Question about Brother MFC-7820N Laser Printer
One more person with BACK COVER OPEN problem
I too cannot get the BACK COVER OPEN message to GO AWAY. Misery loves company I suppose. It seems that this is a common problem without obvious solutions. Please, somebody, HELP US so that we can print again!
  • 5 more comments
  • rerwerwe3d Apr 02, 2008
    I was able to ghetto rig the back black thingy using a letter opener inserted through the opening left by pulling out the paper tray and holding the black thingy in place while I slammed the back door shut.
  • Anonymous May 05, 2008
    same problem, the black thingy wont go into slot
    crappy product
  • lls_email Jun 20, 2008
    Problem with my Brother 7820N MFC Printer.
    After a jam, I've cleared all the paper and I can't get the message "Back Cover Open. Close the Back Cover." to go away. So I can't print.
    Here's what I've done so far:
    Taken everything out (paper tray, drum), opened every door etc, put it all back together, made sure the back door was closed. I've unplugged the power cord, turned it off, rebooted my computer also. Nothing yet has made the message go away.
    This did happen once before and I got it to go away (can't remember how!). I remember it was very stubborn, but I THOUGHT that restarting my computer had been the fix, but not now.
  • fabulosa Jul 01, 2008
    back cover open close the back cover
  • Anonymous Jul 03, 2008
    BROTHER MFC7820N
  • Edro Mar 24, 2009
    I just updated my firmware to the new M release (2/2009), and am getting the back door cover message any time I try to print a page. The paper stops in the fuser, and the message goes away whenever I remove the paper.
    The little black spring-loaded bar on the fuser door seems to be ok, since the error message does not appear when the door is closed and nothing is printing.
    I tried resetting the printer like AZ_CES suggested, but that didn't help me.
  • Anonymous Apr 25, 2009
    I had the same problem and solved it using the help on this site. Thank you.
THANK-YOU Guest for #4. It works! And it seems like a miracle. It took me an hour of fumbling around with flashlight and reading glasses, but I was able to get my brother up and running again.
It's easiest if you remove the back cover completely. Putting it on the edge of a desk or table may make this easier. The door comes off on the left very easily. Just lift the top slotted arm off the peg and then the bottom left part comes off it's peg pretty easily.
Also the fuser cover comes down farther by pressing on the right blue plastic knob and gently pressing the right side of the fuser cover over it.
Then you can see the cylinder that #4 talks about. It lies horizontally in the middle of the fuser cover, about the size of a straw (smaller though). Mine was very obviously bowed and the little spine sticking up (about 1.5 inches long) was also obviously not aligned with a slot below it on the fuser cover.
By gently jiggling it, and particularly on the right side I jiggled it around very gently to push it to the right. (you can move it around a bit and get a feel for where it should be) It then seemed to settle in to the right better, the bowed tension was gone and the spine (or needle) fit right into the slot.
I gently put the fuser cover back up and closed the back door and my printer works.
THANK-YOU thank-you! thank-you a zillion.
(P.S. I tried to attach a photo but had problems with that. . . )
Posted on Jun 20, 2008
Easy solution - once you open up the back cover, there is another smaller black cover that goes over the fuser - on the inside of this smaller cover is a spring loaded piece - this is the "back cover sensor" so to speak. Make sure this is aligned properly, if it doesn't rest in it's place you will forever get the back cover open message.
Posted on Nov 07, 2007
I went to brother typed in the error, it came up with a solution, it told me to pull out the ink cartridge, and sure enough there was anothe piece of paper I had missed in the jam, I pulled it out put the ink back in and it now works fine
Posted on Mar 24, 2008
I Had the Same Problem with a printer i got for free. I tried messing around with the back door sensor flag(spring loaded piece) but it seemed to be located correctly.
I believe the switch has dual purpose first to check for the back cover closed and to see when a paper has gone around the rollers. It would only give me the "back cover" error when a new paper was loaded and would go around the rollers. I would then remove this piece of paper and try again and it would give me the same error.
This lead me to believe that the sensor was working like it should and it could be a programming bug. I couldnt find a way to reset the printer so I took off the left side cover by removing one front and one back screw. (UNPLUG POWER OF COURSE) Then pulled each connector and plugged them back in. This seemed to reset the printer and now it works!!!!
