Question about Kitchen Ranges
HAIER RANGE HOOD MODEL HH1030 ONE WHITE WIRE NAKED AT END, ONE BLUE WIRE NAKED AT END AND ONE BROWN WIRE NAKE AT END, WHICH IS THE GROUND WIRE.I HAVE ONE WHITE/ONE BLACK WIRE AND ONE GROUND WIRE COMING FROM THE WALL FROM ORIGINAL INSTALLATION. DO THE BLUE WIRE AND BLACK CONNECT TOGETHER, I KNOW THE 2 WHITE WIRES CONNECTO TOGETHER AND THE 2 GROUND WIRES TOGETHER MOUNTED TO THE GROUND SCREW.
  • 16 more comments
  • decarlo221 Jan 07, 2009
    IS THIS THE CORRECT INSTALLATION OF THE RANGE HOOD FOR HAIER. MOST WIRING IS ONE BLACK, ONE WHITE, ONE GROUND WIRE. THE BLUE WIRE COMING FROM RANGE HOOD MUST THE HOT WIRE WHICH CONNECTED TO THE BLACK WIRING COMING FROM THE WALL.
    WIRING INSTALLATION, ON HAIER HH1030 RANGEHOOD, THE ONE BLUE WIRE AND ONE WHITE WIRE THAT IS NAKED AT END COMING FROM UNIT, IS THE BLUE WIRE CONNECTED TO THE BLACK WIRE COMING FROM THE WALL AND THE WHITE WIRE CONNECTED TO THE WHITED WIRE COMING FROM THE WALL.
    WIRING INSTALLATION HAIER RANGE HOOD HH1030 ONE BLUE WIRE AND ONE WHITE WIRE AND ONE BROWN WIRE NAKE AT END, COMING FROM UNIT. DO THE BLUE WIRE CONNECT TO THE BLACK WIRE COMING FROM THE WALL AND THE WHITE WIRE CONNECT TO THE WHITE WIRE COMING FROM THE WALL AND BROWN WIRE IS THE GROUND CONNECT TO GROUND THEN MOUNTED ON THE SCREW IN UNIT. INSTALLATION IN MANUEL IS CONFUSING.
    MANUEL IS CONFUSING , IT TALK ABOUT TWO BLACK WIRES BEING CONNECTED, TWO WHITE WIRES , IT DON'T TALK ABOUT A BLUE WIRE. CONFUSING PLEASE HELP
    HAIER RANGEHOOD INSTALLATION, MANUEL IS CONFUSING. ONE BLUE WIRE ONE WHITE WIRE ONE BROWN WIRE ALL NAKED AT END COMING FROM UNIT. IS THE BLUE WIRE THE HOT WIRE CONNECTED TO THE BLACK WIRE FROM WALL, WHITE TO WHITE ,BROWN WIRE TO GROUND FROM WALL AND MOUNTED ON UNITE TO SCREW. PLEASE HELP
    NO IT DON'T HELP
  • decarlo221 Jan 08, 2009
    THE BOOK DID NOT HELP FROM HAIER. PLEASE REPLY
    the blue wire coming from the unit connects to the black wire coming from the wall, and white wire coming from the unit connects to the white wire coming from the wall. the brown ground wire coming from the unit connects from the ground wire coming from the wall. is this the correct connects. so, the blue wire coming from the unit Haier rangehood HH1030 is the hot wire, which connects to the hot wire black coming from the wall.
  • decarlo221 Jan 11, 2009
    haier rangehood hhx1030 model,after wiring installation, the fan do not the work. i have the white wire to white, the blue wire coming from the unit to the black wire from wall,the night lite works, the ground wire to the screw,there is a brown wire coming from the unit. what do this connect to? or is this a ground wire? please respond.
    wiring installation with the haier rangehood hhx1030.
    haier hhx1030 rangehood wiring installation, have the white to white, blue to black, brown to the ground screw with the ground wire coming from wall. the night lite works, but the fan want come on. the wiring must not be correctly install. please help.
    is the white the ground wire.
