Question about Saws
I was using my Delta TS220LS table saw and it stopped running.
The motor will not even hum. The motor was not hot. I was only using it for about 1 minute before it quit. The blade does turn by hand and it has just slight resistance.
    Problem Solver:
  • 5 Answers
I can solve your problem. I need a Delta TS220LS for parts and I do not care if it runs or not. I will buy the saw and you can buy a replacement. What do you say?
Wayne Hill
Anderson, SC
800 944.9577
864 356.3070 cell
Posted on Jun 04, 2009
    President:
  • 1,214 Answers
Confirm there is power to the plug that you are using to power the saw.
Reply back your finding and I can help you further.
Posted on Jan 19, 2009
I own a Delta Shopsmart table saw model TS220LS and I have not used it for years and it still work but I don't know how to get the saw to rise above the table level. thanks.
On pos 75 page A turn the depth adjustment clockwise otherwise if its blocked by wood or other trash control the mechanic and clean it dry .
  • Delta TS220LS TYPE 1 Bench Table Saw Parts
Sep 17, 2016 | Delta Saws
Delta x5 unisaw 3 hp. couple days ago it was running strong never had a problem before. push start motor tries hard to spin but nothing besides a hot motor barely touch it hot. 10 min later saw starts...
The motor has a component called a clixon (there are other names for it, too). The clixon has a step up coil and a capacitor that gives the motor an extra bit of juice to get started turning. When it fails, you get the kind of thing you're talking about. If you keep trying to use it without this component working, it overheats the windings and shorts the motor out, killing it. You're most likely going to end up replacing the motor now.
Sorry I didn't have better news for you.
Jul 09, 2011 | Delta X5 3Hp Left Titl Unisaw with...
My table saw will not start. the power source is good.
If the motor is using a single phase supply there will be a capacitor which could have reduced in value- open.
If so try and use a capacitor in parallel to see if the motor works-- in this case the motor might hum and get heated up.
Mar 11, 2011 | Delta 36 982 10 Inch Left Tilt 1 1/2...
I have a 10" Delta Table saw Model 34-670. I was
Check nameplate on motor for amp draw, and then check that against your breaker and wire size.
http://waterheatertimer.org/Color-codewire2.html
If table saw worked on the breakers before and suddenly stopped working, then see if you can lubricate motor bearings >> look for oil cap on each end of motor and use 3-in-1 oil.
Clean the saw and make sure there's nothing rubbing against drive belt and that saw blade rolls easily when saw is turned off.
Mar 02, 2011 | Delta Saws
I have a delta 36-600 table saw that the clutch or drive has quit working . the motor was rebuilt about a year ago now the drive slips is there a simple or easy fix or adjustment to the clutch for this...
If you have a motor with the no.1313314 and the motor runs ,but the blade spindel does not turn try removing the backcover plate . With this removed you might find that the toothed gear belt has broken. If this ,in fact, is the problem the belt is a Bando syncro,link 100xl.
Hope this rectifies your problem as I am waiting for a new belt myself.
E
Oct 10, 2010 | Delta 10"Hybrid Tablesaw with 30"Unifence
My table saw stops after a minute or two i replaces the capacitor and still does the same the breaker pops out
This means it's drawing high amp. Could be just packed with saw dust, getting hot. The breaker is probably thermal. Clean it up good. If it still trips, check for name plate current on motor and test.
Jun 22, 2009 | Delta 36-716B 10" 1-3/4 HP 120/240V...
Delta Table Saw stopped running
I have a table saw that the cord from the motor plugs into the the back of the on/off switch. I yours is configured like that, unplug the motor cord from the back of the switch and plug it in to the wall and see if the motor will run. If so replace the switch.
Jun 21, 2009 | Delta 10"Hybrid Tablesaw with 30"Unifence
Motor stops after about 5 minutes of running
What are you cutting? What type of blade, power supply, etc are you using. It sounds like the thermal overload is cutting out.
Try looking for a little (red) button on the motor itself that pops out slightly when the motor cuts off.(due to overheating). If you push that in, will the saw start running again?
Mar 23, 2009 | Delta Saws
I was using my Delta TS220LS table saw and it quit running.
Try taking out your brushes and clean them, also clean the brush holders. (make sure the brushes slide all the way in and out freely and that they are not worn down past the ware mark) Also make sure you put the brushes back in the same way or the electric break may not work properly because of the ware pattern it makes.
While you have the brushes out look into the brush holders and look at the armature. The copper blocks are called the commutator if it does not look smooth you might want to take it somewhere and have it tested.
Also make sure your are getting power through your switch to the motor.
More than likely it is your brushes or brush holders.
Jan 07, 2009 | Saws
Saws Logo
248 people viewed this question
Top Saws Experts
Tom Chichester
ray gallant
Are you a Saw Expert? Answer questions, earn points and help others
