Question about RCA F36673ET 36" TV
RCA f32672sb without original remote and need to change inputs
Have tried the 91/92 thing, have tried the menu, have tried everything and can't seem to change the input on my tv to allow the dvd/vcr combo to work. Screen says "Unusable signal" at the bottom and "Video 00" at the top.
  • dhamlin11jgr May 23, 2009
    Okay, this is really frustrating that a TV with an input function cannot be switched to that mode with the TV buttons itself, i tried every channel function, but it won't allow the 00 to display via the CH+/- buttons in the setup menu. I've tried programming the universal Comcast remote that goes with the cable box I have, but those codes do not work and the code searching action for it does not work either. I've been searching for well over an hour for a solution to this problem, a code, another action with the Comcast remote, anything, but have uncovered nothing. HELP, please!
  • 46 Answers
SOURCE: RCA TV - Trying to hookup new dvd/vcr player to old tv with only antenna input
The input on your television is probably coaxial (for cable or an antenna) which means it needs an RF modulated signal. You can find one of those at your local department or electronics stores. Just look for an "RF Modulator" or "video-RF convertor." They're most commonly used to hook video games up to older televisions.
Now, if you've got an old VCR handy, that has an external input, it already has the RF modulator built-in.
Posted on Nov 08, 2007
SOURCE: how do i get to the input/video screen on the RCA F32672sb 32
If you have an old vcr hook the dvd player to the inputs on back of the vcr (RCA jacks) Run a coax cable from the "out" on the vcr to the back of tv. Turn the tv on channel 4 or 3 then put a tape in the vcr and push record then pause it. Or if the vcr has a tv/video button you can push or activate it and it should allow the dvd to play through to the tv.
Posted on Feb 10, 2009
  • 48 Answers
SOURCE: unusable signal prompt on video input
be sure to cycle thru the input selections-- either w/Remote (input button), or channel +/- on the panel. my truflat 26" hd set has side/front/video1 video2 inputs, yours may have more or less. also, be sure you've plugged into an INPUT set, not an OUTPUT set. Does sound work otherwise on this set? If not, maybe interal speakers (menu setting) is set to off/not checked.
And on your PS3--goto the settings menu, sound outputs, make sure you select A/V connector and analog sound. The ps3 cable can become sloppy too, wiggle/check/reseat or try another cabe (usually video is touchy more than the sound though)
If you KNOW you've got the right input selected and the PS3 is setup properly, do you have another device with audio output to test on the TV? a notebook computer, walkman, cd player--anything that has rca outputs for sound--quick swap the cables to the new 'test' device-- if sound is OK with test device, either PS3 setting or cable is bad/wrong. if no sound from test device on TV either the tv is not using proper inputs, or is damaged, or the test device is not properly configured. If you have another input receiving device to test the ps3 output sound, like the LINE INPUT on a notebook computer, or a boombox with Aux inputs, test the PS3 sound output too.
Posted on Mar 14, 2009
  • 36 Answers
SOURCE: In my old Rca The chanels don change I want input
this sounds like a cold solder joint problem.. around the tuner, you need to unplug the tv and take the back off the set .remove chassis and turn it upside down ... take a magnifing glass and ckeck the curcuit board for broken or dull solder joints the resolder them.... this should solve your problem good luck
Posted on Dec 23, 2009
SOURCE: Input Selection without a Remote
On either the front of the TV or a universal remote (which I assume you have already programmed) hit the MENU button. Go to option 4 "Channel". Go down to "List and Labels." Hit the CH up or down key until you see "FRNT" come up under the channel # heading. If your DVD is connected and playing, you'll see it playing now. Exit the menu to watch. You'll have to reverse the process to get back to watching TV, but there doesn't seem to be any way around this if you don't have your RCA remote. This process is guaranteed to work on an F27442 and will probably work on some other RCA models.
Posted on Mar 11, 2012
I have a RCA tv in our rv connected to Dish Network. What are the channels and input for the rca tv? The model is L32HD41
Try ch 3 and sat or cable input on tv. use menu on original tv remote to set input as sat or cable.. then use dish remote for all other changes.
