How to load ink cartridge - Office Equipment & Supplies
  • 2,692 Answers
Follow the directions in the manual for your model of printer. The engineeers designed them all differently. If you need a manual go to the manufactors website and downolad on for your model.
Posted on Jan 07, 2009
How to load ink cartridges
It uses cartridges, to change ink cartridge open from the section where the paper comes out from, take a good look you would find a small groove where your finger can enter then pull. while it is ON the ink carrier moves to the convienient position.
Aug 20, 2014 | HP PSC 2175 All-In-One InkJet Printer
The Lexmark 7100 Series User's Guide will give you a more comprehensive guide on how to load your ink cartridges in your printer.
Aug 28, 2011 | Lexmark X7170 All-In-One InkJet Printer
How do I change the ink cartridges on a lexmark 5495
Please follow the steps below on how to replace ink cartridge on the Lexmark X5495 printer:
  1. Make sure the printer is on.
  2. Lift the scanner unit. The print cartridge carrier moves and stops at the loading position, unless the printer is busy.
  3. Press down on the cartridge carrier latch to raise the cartridge carrier lid.
  4. Remove the used print cartridge.
Sometimes the ink cartridge carrier won't automatically move to its loading position even when the printer is on and the cover is open. Follow the steps below:
1. Unplug the printer from the power source.
2. With the cover open, hold the solid white strip that connects from the carrier assembly to the ink cartridge carrier and gently slide the cartridge carrier to the center of the printer.
3. Remove the used cartridges.
4. Load the new cartridges. Close the cover.
5. Plug the printer back to the power source.
Aug 14, 2011 | Lexmark X5470 All-In-One InkJet Printer
My printer won't align new ink. It says load paper in tray. I load it. then blank page come out and gives me the same message. Load paper in tray. I did a diagnostic test and at the bottom it says...
Sorry to know you're in trouble with your printer. Here are my suggestions: You have to buy a new genuine cartridge or you can refill ink. Be warned! Refilling ink or using a refilled ink cartridges will not work until the ink cartridge chip or ink monitor is disabled. For instructions on how to disable an ink cartridge chip, please visit []Now you can CURSE the manufacturer of your printer for making your life sucks by making it complicated the things that should be made SIMPLE and EASY. Printer or Cartridge, more or less, cost you the same. Don't you think the printer cartridges should be made simply refillable/usable unless they are broken, and we should be buying only the ink for the cartridges. It is SO ANNOYING, dude! Good luck.
May 06, 2011 | Office Equipment & Supplies
Loaded cartridge, but the printer still says load right side
There may be some ink covering the circuit pads on either the ink cartridge or the flexible circuit board that makes contact to those small gold pads on the ink cartridge. I have been able to get cartridges to work by cleaning both the pads on the flexible circuit in the printer and the ink cartridge very carefully with a cotton swab dipped in alcohol.
Aug 13, 2010 | Lexmark X125 All-In-One InkJet Printer
How do I load an ink cartridge into a f 2480
Power on the printer, gently raise or pull the head up when it has finished loading and ready to print. you will notice that the ink cartridge house moves to the middle.
Now power off the printer with the printer head still raised, gently load the ink cartridge you want to insert into the printer and pull the printer head down back after you have load it.
You can now power on your printer to boot up.
Apr 23, 2010 | Office Equipment & Supplies
Have error message saying paper is to narrow, load wider paper and press enter, A4 is loaded print options are set to upper tray A4, paper is loaded, cannot clear message
That message is indicating that there is a problem with the cartridge alignment.
From HP:There are several reasons why the HP All-in-One may fail to align the cartridges. The most common reason is an ink cartridge that has one of the following problems:
  • One of the ink cartridges is low or out of ink. Black and all three colors must be available.
  • The paper has already been printed on or is colored paper.
  • Protective tape on a new ink cartridge has not been removed.
  • Contacts on the ink cartridge are not meeting the contacts in the carriage correctly.
  • Cartridge is remanufactured or refilled. Refilled or remanufactured ink cartridges may have been damaged during the refilling process or have clogged ink nozzles.
  • The ink cartridge is defective.