  • decarlo221 Jan 18, 2009
    haier rangehood hhx1030 need help with wiring installation. blue wire from unit to the black wire from wall, white to white plus the brown from unit is connected to the white. is this right? the book is confusing, but this what i figure out of the book.
    on the wiring connections, white to white plus the brown, blue to black, is this correct wiring. on haier range hood hhx 1030
    haier rangehood hhx 1030 wiring installation, blue to black, white to white plus the brown wire, is this correct? please advise
    blue to black, white to white plus the brown wire, correct the book is confusing
  • decarlo221 Jan 23, 2009
    good info
  • 2,071 Answers
Just click the site below: http://www.acmehowto.com/
Posted on Jun 11, 2009
  • 8,197 Answers
Blue to Black, White to white and the Brown wire is the ground. If you have a green or bare wire in the box conect to it. Or if the box is metel screw it to the box as the ground. That is the way to wire the hood.
Good Luck and Please Rate FixYa!
Posted on Jan 22, 2009
    President:
  • 2,559 Answers
Blue is to white
brown is to black
Here is a link to the installation manual
page 9 shows the wiring diagram.
http://www.haieramerica.com/en/asset/archived/HHX1030.pdf
Posted on Jan 18, 2009
  • Randy Hough
    Randy Hough Jan 18, 2009
    Hope this helps
  • Randy Hough
    Randy Hough Jan 22, 2009
    Twist the blue and white from the unit,to the white from power wire.(2 white + 1 Blue)
    twist together the brown from the unit and black from the power wire.(1 brown+ 1 black
    Uninsulated wire(center bare copper wire) goes under the ground screw by it's self.
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
Initially, you would need a continuity tester (DVM or VOM). Check as follows:
  • unplug/disconnect the range hood from the outlet/power source;
  • set DVM/VOM to ohms (X1);
  • one prod to the body of the range hood (exposed metal), the other to white, then blue, then brown. Whichever wire shows 0 or nearly 0 ohms, that would be the body ground (for the moment I would suspect blue although standard would be green or green/yellow);
  • that would leave you 2 wires (presuming blue is ground, then that would be white and brown);
  • measure the resistance of the left two wires (white and brown);
  • turn on the switches;
  • there should be continuity when the LIGHT switch is turned on, the measured resistance would go down a little when the fan switch is set to LOW and would go down further if fan is set to HIGH;
  • set the DVM/VOM to ACV;
  • measure the voltage on the outlet between the black and white wires;
  • it should read as 120VAC;
  • if not try combination of colors and ground till you get the 120VAC;
  • if black & white measures 120VAC, then connect brown of range hood to black of outlet;
  • connect white of range hood to white of outlet;
  • if some other combination measures 120VAC, connect the brown & white of the range hood to which ever wire measures 120.
Check and perform preliminary visual or necessary inspection. Pls post back result(s). Good luck and Thank you for using FixYa.
    Sergeant:
  • 270 Answers
Make the electrical connections by fastening the brown power wire to the opposing black power wire and the hood’s blue power wire to the other white wire.
There is the manual and installation guide for that product on-line
Click on customer support,,,
you'll Manual & warrenty Info section, in the box type "hhx1030" hit "GO",,, you have to hit "GO" don't pick any of the model numbers from the drop box. Hitting "GO" will show all the info they have for that model number type. The first one is the manual your looking for.
  • 19,396 Answers
    Sergeant:
    Champion:
  • 247 Answers
Welcome-
here is how you need to wire the hood in:
  • white to white
  • brown to black
  • blue is ground
if you look in your instruction manual on page 8 it shows a diagram on how to wire the hood. i know that it is confusing and that is why i am helping you. it shows on the right side brown wire point right with writing below it that means that it is your hot wire. which means brown goes to the black wire. and the white is your nuetral wire meaning white to white. which leaves your blue wire, well there is only one option left for it and that is the ground.
if there anything else i can do for you let me know.
thanks
tom
Posted on Jan 11, 2009
  • 362 Answers
Let me know if this helps  lone99star
  • Jason Morris Jan 11, 2009
    White is ground, blue is light power, brown is fan power.
  • 1,512 Answers
A lot of the calls in this post are suspect. You may be in America, and standards vary around the world. In Au, brown is phase, Blue is neutral. Always think the warmer colour(hot) is phase. Black is never ground, nor phase in a single phase system, earth is always green or green with yellow trace. If in doubt, you should be advised to have an electrician make the connections to save electrocuting someone.
