Question about DISH Network IR Remote Control
New dish network remote not working
I have a 510 receiver and just received a new remote for it. The remote is 6.3 # 148786. I spent and hour with dish network tech support and cant get it to work. Can you help me please?
  • 374 Answers
The 6.3 remote has a blue number two key tab on it when it is shipped from the warehouse. If you remove the battery lid you will be able to remove the tab by pulling it out.You will need the other keys that should have come with the remote and use the black colored uhf key and insert it into the remote and put battery cover back on. Ensure the UHF antenna on the back of the receiver is tight and in the upright position. Now turn the TV on and using the buttons on the receiver press menu twice. This should bring you to the system info screen. There will be a remote address toward the bottom of the screen and usually this number is 1. Now take the new remote and press and hold the clear SAT button on top until all the lights across the top illuminate. Now release and key in 01 and press the pound key. The SAT button should flash three times. Press the record button and noe try to navigate the highlight to the done or cancel option using the left and right key. You should now have control of the receiver if not the antenna port which receives the commands could be faulty. If you were successful with the remote remember you will also need to program it to the TV itself to enable you to turn the TV on and off and control the volume with the remote. The FINAL issue that may be causing your issue is that the part number you gave does not match a 6.3 remote. A 6.0 WILL NOT WORK WITH THE 510 EVEN IF YOU DO ALL OF THE ABOVE as I tried it the other night to verify the accuracy of information that is put out internally. I hope this resolves your issue and if you need help programming the remote to the TV itself please let me know. Thanks for using Fix Ya.
Posted on Jan 07, 2009
I have a Dish IR. Not sure of the model number. Uses 4 AAA batts. The problem I have is the every function seems to work fine except for the volume control. In order to change volume I have to use the TV...
It is possible that those buttons have failed, but a bit more likely the remote lost the codes for the TV itself... since almost everything the remote controls... is on the DVR. I apologize if I am guessing wrong in assuming other "TV" buttons (like INPUT) don't function either.
To re-program your remote to recognize your TV (like when the tech first set up the system) choose from the following receiver types to find the correct remote control TV codes for your Zenith.
Remote TV Codes for 722/622/612/411/222/211 Receivers
Remote TV Codes for 625/522/512/510/508/501 Receivers
Remote TV Codes for 811/381/322/311/301 Receivers
Aug 29, 2011 | DISH Network IR Remote Control
We purchaed a new LCD tv and now our Dish Network receiver does not work with the remote. The Ttv works fine with te remote but not the receiver.
Hello Haley_cb, this is Cheri Torres with DISH Network customer service. I came across your post and wanted to see if I could be of some assistance. There are a few steps you can walk through to get your DISH remote addressed to your receiver again. First you want to make sure you DISH remote is in SAT mode, you can insure this by pressing the SAT button at the top left of your remote. If you have insured this, here are some instructions on how to address your DISH remote to your receiver again. If you have any further questions or concerns feel free to post back here or you can also email me at Cheri.Torres@Dishnetwork.com.
  1. Go to System Info scree. You can do this by pressing the system info button on the front of your DISH Network receiver box. Another way to get into the system info screen is by pressing the power button once and then the up arrow button once on the front of your receiver. If both options do not work you can try opening the smart card door on the left side of the receiver and pulling out the smart card.
  2. Once you are in the system info screen, hold down the SAT button until all mode lights light up.
  3. Enter a number between 1 and 15 using the numeric keypad on the remote.
  4. Press the pound (#) button
  5. Once the SAT button blinks three times, press record. Note: If successful the number selected in step 3 will appear in the System Info screen under Remote Address.
Dec 09, 2010 | DISH Network IR Remote Control
Need to program a existing dish remote to a new dish receiver
marinecorpve
I have provided a link with instructions on how to readdress your remote to the new receiver. I hope this helps.
http://www.dishnetwork.com/SupportSection/remote-setup
Ray Calo
DISH Network
Nov 09, 2010 | DISH Network IR Remote Control
Bought new Vizio 55"
Had same problem - turned off Adaptive Lumina, Backlight control, and Ambient light sensors on the Vizio advanced picture settings and the Dish remote now works. Vizio was emitting an infared signal that interfered with the Dish remote signals with these settings on. TV still works and looks just fine... But best of all Dish remote works too.