Posted on Jan 11, 2009
I discovered that the long sensor rod was pushed out of place about 1/8" or 1/4" to the left. I noticed that there is a small tongue that fits in a slot about midway on the rod part, and it was misaligned. Once I pushed it to the right to align the toungue with the slot, it all worked again. Aargh, so frustrating.
Posted on Apr 05, 2008
See solution #1. A little bit more clarification:
The "spring loaded piece" mentioned is a black cylinder, about an eighth-inch in diameter, that runs about halfway across the black fuser cover mentioned. On it is a very slender spine. On the printer I looked at, the cylinder was noticeably bowed, and the spine was not fitting through the slots in a small metal shield in the fuser cover. Once I moved it so the spine aligned correctly, and closed everything up, the error went away.
Posted on Mar 05, 2008
  • 40 Answers
I've been researching this problem. You're right, it seems to be a common issue with this MFC. Apparently it's not only a known issue, but Brother has no fix for it outside of replacement.
Posted on Jun 04, 2007
  • Chris Yost
    Chris Yost Jun 06, 2007
    I'm sorry I wasn't able to be more help. But that's the answer I was able to glean from my research; it's a known issue and it's not repairable.
Back cover open message but cover is closed
Sounds like the sensor has been damaged try turning off at wall and re starting if it continues you'll have to go into maintenance mode and reset
Apr 09, 2014 | Brother DCP-7020 All-In-One Laser Printer
GPS antenna error
Unfortunately I have now solution. But since misery love company, take comfort that I'm experiencing exactly the same problem, even after the software update.
Feb 01, 2014 | JVC KW-NT700 7-inch Navigation Receiver...
Keeps shutting off
The same happened to my 'smart phone' and US Cellular had to send it in for reprogramming! It was under the Manufacture Warranty, hope you have a Warranty!!
Hope it helps, misery loves company!
Dr Gene n Landrum, PhQ.
May 19, 2013 | Sony Ericsson Cell Phones
What's your problem?i have a kenwood GE-7020 graphic equaliser display problem
A wire or something shorting to the case. Have you had it apart? Are there any dents in the case? Has it been dropped?
Apr 06, 2012 | Kenwood Audio Players & Recorders
MFC-7220 All-In-One Laser Printer: the back cover open message will not go away...
There is a paper jam in the machine which is blocking the sensor for the back cover.
Remoev the drum and toner (cartridge) from printer and look inside, there should be a piece of paper there, you need to remove it slowly
May 16, 2010 | Brother MFC-7220 All-In-One Laser Printer
The TV only received High Def chanles. When switched to reg. chanels, there are green vertical lines and you can see the goast chanel behind the green lines. On pic in a pic setting the pic. chanel is...
Exact same thing happened to me last night. The TV only received High Def chanles. When switched to reg. chanels, there are green vertical lines. Light is definitely on and visible in the back. Now goes out after abut 30 sec. Misery loves company. Will watch the site for a solution. 4yrs. old just went off extended warranty 45 days ago. damn
Feb 12, 2010 | Samsung HLR5067WX 50" Rear Projection HDTV
Back cover open will not go away ... even though back cover is closed!
This is a common problem with the Brother 7820 printers. If you open the back cover, there is a black tray in front of the fuser roller that falls back. That black tray has an arm on the inside on one side that triggers the back cover open message. try pushing that tray up firmly against the back with the back cover open and see if the message disappears. If it does, try taping folded paper to the rails on inside of the grey back cover. The verital plastic rails are what push the black tray into the printer. By taping the paper on you are adding depth to them which will push the black tray further into the printer. If this doesn't work and you cannot get the message to go away from pushing on the black tray, there may be a problem with the trigger. If this were the case I would replace the printer. You can find the 7820 refurbished for $99 online. Just google 7820 refurb.
Apr 15, 2009 | Brother MFC-7820N Printer
I had the same error message. I also tried every compartment... Here's ultimately what my problem/solution was...
I turned the printer around and fully opened the back cover. I found that one of my kids had somehow fed a small piece of paper/cardboard into the printer. When I opened the back cover all the way I could see that obstruction (which I hadn't seen before). Pulled it out, and the error message went away. Works fine now.
Sep 02, 2008 | Brother MFC-7820N Printer
Brother MFC-7820N Laser Printer Logo
753 people viewed this question
James Cagle
James Cagle
ctnozil
Victorman
Victorman
