Question about Sony Playstation 3 (PS3) Console
THE PS3 SCREEN STAY BLACK EVEN WHEN THE CONSOLE IS ON
Please help me, it is urgent. When I turn my ps3 on, the screen of the TV just stay black even though the PS3 is on. Here are the situations:
- I know it is not the display problem because I know how to fix them.
- All the cables are properly plug in.
- The ps3 won't recognize any controllers, even when I plug in the USB cable.
- I can still insert any types of disc (DVD, Blu-Ray, CD) but the screen is still black.
- No audio
Please, once again help me!!!
  • gen_ab Jan 07, 2009
    same s%&^ here, so bloody annoying, i know how fix issues usually, especially display.
    This is after update 2.5.2
    i boot up, TV detects resolution set, i get no audio, and a blank screen, pretty sure the ps3 is working behind this ****, cause i can hear my game disk spinning around after i hit x a few times.
    Thanks sony, i've heard of making me send it in for 150$ fix, how bout go F&**(^*&^ you made the problem you fix it! i will not pay for their mistake.
  • ltjustinsane Jan 07, 2009
    I'm having the exact same problem on mine, with no loading screen when I insert a disk
Hi, I can help you but i need you to turn everything on and at that blank black screen insert any Disc wait like 2 seconds and tell me if the top right hand corner if theres a small loading icon looks something like a water drop ripple that pops up. If so i had the same exact problem, they way i fix mine is I replaced my HDD (2.5 SATA drive) which is located on the left side of the ps3 when layed down horizontally if you didnt know already. I went ahead and bought a new 2.5 SATA drive and replaced it with my old one that was causing the problem, most likely is caused buy corrupted data files. HOpe this helps
Posted on Jan 07, 2009
My Ps3 wont turn on
Does the PS3 turn off?
If it stays on but you have a black screen, is it possible you have your tv set to the wrong channel?
Are you able to hook up your PS3 to another tv...preferably one that you know will work...such as a friend's tv that also has a ps3
Feb 13, 2015 | Sony Playstation 3 (PS3) Console
My ps3 console signal isn't working but the sound works but there is no signal! not even a hdmi cable works help!
Try these tips to fix the so-called "black screen of death".
Tip 1: The main reason of HDMI black screen problem due to HDMI cable may be damaged and not properly connected to the PS3 console. Please follow below step to troubleshoot PS3 HDMI cables problem:
1) Restart your PlayStation 3.
2) Look for loose cables.
3) Try to unplug all cables except the power cord, and plug them back in. If you found out that your HDMI cable is damaged, borrow a friends cable and try it. If your friends cable works fine, and the black screen error disappears. Then you can buy a brand new HDMI cable for a replacement.
Tip 2: Only try as last resort. There is a possibility you'll lose all data on your PS3's hard drive. If tip 1 didn't work, you will need to go a step deeper and reset your console. Most PS3 gamers are not aware that Sony actually included a black screen of death troubleshooting method and other HDMI problems in the PS3 manual, you can find it under the troubleshooting section - topic "console reset".
If you do it correctly, the console reset fix will allow you to reset back your PS3 to its default HDMI settings without impacting your gamer profile, and other storage data on the hard drive.
You will need to perform the following steps:
1. Place your PS3 in stand-by mode.
2. Hold down the touch power button until a series of beeps are heard.
3. Listen for one long beep, followed by two shorter beeps.
4. Release the power button.
5. Follow the instructions on screen.
If it works you should be good to go.
May 20, 2012 | Sony Playstation 3 (PS3) Console
Ps3 turns on but screen stays black. when the ps3 turns on the screen stays black even when i change it to different chanles
i think your power card may be the reason for this but i am not sure.................... else use repair guide to fix this problem...............
click here to download repair guide.........
Sep 09, 2010 | Sony Playstation 3 (PS3) Console
I AM TRYING TO RECONNECT MY PS3 ON MY LCD TV AFTER 2 WEEK BEEING DISCONNECTED AND IT DOESNT SEEM TO WORK THREW HDMI CABLE! IT SAYS THAT HDMI CABLE WAS DETECTED BUT WHEN I AM ON HDMI CHANNEL ON TV THERE IS...
I think maybe the following steps might help you out :
Step 1. Turn the PS3 off into standby (red light on)
Step 2. Press and hold the power button. It will beep as soon as you press it and then about 5 seconds later it will beep again. Let go of the power button when you hear this second beep.
Step 3. Wait for your PS3 to start.
This solution basically resets the video output back to standard definition.
Hope this helps and thank you for using FixYa
Aug 26, 2010 | Sony Playstation 3 (PS3) Console
Ps3 turns on with green light an doesn't show users screen blank
Your tv screen has problems with the video mode
that has setted up on your ps3, hold the power button till hear two beeps, this will reset the video mode of the ps3, and leavse you at a screen to set up the video mode of the ps3.
Succes.
Sep 03, 2009 | Sony Playstation 3 (PS3) Console
PS3 will play on AV but will not in HDMI
  1. Connect via AV and turn on the system.
  2. Go to Setting and then Display setting
  3. Select the connector type on your TV.
  4. After you selected connector your TV screen may go staid black. Try to hook your HD cable while the system is still on. (This step should be done in 30 sec. If not, will go back to previous screen)
  5. Your TV Screen should be on via HD cable
Dec 09, 2008 | Sony Playstation 3 (PS3) Console
Gamer in desperate need of help
your video card portion of the ps3 is dying. you will need a new ps3.
Aug 09, 2008 | Sony Playstation 3 (PS3) Console
Ps3 black screen
PS3 works only on HDMI. or you get the composite cables and set the tv up to have the specs liek the ps3
Jul 12, 2008 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
617 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
marley mcelhinney
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