Also, use a fresh piece of paper that has never been printed on for the alignment process or the alignment will fail.
Hope this helps.
Dec 01, 2009 | HP PSC 950 All-In-One InkJet Printer
How do I change the ink cartridge on my Dell 810 printer
Ink Cartridge Maintenance Replacing an Ink Cartridge
  1. Turn on your printer.
  2. Lift the printer unit, and position the scanner support between the tabs to hold it open.
The ink cartridge carrier moves and stops at the loading position unless the printer is busy.
  1. Press down on the ink cartridge lever to raise the ink cartridge lid.
  1. Remove the old ink cartridge.
  1. Dispose of the old cartridge properly.
  2. If you are installing a new ink cartridge, remove the sticker and transparent tape from the back and bottom of the ink cartridge.
  1. Insert the new ink cartridge.
  1. Snap the lid closed.
  1. Lift the printer unit, and hold the scanner support up while lowering the printer unit until it is completely closed.
rcrtdrc1.jpg Aligning an Ink Cartridge You may need to align the ink cartridge when characters are not properly formed or are not aligned at the left margin, or when vertical or straight lines appear wavy.
To align the ink cartridge:
  1. Load plain paper. For more information, see Loading Paper.
  2. In Windows XP, click Start® Control Panel® Printers and Other Hardware® Printers and Faxes.
In Windows 2000, click Start® Settings® Printers.
  1. Right-click the Dell AIO 810 icon.
  2. Click Printing Preferences.
The Printing Preferences dialog box opens.
  1. Click the Maintenance tab.
  2. Click Align Print Cartridge.
  3. Click Print.
A blue and black alignment page prints.
  1. After the alignment page has finished printing, place the page face-down on the scanner glass. Make sure the upper left corner of the front of the page aligns with the arrow on the printer.
  1. Press the Scan button scanicoa.jpg .
The page is scanned. When the scan is complete, the cartridge is aligned. You may discard the alignment page when the alignment is complete.
Please download the manual from the link below and go to chapter Ink Cartridge Maintenance:
Hope it helped.
Nov 22, 2009 | Office Equipment & Supplies
Hi there
Replacing Ink Cartridges 1. Turn on your printer. 2. Lift the printer unit. 3. The ink cartridge carrier moves and stops at the loading position unless the printer is busy. 4. Press down on the ink cartridge lever to raise each ink cartridge lid. 5. Remove the old ink cartridges. 6. Store the cartridges in an air-tight container, such as the storage unit you received with your photo cartridge, or dispose of them. 7. If you are installing new ink cartridges, remove the sticker and transparent tape from the back and bottom of each ink cartridge. 8. Insert the new ink cartridges. Make sure the black or photo ink cartridge is secure in the left ink cartridge carrier and the color ink cartridge is secure in the right ink cartridge carrier. 9. Snap each lid closed. 10. Close the printer unit. 11. An alignment page automatically prints.
Mar 01, 2009 | Dell 926 All-In-One InkJet Printer
Loading the ink cartridge
Please remember to rate other users who assist you for free :)
How to install or remove ink cartridges To print normally, install or remove ink cartridges in an orderly procedure.
How to install ink cartridges
1. After confirming that the printer is powered on, open the front cover. The ink cartridge holder moves to the replacement position.
2. Take out an new cartridge from its casing and gently remove the orange protective tape in the direction of an arrow.
Caution: Do not attempt to reattach the protective tape once you have removed it. Do not touch the gold electrical contacts or the print head after removing the protective tape.
3. Insert the color cartridge into the right slot and then the black cartridge into the left slot.
Note: Push up on the nearest side of the cartridge until it clicks into place.
4. Confirm that the ink cartridges are installed properly.
(A) The ink cartridge is not installed properly.
(B) The ink cartridge is installed properly.
5. Close the front cover. Wait until the preparatory operation is complete; it takes about one to two minutes.
How to remove ink cartridges
2. Remove the ink cartridges.
Note: Handle the ink cartridges carefully to avoid staining clothes and surrounding work area.
Sep 29, 2008 | Canon PIXMA iP1800 InkJet Photo Printer
262 people viewed this question