  • 470 Answers
You need the complete diagram wiring of it, go to my sites,, http://books.google.com.ph/books?id=wuPdEjNZle8C&pg=PA65&lpg=PA65&dq=kitchen+RANGE+wiring+installation&source=web&ots=0_oIdtJsLS&sig=Dii09f4OzJf5czOOTlVSNTHl3Ws&hl=en&sa=X&oi=book_result&resnum=1&ct=result#PPA79,M1
what u have there is probily #6 se cabel and ill bet its alumium wire being that its on a 40 amp breaker. u said u plained on installing a j box in attic and useing 8-3 with ground useing the bare to ground between the boxes. this will not ground the boxes since it does not go to the panel. now u also asked if this would meet the code. this all depends on what year code your area is useing. a 3 wire range will meet the 93 and 96 code but in 99 the code was chainged to require a 4 wire. in my area we r allowed to repair 3 wire range and dryer but any new construction we must install a 4 wire. u need to check with your local building inspection department to c what they require.
what we would do here is install the j box in attic install a new piece of se cabel and wire it back in.
  • 1 more comment
  • Antonio Buenafe Jr.
    Antonio Buenafe Jr. Jan 11, 2009
    it is verry possabel for a new range to be a 3 prong plug. since u know the range is 3 prong id wire it accordinly. if your old wire is in good condition you shuld be fine useing it. if u determin its in good condition and r going to use it install your j box and add a piece of 8-2 with ground hook the black and white to the covered wire and bare to bare. useing wirenuts it will eather take blue or gray nuts.
    Antonio Buenafe Jr. Jan 18, 2009
    look it carefully
    http://www.bigcee.com/faq/KLR650-color-w...
    Guru:
  • 449 Answers
Make the electrical connections by fastening the brown power wire to the opposing black. power wire and the hood’s blue power wire to the other white
Posted on Jan 08, 2009
  • Jerry Parmanand Jan 08, 2009
    1) There are three different color wire strands to be connected. Strip solid wire 5/16” and strip
    stranded wire 3/8”.
    2) Connect the power line ground wire to the grounding green lead supplied with the hood.
    Ground wire will always be green.
    3) Make the electrical connections by fastening the brown power wire to the opposing black
    Sergeant:
  • 431 Answers
Black wire is the ground wire
  • 115 Answers
Yes the blue and black connect together one goes to light and one goes to fan good job you had it figured out please give a good rating for me
Posted on Jan 07, 2009
  • 334 Answers
Trace out the brown wire, where does it ultimatly go to?
  • Danny Clark
    Danny Clark Jan 07, 2009
    If the brown wire is "naked" as in no rubber insualtion, it is the ground. In that case, go white to white, black to blue, and ground/green to brown/naked.
    Scholar:
  • 76 Answers
Here's a link to the manual, you'll find the wiring diagram on page 8
Model HHX1030
  • 1 more comment
  • mwit465
    mwit465 Jan 08, 2009
    Connect the brown wire from your hood to the black of your house
    Connect the Blue wire from your hood to the white of your house
    MOST IMPORTANTLY check to make sure the white wire from your hood is in fact a ground wire which would then be connected to the house ground
    (It should be connected to the metal structure or housing of your hood.
  • mwit465
    Read my last post but as long as you connect the ground to the ground, the other two wires won't matter. From what you said earlier you said you had a white wire coming from the hood. According to the wiring diagram this is NOT a power wire so must be a ground. It should be connected to the ground wire of your house.
    Let me know if this helps.
  • mwit465
    One last thing.
    Black is not necessarily ground. For most residential construction this is the "hot" or power.
    White is the nuetral (this is the return path for the "hot" or power) and the bare wire is ground
    The two "hot" wires coming from your hood are blue and brown because they are for light and fan (both power) Hence would be connected to you houses black and white.
    REMEMBER: follow the white wire from the hood to see if it grounds to the housing or motor.
    If it does, this is your hood ground.
    According to the wiring diagram the blue should go to the light, and the brown to the switch.
  • 716 Answers
Http://www.haieramerica.com/en/asset/archived/HHX1030.pdf
The PDF File On Your Range With Wiring Diagram.
    Master:
  • 416 Answers
Good Luck
  • 10,515 Answers
HEY THE BEST LINK :)
ALSO KEEP UR SPEAKERS ON TO LISTEN TO TE PROCEDURE AS WELL :)
http://www.easy2diy.com/cm/easy/diy_ht_3d_index.asp?page_id=35743519
THANKS.
