Hitachi 57F500 dvi input no picture or sound
I had to go to amazon and buy a convertor to convert the hdmi to regular to get my bluray to work with my tv
Jun 08, 2014 | Hitachi 57F500 57" Rear Projection...
I have a Hitachi 55hdt51M 55" plasma monitor/TV with no AVC75 controller. Can I operate this monitor/TV without a controller box vias some sort of direct hookup? The only input connection is labeled "in...
You can use either input to use the monitor as long as you have the correct cable. HD15 to DVI can be converted and so can HDMI to DVI. Only hold up is the type of DVI. There are three types and I cannot remember for sure the designation but I believe there is an I, S and a D. The device will have to be able to display in a matching format.
Jan 27, 2014 | Televison & Video
HOOK UP VIDIO SURVALENCE CAMERA TO BACK OF TV
The camera output would have to be composite---and if so go to one of the rear audio/video inputs: yellow (composite video) is likely all you would need unless the camera has audio as well (go to red or white on same input).
Jun 02, 2012 | Hitachi 43UWX10B 43" Rear Projection...
I dont see a coaxial to plug in cable
This "TV" is actually a monitor. It has no tuner and thus no coax connection. You have composite, S-video and component video inputs. You will need a set-top box. If you have cable, get one that is compatible with the type of cable you are receiving (CATV (analog) or QAM (digital).) If you are getting over the air signals, the basic digital to analog tuners will work but only provide SD out. There are some HD tuner options available.
I'm assuming you have a unit with the video input board installed. (Otherwise, it would only have VGA ports.)
The manual is available here: http://www.hitachiserviceusa.com:8080/CMP4201.pdf . If the direct link doesn't work, see the Hitachi support site at http://www.hitachiserviceusa.com:8080/Index.aspx . Use the drop down menus to choose your monitor (plasma monitor then model number).
I hope this helps and wish that I had better news for you.
Feb 26, 2011 | Hitachi CMP4201U 42 in. HD-Ready Plasma...
How do I connect my laptop to tv to use as monitor
It depends on the laptop and the TV. If both have a VGA port, then use a VGA cable between them. Make sure the VGA port is enabled on the computer (possibly in the BIOS) and then set the monitor properties. You may need to reboot the computer to get the TV on.
If the TV has HDMI input and the laptop also has an HDMI port then you need to check the TV specs. Some HDMI ports can accept a signal from a computer (often labeled HDMI/DVI) and others don't. If the HDMI port is compatible with a computer source, then use an HDMI cable between the two. Again make sure the port is active. If TV's HDMI port is not compatible with the computer, you will need a converter.
If the TV doesn't have a VGA port (and the laptop doesn't have any video port other than VGA), then you will need a VGA to component video converter (or VGA to composite video) depending on the inputs of the TV. See http://www.svideo.com/pctocomponent.html for some converters.
Note: the converters are needed since computers output in a different format than the TV input understands. For analog, the computer is RGB and the component video is YPbPr.
A few media PCs might have a TV out port. This would eliminate the need for a converter. Check the specs for the cable you need.
I hope this helps.
Dec 10, 2010 | Televison & Video
I need assistance in connecting my DVC845E (VHS & DVD recorder) to my Samsung TV. A VHS will play but cannot get it to record.
Some of the Newer VHS/DVD units don't have cable inputs. If this is like yours you can hook a RCA Audio/Vidio cable from your Samsung TV Vidio/Audio outputs (if set has them) to VCR/DVD inputs................... Larry
Oct 08, 2010 | Sylvania DVC845E
Help with Hitachi Audio Video Center (AVC80U)
okay so it doesn't need a remote control.............. The AVC08U should register immediately with the tv, the box itself has a bad HDMI out.
Dec 07, 2009 | Televison & Video
Digital TV Ready?
I believe you need a converter box. Im pretty sure this unit only has a NTSC Tuner. Recieving HD would be via Componet Inputs or DVI. If a HDMI Input is available you could use it too but I think it only has a DVI connector.
Hope this helps,
Skyassoc
Jun 19, 2009 | Hitachi 57SWX20B 57" Rear Projection...
Analog to Digital TV Converter-Which Brand is BEST for the Money?
my first question is how many channels can you receive now, that are clear with no snow, without a dtv box hooked up. if any channels have snowy pictures now when tuned in at best reception, you more than likely will not pick then up with the dtv box. the only option in my opinion that some may prefer from one model to another would be the program guide on some units only show whats on now and next, whereas some units may have a 5 to 7 day program guide. there is one unit out that has a noticeable hum on the audio if turned to a high volume. Im not familiar with the dtt901, but from what you have looked at so far, you shouldnt go wrong with purchasing any one of them. If you can only get 1 or 2 channels now, i wouldnt invest a fortune in a dtv box, unless its your only means of viewing television, and watch alot of tv.
Mar 01, 2009 | Televison & Video
Televison & Video Logo
46 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
