Question about Estate TEDS840JQ Electric Dryer
HOW DO I REPLACE THE BELT
How do i get to the belt
  • 5,911 Answers
Perform the following steps:
1. UNPLUG the dryer before servicing.
2. Open the dryer lint trap and remove the screen.
3. With the lint door open, remove the two screws under the lint screen door. Be carefully not to drop the screws down the ventilation duct.
4. With the screws removed, the top panel should pull towards you slightly than lift up. You may want to use some assistance in holding the top panel up.
5. Unplug the door latch connectors from inside the front panel. Remove any ground wires that may be attached to the front panel.
6. Locate and remove the screws that hold the front panel in place to the side panels. There are two of them (one on each side). Make sure you place your body against the panel as you loosen the screws to prevent it from falling.
7. With the screws removed, grasp the front panel at the top and lift up slightly to remove.
With the front panel out of the way, you should have plenty of access to replace the drive belt. If you require assistance in how to properly route the belt, go to repairclinic.com and click on the "Repair Help" link at the top of the page. On the following page, look for a "Dryer Belt Diagrams" link under the "Special Features" section. Scroll down until you find Estate. Use diagram H for your dryer.
To reinstall everything follow the above steps in the reverse order. Getting the front panel back in place can take some effort. The panel has two small square holes at the bottom on each side behind the panel. These holes holes need to line up correctly with the small black cleats on the front edge of each side panel in order for it go back into place. Make sure you reconnect all connector plug and ground wires. Do not forget to reinstall the screws under the lint screen door when the top panel is back in place. Once again, do not drop them down inside the vent ducting or you will have to remove the entire back panel to retrieve them. NOTE: Placing some tape over the vent opening will prevent this.
I hope this information is helpful to you. If you still have questions, please let me know.
PS For additional assistance you can, go to searspartsdirect.com for exploded view diagrams for you dryer. This may help you with assembly/disassembly.
Posted on Jan 07, 2009
  • 135 Answers
2 screws at bottom front, pull out slowly from bottom first. Remove the door switch wiring. Then you will see the rest. Note how the belt rides thru the pulley and onto the motor. Belt # 341241, available for $11.99 at timerking.com. Hope this helps!
I Have error code E000007 - 001 on Canon C9060 pro
Fixing belt full displacement error (Displacement
direction is unknown.)
Full displacement of the fixing belt was detected, but the
displacement direction (front, rear) was unknown.
1. Forgot to clear the counter at the fixing belt
replacement -> clear the counter
2. Check physical relationship between the fixing belt
position sensor 1, 2 (PS71, 72) and the sensor flag
A. In case that both sensors are blocked from light
A-1. Faulty fixing belt unit -> replace the fixing belt
unit
A-2. Faulty fixing belt displacement control drive ->
replace the displacement control drive assembly
B. In case that both sensors are not blocked from light
B-1. The connector on the fixing belt position
sensor 1, 2 (PS71, 72) is physically removed,
or the cable is disconnected -> connect the
connector, or replace the harness
B-2. Faulty fixing belt position sensor 1, 2 ->
replace the sensor
B-3. Faulty fixing belt unit -> replace the fixing belt
unit
B-4. Faulty fixing feed driver PCB -> replace teh
B-5. Connection error of drawer connector (J8023)
-> clean or replace drawer connector
B-6. Short-circuit or open-circuit of harness
between fixing feed driver and DC controller
PCB -> replace harness
Jan 02, 2018 | Canon Office Equipment & Supplies
Noise sounds like a belt, only makes it in park, neutral and drive
Squealing noises are either
* a worn or loose belt. replace the belt.
* an A/C belt idler bearing. Replace belt and idler.
* alternator bearing: replace the alternator.
* timing belt idler bearing(s). Replace the timing belt and all bearings (there's a full kit for this).
Oct 03, 2016 | 2005 Subaru Outback
How to change a belt on sewing machine
Google is your fried in such cases Mary :>) I can probably find you your manual if you give me the model number.
  • How to Replace a Sewing Machine Drive Belt - YouTube www.youtube.com/watch?v=8Voq7f5vT6E
    • BY SEARS PARTSDIRECT
    • 1 MIN
    • 23K VIEWS
    2015-04-23 · Video embedded · ... shows how to replace a broken drive belt in a sewing ... a broken drive belt in a sewing machine. ... to Replace a Sewing Machine Drive Belt
  • Brother Sewing Machine Diagram to Replace Belt ? ' Yahoo ... https://answers.yahoo.com/question/index?qid=20090426184749AAQ5W2y
    • RESOLVED
    • 4 POSTS
    • 3 TOTAL ANSWERS
    2009-04-26 · Best Answer: I am sure there are the diagrams you are looking for are online. ... After years of machine maintenance I would love to have a duplicate ...
  • Videos of how to change brother sewing machine belt bing.com/videos 2q==Click to view 43:10HD Brother PE770 repairs, motor belt.(Spanish Discription) YouTube zClick to view 1:00HD How to Replace a Sewing Machine Drive Belt YouTube 9k=Click to view 1:03:43 SINGER 95-1 BELT REPLACEMENT & RE-TIMING 081813 YouTube 2q==Click to view 1:42 How To Install Antique Singer Sewing Machine Belts YouTube See more videos of how to change brother sewing machine belt
  • Brother PE770 repairs, motor belt.(Spanish Discription ... www.youtube.com/watch?v=Cy-wNw8_kuU
    • BY VINCE J. ARCURI
    • 43 MIN
    • 25K VIEWS
    2013-05-19 · Video embedded · Brother PE770 repairs, motor belt. ... In this video I am showing how to access the machine's motor drive belt. ... Brother Sewing Machine ...