    Genius:
  • 1,199 Answers
You connect the blue and black wires and all will be well
Ford 2015 transit radio wire color codes
Car Radio Battery Constant 12V+ Wire: White/Red
Car Radio Accessory Switched 12V+ Wire: Blue
Car Radio Ground Wire: Black/Blue
Car Radio Dimmer Wire: Violet/Gray
Left Front Speaker Positive Wire (+): White
Left Front Speaker Negative Wire (-): White/Brown
Right Front Speaker Positive Wire (+): White/Violet
Right Front Speaker Negative Wire (-): White/Orange
Left Rear Speaker Positive Wire (+): White/Green
Left Rear Speaker Negative Wire (-): Brown/Yellow
Right Rear Speaker Positive Wire (+): Brown/White
Right Rear Speaker Negative Wire (-): Brown/Blue
Jan 26, 2017 | Ford Cars & Trucks
99 dodge truck sterio wireing picture
We need details about your car model, but this coild helpfull...
1999 Dodge Dakota Car Audio Wiring Diagram
Car Radio Battery Constant 12v+ Wire: Red/Blue
Car Radio Accessory Switched 12v+ Wire: Red/White
Car Radio Ground Wire: Chassis
Car Radio Illumination Wire: Black/Yellow
Car Stereo Dimmer Wire: Orange
Car Stereo Antenna Trigger Wire: N/A
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Dark Green
Left Front Speaker Negative Wire (-): Brown/Red
Right Front Speaker Positive Wire (+): Brown/Yellow
Right Front Speaker Negative Wire (-): Brown/Light Blue
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Left Rear Speaker Negative Wire (-): Dark Blue/Red
Right Rear Speaker Negative Wire (-): Brown/Orange
1999 Dodge Ram 1500 Truck Car Stereo Radio Wiring Diagram
Car Radio Constant 12v+ Wire: Red
Car Radio Switched 12v+ Wire: Red/White
Car Radio Illumination Wire: N/A
Car Stereo Dimmer Wire: Orange/White
Car Stereo Antenna Trigger: Yellow
Car Stereo Amplifier Location: Behind the glove box.
Right Front Speaker Positive Wire (+): Violet
Right Front Speaker Negative Wire (-): Dark Blue/Red
Left Rear Speaker Positive Wire (+): Brown/Yellow
Left Rear Speaker Negative Wire (-): Brown/Light Blue
Right Rear Speaker Positive Wire (+): Dark Blue/White
Right Rear Speaker Negative Wire (-): Dark Blue/Orange
Hope this helps; also keep in mind that your feedback is important and I`ll appreciate your time and consideration if you leave some testimonial comment about this answer.
Thank you for using FixYa, have a nice day.
Jun 29, 2012 | Cars & Trucks
How to wire a towbar to a renault laguna ? what
If you have the Renault end, I've got the rest. I have the pinouts for 7 wire, 6 Wire and 4 Wire, One of them will fit the bill
Plug Types/Application
7 Way - RV Trailers, Horse and Utility Trailers
6 Way - Horse, Stock and Utility
4 Way - Utility Trailers
Columns are: Color, Function, Mark on the plug.
Seven wire Trailer plugs:
Horse, stock or utility trailers:
White = Ground - 1
Blue = Electric Brakes - 2
Brown = Tail and clearance lights - 3
Black = Battery, aux power - 4
Yellow = Left turn/Brake - 5
Green = Right turn Brake - 6
Orange or Purple (not both) = Auxilliary or Reverse - 7
Recreational Vehicle:
White = Ground - 1
Blue = Electric2_bing.gif Brakes - 2
Green = Tail and clearance lights - 3
Red = Left turn/Brake - 5
Brown = Right turn Brake - 6
Yellow = Auxilliary or Reverse - 7
Six wire trailer plugs:
White = Ground - GD
Yellow = Left turn/Brake -LT
Green = Right turn Brake -RT
Brown = Tail and clearance lights - TM
Red or Black (not both) = Battery2_bing.gif, aux power - A
Blue = Electric Brakes - S
Recreational Vehicle: (color, use, plug mark)
White = Ground - GD
Brown = Right turn Brake - RT
Green = Tail and clearance lights -TM
Black = Battery, aux power - A
Red = Left turn/Brake - LT
Four wire plugs:
White = Ground
Ground should be 10ga.
Others 14 ga
A test light and a 12VDC power source can be handy for trouble shooting
Best regards
Aug 14, 2010 | 2007 Renault R18
Which colour wire to use to hook up a trailer for a Kia Carnival 2000,trailer leads are yellow, green,black,brown,red,white and blue(no connection). just want to know which lead goes to which in the Kia?...