May 15, 2017 | RCA Televison & Video
Rca l32wd22
You can't select its input selection without a remote control. Should have its original remote control. No universal remote control will go. Contact the authorized service center for RCA to buy an orginal one.
Dec 03, 2013 | Televison & Video
I have a Toshiba 24af42 with no remote. I am trying to change the input, but without a remote I cannot figure out how to change it. I have tried a universal remote which works for other functions, but not...
Try this website 1-800-remotes Factory original u can buy an original remote,tries Channels up or down couple times u should get in the input 1 or 2.
Oct 22, 2009 | Toshiba 24AF42 24" TV
New remote won't program to switch to cable input.
That's a problem with universal remote controls. Often they don't control every function of the TV. They just don't have the buttons needed to control everything the original remote did. You'll have the most basic controls - power, channel and volume up and down - and maybe a menu button. But you'll frequently find other things don't work, like switching inputs. There isn't anything you can do except try all the codes for your TV brand and see what each button does. You might find that the buttons have different functions depending on which code you've entered. You might also look for another brand of universal remote that has more functions available.
May 23, 2009 | Daewoo Televison & Video
I usually play video games on the rca 14 inch true flat tv but my remote broke that they gave me so i cant go to input to play video games. Do i need a new remote for that or can you do it a diffrent way...
Unless the set has front panel menu buttons and the on-screen menu allows you to select the source, the answer is "no, you can't switch without the remote". If the original remote is really broken, you may be able to use an RCA-brand universal replacement that has an "input" or "source" button. Unless the original is physically damaged, before you toss it check the battery contacts inside. They sometimes get loose from handling the remote a lot and don't make good connections. Also make sure the new batteries are fresh and facing the right way.
Apr 09, 2009 | RCA 14F512T 14" TV
Can't select front input without remote
I had the same problem, had a universal DirecTV remote that was able to control the volume/mute, power and channels (both TV and DirecTV), but the input button didn't work. There was no av/tv button on the front of the tv, and the autoregistration of channels didn't pickup the gamecube on the AV channel. What solved it was simply to press "00". I couldn't believe it, but it was that simple. Hope this helps you like it helped me, since the tv was not going to be of much use since we were using the RCA inputs, not the coax. Didn't want to try to conver the RCA to coax either.
Apr 04, 2009 | RCA F27440 27" TV
Need remote for rca dvd
try putting batteries in it. It nothing comes on - you don't have any power or the thing is broken
Mar 18, 2009 | RCA 3-Device Universal Remote with...
How does one change the video inputs without the remote control?
If you have lost the remote, go to any electronics store and buy a universal one. I have programmed many generic remote controls, and they all work fine for adjusting the video inputs. Not all television sets allow their video inputs to be switched without the remote. Most likely you will have to buy a replacement.
Jan 08, 2009 | RCA Scenium L50000 Television
Hooking up & seeing a dvd player?
does the dvd have a coax output for coax antenna input on the tv? you can use that untill you can get the video input selection straight with the tv and a remote that supports rca's extra functions such as menu , tv/av button
or
also if there is a( wake-up) on/off timer in the tv menu , then you can also set it to come on with the video input instead of a tv station,set it a few minutes after the time it is when you set it( then just turn off the tv set after the time is set and you have exited the menu, then it will come on with the video input instead of a tv station)
otherwise you will need that remote that supports the video input selection on your tv
Jan 08, 2009 | RCA F20625 20" TV
No Video
From the manual (search Google for CM27101S): Normally, your TV displays the signal coming through the antenna terminal. However, If you?ve connected another component to your TV(such as a VCR) using the Video/Audio input, you will want to be able to view the signal from the component. To do this, you will need to switch from the ? TV ? input to the ? Line1, Line2 ? Input, as follows: 1 With the TV on, press the MENU button twice, then ? Set-Up ? menu will appear. 2 Use the WCHVbuttons to select ? Input ?. 3 Press the CVOLB buttons to change from ? TV ? to ? Line1, Line 2 ?. 4 Wait 10 seconds, or press the MENU button to return to normal TV viewing.
Aug 07, 2006 | RCA F27676BC TV
Televison & Video Logo
155 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