  • Can U Help Me Find A Diagram to Replace Sewing Machine ... https://answers.yahoo.com/question/index?qid=20090428210336AAvwslh
    • RESOLVED
    • 4 POSTS
    • 3 TOTAL ANSWERS
    2009-04-28 · Can U Help Me Find A Diagram to Replace Sewing Machine Belt ? ... I can get a Diagram that can show me how to replace a belt on a Brother Sewing Machine ...
  • Replace Belt ' Brother support.brother.com/g/b/faqend.aspx?c=eu_ot&lang=en&prod=mfcl8850... Replace Belt. Follow the steps ... Close the front cover of the machine. Reset the belt unit counter. Press (Settings). ... please contact Brother customer service:
  • How to Replace a Sewing Machine Belt ' eHow www.ehow.com > Crafts > Sewing & Textile Crafts > Sewing
    • BY RUTH O'NEIL
    How to Replace a Sewing Machine Belt ... When you smell this, you know it is time to change the belt. Changing a sewing machine belt is fairly easy; ...
  • Sewing Machine Belt Sizing - Sewing Parts Online ... www.sewingpartsonline.com > Home > Maintenance & Repair Home Maintenance & Repair Sewing Machine Belt Sizing. ... How to Replace Sewing Machine Gears December 5, 2010. How To Replace A Sewing Machine Motor May ...
  • Brother Sewing Machines and Accessories: Rubber Drive Belt https://www.brothermachines.com/sewing/491/Rubber_Drive_Belt Brother sewing machines, parts and accessories ... Brother Emb. Cards; ... Home Sewing Machine Rubber Drive Belt
  • Sewing Machine Belt - Sew-Classic shop.sew-classic.com/Belts_c3.htm Click here to download for FREE How to determine the correct belt size and how to adjust/install a sewing machine belt. ... Sewing machine motor belt ... Brother Elna ...
  • Sewing Machine Repair Tips: Change / Replace The Belt on a ... sewingmachinerepair.blogspot.com/2008/01/change-replace-belt-on... 2008-01-27 · Although it may initially look complicated to change the long leather belt on a ... brother sewing machines. April 27 ... cover over the belt on the sewing ...
  • http://www.bing.com/search?q=How+to+change+brother+sewing+machine+belt+&qs=n&form=QBRE&pq=how+to+change+brother+sewing+machine+belt+&sc=0-42&sp=-1&sk=&cvid=B1D6E61981414EB7A56CB3A4C0D371A3
    Jun 18, 2016 | Brother Sewing Machines
    1992. How do I replace fan belt? fan belt
    There is a spring loaded belt tensioner. Use the appropriate tool to release the tension on the belt Remove the belt , paying attention to the belt routing and replace the old belt with the new belt.
    Oct 13, 2015 | Ford Explorer Cars & Trucks
    If I replace timing belt 97 quest van do I need to replace camshaft belt tensioner
    any time a vehicle has a hydraulic tensioner it should be replaced. most parts stores have a timing belt replacement kit. some have the idler pullies and the tensioner and belt. you should replace the water pump while you are in their.
    Sep 08, 2014 | Vehicle Parts & Accessories
    My printer can`t print and shows me to 'Check the transfer belt'
    Your printer monitors the life of your transfer belt. When the transfer belt reaches the end of its
    life, the printer displays
    80 Belt Exhausted. This message indicates it is time for you to
    replace the transfer belt. For best print quality, make sure you replace the transfer belt when
    80 Belt Life Warning.
    Press
    Go to clear the message. The Supplies message appears on the second line of the
    display to remind you that supplies need attention. You can open the Supplies Menu to see
    80 Belt Exhausted
    or 80 Belt Life Warning messages.
    The printer continues to display the
    Supplies message until you replace the transfer belt. To
    replace the transfer belt, use the following steps or the instruction sheet supplied with the
    transfer belt.
    Nov 26, 2012 | Samsung CLP-610 Series
    How do you replace timing belt
    no.
    Below is the master help link provided to go through belt routing diagram:---Timing belt, drive belt, serpentine belt, accessory belt, fan belt, engine belt routing diagrams for all types of car models?
    Click the link below: ----
    http://carbeltrouting.blogspot.in/2012/02/timing-beltdrive-beltserpentine.html
    ----------This will help. Thanks.
    Feb 01, 2012 | 1996 Volvo 960
    Squeaky noise from serpentine belt
    Replace the serpentine belt tensioner. Expect to pay approx $150.00 if installed by a mechanic.
    Dec 28, 2008 | 2003 Toyota Corolla
    Kirby g4 belt replacement
    Facing vacuum,turn belt lifter knob counterclockwise till it stops.Lift headlight hood,and unlatch brushead,and remove.Looking thru the hole in back,turn belt lifter knob clockwise to release belt.Remove bottom plate,and bend one end of bracket to remove end of brush roll.Slip new belt on and replace brushroll back into bracket,and replace bottom rug plate.Looking thru hole in back,turn belt lifter knob until the hook inside picks up belt.Replace brushead,and again,turn belt lifter knob clockwise to drop belt onto shaft.
    Dec 18, 2008 | Vacuums
    Estate TEDS840JQ Electric Dryer Logo
    103 people viewed this question
    Top Estate Dryers Experts
    Dan Webster
    Dan Webster
    Tim Whalen
    Terry Schneider
    Are you an Estate Dryer Expert? Answer questions, earn points and help others