Here is a cheat sheet I compiled that you will find very helpful:
Columns are Color, Function, Mark on the plug.
White = Ground - 1
White = Ground - 1
White = Ground - GD
Red or Black (not both) = Battery, aux power - A
White = Ground - GD
Yellow = Not used -
Four wire plugs:
White = Ground
Others 14 ga
Best regards
Mike
Oct 28, 2009 | 2000 Kia Amanti
Radio wiring harness color code for ford van e-250
Car Radio Battery Constant 12v+ Wire: Red/White
Car Radio Accessory Switched 12v+ Wire: Blue
Car Radio Ground Wire: Black/Gray
Oct 09, 2009 | 2005 Ford Econoline Cutaway
Can,t figure out how to wire it up to my 1995 jeep and would like to find out how to wire it up?
Dont know what model you have so here u go!
1995 Jeep Wrangler Car Stereo Radio Wiring Diagram.
Car Radio Constant 12V+ Wire: Red/White
Car Radio Switched 12V+ Wire: Purple/White
Car Radio Illumination Wire: Blue/Red
Car Radio Dimmer Wire: Red/Black
Car Radio Antenna Trigger Wire: N/A
Car Radio Amp Trigger Wire: N/A
Front Speakers Size: 4′ x 6′
Front Speakers Location: Dash
Left Front Speaker Wire (+): Gray
Left Front Speaker Wire (-): Yellow
Right Front Speaker Wire (+): White/Red
Right Front Speaker Wire (-): Brown/Red
Rear Speakers Size: 4′
Rear Speakers Location: Rear Roof
Left Rear Speaker Wire (+): Gray/White
Left Rear Speaker Wire (-): Brown/White
Right Rear Speaker Wire (+): White/Black
Right Rear Speaker Wire (-): Brown
1995 Jeep Cherokee Car Radio Stereo Audio Wiring Diagram
Car Radio Constant 12v+ Wire: Pink
Car Radio Switched 12v+ Wire: Violet/White
Car Radio Illumination Wire: Light Blue/Red
Car Stereo Antenna Trigger: N/A
1995 Jeep Grand Cherokee Car Stereo Radio Wiring Diagram
Radio Switched 12V+ Wire: Red/Gray
Radio Dimmer Wire: Orange
Radio Power Antenna Trigger Wire: Green/Red
Radio Amplifier Turn On Trigger Wire: N/A
Front Speakers Size: 6 1/2′
Front Speakers Location: Doors
Left Front Speaker Wire (+): Green
Left Front Speaker Wire (-): Brown/Red
Right Front Speaker Wire (+): Purple/Yellow
Right Front Speaker Wire (-): Blue
Rear Speakers Size: 6 1/2′
Rear Speakers Location: Rear Doors
Left Rear Speaker Wire (+): Brown/Yellow
Left Rear Speaker Wire (-): Brown/Light Blue
Right Rear Speaker Wire (+): Blue/White
Right Rear Speaker Wire (-): Blue/Pink
window.google_render_ad();
Jun 03, 2009 | Pioneer DEH-P2000 CD Player
I need the wiring diagram for the radio on a 1994 nissian quest gxe
Constant 12V+ Brown/White
Switched 12V+ Orange
Ground Black/Light Green
Illumination Pink/Black
Dimmer Pink
Front Speakers 5" x 7" Doors
Left Front (+) Gray/Blue
Left Front (-) Yellow/Blue
Right Front (+) Blue
Right Front (-) Yellow
Rear Speakers 5" x 7" Side Panels
Left Rear (+) Blue/White
Left Rear (-) Blue/White
Right Rear (+) Blue/Black
Right Rear (-) Red/Blue
Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
Apr 13, 2009 | 1994 Nissan Quest
I have a Philips wall jack model number ph69636. and i need to know how to wire it up with a cat5e cable
Pin Std Phillips
1 White/Orange BLUE
2 Orange Orange
3 White/Green Black
4 BLUE Red
5 White/Blue Green
6 Green Yellow
7 White/Brown Brown
8 Brown White
May 16, 2008 | Computers & Internet
Plymouth voyager
Hi Marlon,
Not a whole I can do to help. What I can do is refer you to go get a Chilton, or Haynes manual thac voers your Plymouth Voyager. They have schematics with wire colors labeled.You will have a good shot at figuring out which wire is which.
Nov 24, 2007 | Car Audio & Video
Kitchen Ranges Logo
292 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
