Question about Lexmark Office Equipment & Supplies
Broken pin in USB port, how do i replace port?
One of the pins in the USB port on my Lexmark all in one 7300 seriesgot bnet and then broke off. How do I replace the port?
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 144 Answers
Find a guide to disassemble your computer and buy a replacement ports then before removing the port take a picture of how it was inserted then desolder the port and insert the new one.
Posted on Jan 07, 2009
USB Port Plastic Pin Divider Broke
you will have to replace it. or make sure the connecyion touches. invest in one of these Black 4 Port High Speed USB 2 0 Hub
Jan 16, 2014 | Computers & Internet
Plastic Pin Divider in USB port broke off
is it on board or not if not just replace it and if not you will have to desolder and get a new one not worth it. get new usb port will go in the back slot of computer then plug it in the usb port on board jim time saver that way.
WHY MY BIOSTAR G31-M7 TE mother board key board NOT WORKING ANY KEY BOARD?
Lets trace the problem here before we get to the solution. Check the keyboard on another computer to see whether the problem still exists. If the keyboard does not respond then the problem is with the keyboard. But if the keyboard works fine on another computer then the problem might be with the keyboard port of your computer. Now lets get down to the solution. If the keyboard doesnt work on both computers, firstly check the keyboard connecting pin. The pins inside it might have been bent, broken, pushed in or the pins have remained to the keyboard port on your computer. In the case of broken, bent or pushed in pins, REPLACE THE KEYBOARD WITH A NEW ONE. In the case that the pins have remained in the port of your computer, get a Computer Technician to remove the pin. If it can not be removed, then replace the keyboard with the usb one.
Dec 11, 2011 | Computers & Internet
Could a firewire cable have bent the pins in sony trv19e
If the pins of the cable are broken, better to buy a new one. If the pins of the camara port are broken, a professional may be able to fix it.
Jul 07, 2009 | Sony Handycam DCR-TRV33 Mini DV Digital...
Motorola E680 charging port pins broken
do you can to servicing it?
try to replace the usb connector. you may replace by the MP4 usb connector.
just a little bit hard but it will 100% works!!
it is easy to open the phone.
Oct 04, 2008 | Motorola Mobility E680i Cellular Phone
I have a 1 GB flash drive that is physically broken and my laptop won't recognize it. The pin got bent and was partially out of the case.
relax , as long as your flash drive is not smashed with a hammer
we can get it back up and running , your notebook on the other hand may need a little technical lovin'
if you broke a pin in the USB port , thats gonna take some serious work , if the notbook is under warrenty use the warrenty
if the notebook is passed it's warrenty , then you CAN do the job yourself , you'll need to remove a USB port from a junk motherboard or better , and use that to replace the broken pins
that does involved some soldering with a solder gun or pen
which might cost you about 10 to 20 dollars as of 2008
Good luck and may the nforce2 be with you , always.
Aug 25, 2008 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
Broken pins in monitor cable
cut the vga cable's port and take another one take continuity of every pin and joint this to the cable .Hope this solution works
Jul 25, 2008 | Gateway FPD2275W LCD Monitor
Dell P1500 Laser Printer: USB Port is Broken--plastic center peg broken off
If you mean the centre pin from the plug has broken off in the socket then use a tooth pick, dab a tiny bit of cyanoacrylate, (super glue) on one tip and push against the broken pin keeping steady for at least 20 seconds. Now, gently pull the pin out.
If the socket is broken, new board or repair shop.
May 19, 2017 | Office Equipment & Supplies
Controller port usb pins are bent
is it in the warrinty / do they cover it
Oct 20, 2007 | Microsoft Xbox 360 Console
165 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