Nov 08, 2010 | DISH Network IR Remote Control
HOW CAN i RESET SAT CODE FOR DIH REMOTE CONTROL FOR DIFFERENT DISH BOX
nmg55
Not all remote are compatible with all our receivers. Depending on the receiver and remote model numbers, if they are compatible you can readdress the remote to the receiver. I have provided a link for readdressing the remote to the receiver. I hope this helps.
Instructions on how to readdress the remote to the receiver:
Remotes and receivers models:
222 -
21.0 IR / UHF Pro
222k - 21.0 IR / UHF Pro
301 -
3.4 IR
311 -
3.4 IR
322 -
4.4 IR / UHF Pro
381 -
6.4 IR / UHF Pro
411 -
20.0 IR
501 -
6.4 IR / UHF Pro
508 -
6.4 IR / UHF Pro
510 -
6.4 IR / UHF Pro
512 -
6.4 IR / UHF Pro
522 -
6.4 IR / UHF Pro
612 -
21.0 IR / UHF Pro
622 -
21.0 IR / UHF Pro
625 -
6.4 IR / UHF Pro
722 -
21.0 IR / UHF Pro
722k - 21.0 IR / UHF Pro
Ray Calo
DISH Network
Nov 06, 2010 | DISH Network IR Remote Control
Hi, I bought a lg plasma tv model 55LD520, and now my dish network remote won't work unless I'm literally 2 inches from the reciever. What can I do? Please help
I had the same issue with the 55LD520 and my Dish 722 receiver.
Check out this link for some suggestions:
http://www.satelliteguys.us/dish-network-technical-discussions/193510-ir-remote-1-722-receiver.html
Putting black tape over the receiver IR sensor seems to be working for me.
Sep 05, 2010 | DISH Network IR Remote Control
The 5.3IR dish remote does not work. I changed
dwasson597
You will need to readdress the remote to the receiver. I have provided a linkwith instructions on how to readdress the remote to the receiver. Select yourreceiver type and this will open a PDF document with the instructions. If thisdoesn't resolve the issue, you may need a new remote. I hope this helps.
Readdress the remote to the receiver, step 4:
Ray Calo
DISH Network
Oct 09, 2009 | DISH Network IR Remote Control
DishNetwork IR Remote Control Problem
First the only way the 6.3 will work is if it has the green number 1 on the tab facing you. Assuming this is the case you will need a new remote. This primarily is the remote for the second room away from the receiver. Thanks for using Fix Ya.
Apr 15, 2009 | DISH Network IR Remote Control
Hello. My name is Jerry I have a dish net work I want to set up my dvd recorder with this remok control I have the 510, Part # 118579, 132578 remock control
Jerry,
You will need a 6.4kit or 6.3kit and remote to communicate with the 510 receiver. The remote you have is a 6.0 and may work with the kit but I have never tried that application before and Dish does not recommend that remote as a replacement for the original. An 8.0 remote would work also. Thanks for using Fix Ya and let me know if I can be of further assistance.
Dec 28, 2008 | DISH Network IR Remote Control
Toshiba remote
I have the Toshiba remote ct-90159 and the Dish Pro 301 receiver. I've spent countless hours searching for the same code as you with no results. Finally I gave up and just started trying all the codes for all the satellite receivers listed in the user manual. I landed on 018 AND IT WORKED! Best of luck to you.
Oct 10, 2008 | Televison & Video
DISH Network IR Remote Control Logo
551 people viewed this question
Top DISH Network Televison & Video Experts
brian soufane
john milligan
matt martin
matt martin
Are you a DISH Network Televison and Video Expert? Answer questions, earn points and help others
