Question about Maytag PER5705 Performa Electric Kitchen Range
How Do I Use Self Clean Oven Feature?
My husband was our cook, and he passed away last fall. I can't find the owener's manual and can't figure out how to use the self cleaning feature on my oven. When I press "CLEAN", it beeps at me twice. I don't see a manual lock for the door. I'm not even sure it's a PER5705, but it is is a Maytag Performa, electric with a smooth rangetop (no exposed burners), stainless steel/black, with a storage drawer under the oven. Can anybody help a frustrated widow who's lost in the kitchen - with a dirty oven?? Thanks in advance.
  • 1 more comment
  • Kathy Vanchieri May 30, 2007
    I can only find one setting that says CLEAN. Thanks for trying.
  • Anonymous Mar 22, 2014
    I try to start oven clean get message that says door
  • Anonymous Mar 25, 2014
    The rangetop burners all of a sudden started clicking and sparking for no reason and won't stop. We turned the power off for the last 30 hours but it continues. I've used a paper clip to make sure the hole below the igintors are clean, etc. What do I do - is it something I can fix myself?
Kathy - we just figured ours out!! Hit the clean buttton, will light up With "cl n", hit 2nd time and it will start the cleaning. Ours set for 4 hrs! Good luck!! This is for the maytag performance!
Posted on Jun 10, 2007
  • Jennifer Allen Jun 10, 2007
    Sorry, it deleted part of my solution!! Hit the clean button, then hit the "more +" button, will light up "cl n", if you hit more a second time, it will lock on the longest cleaning session...which is four hours! Our is cleaning as I type! Good Luck!!!!
Hi
I came hear to find solution mine is still a little different. 1) Lock door, 2)Hit clean, 3) press the cook and hold button, 4)then the timer up button, and it will set itself for 4 hours. good luck.
Posted on Aug 17, 2008
  • 883 Answers
Look for a second dial setting with the word CLEAN also. i have to use 2 controls (mine is not Maytag, though)in order to start the clean cycle
Posted on May 29, 2007
  • Marty marty May 31, 2007
    also, the second control on mine instructs me to set the temperature on full high (500 degrees)...
When I try to turn on my GE oven, the “auto self-clean” light lights up. I am trying to turn on my stove to 350 to cook a small roast.
Disconnect for the mains for 5 minutes to reset the Self Clean feature. BTW, NEVER use the self clean feature, they burn out elements and cause all sorts of problems.
Sep 02, 2018 | GE Kitchen Ranges
How do I set the automatic clean on a Siemens Pyrolytic Oven SS that was bought in Australia 5.5 years ago? Oven code is HB76AU560A. Thank you.
i've never worked on your brand name stove but i want to tell you don't self clean it until after the holidays,when you self clean an oven it gets up to 1000 degrees,the heat can damage the electronics in the oven,if it does and you need a part ordered you won't have an oven to cook with for the holidays,after what i've seen i will never self clean my oven again with the self clean feature i use easy off just as good.hope this helps you out and merry christmas
Dec 20, 2017 | Siemens Ovens
RBS305 replaced thermal cutoff twice and again it won't come on bake or broil
Good Evening!
The self clean feature is causing your thermal fuses to fail or open. This is a safety mechanism that when open (bad) won't allow electricity to pass through any longer. The temperature in your oven exceeds what the components in your appliance can handle. If you want your oven to last it's longest, I would discontinue using that feature. If ever the control board or keypad on your oven by way of the self clean feature, we can help you with that. Fixyourboard.com can help. Send all inquiries to info@fixyourboard.com . Thank you!
Jun 05, 2017 | Whirlpool RBS305PD Electric Single Oven
I have a Magic Chef self-cleaning oven. The lock lever broke as I was trying to open the oven door after the self-cleaning cycle was finished; Any suggestions for getting the oven door opened? And if I am...
I had the same prob. Just today I figured it out. My husband tried for a hour the other day and it just took me 30. Min. Lift up the burnner part. You will have to unscrew a cover that sticks up on the front part. Open that section and this is what I done. I beat it with a hammer to ser it it worked, but no. I played with it then I took a screw out on the lever and wool
Jul 24, 2011 | Ovens
How do I get the door open after self cleaning and what do I push to self cleaning
Hi, Some ovens are self cleaning During the cleaning process, the oven heats up to a temperature of 900 degrees Fahrenheit. The extreme heat cooks off food and spills inside the oven, leaving ash that can easily be wiped out. The oven door locks while it is cleaning to prevent the door from being opened. Self cleaning ovens are better insulated than regular ovens to keep the extreme heat inside.
Instructions
Read the owner's manual that came with your oven before you perform self cleaning. Although all self cleaning ovens work basically the same way, there may be slight variations for some manufacturers and models.
Take out the oven racks. You need to clean the oven racks by hand, and then put them back in when the oven is done cleaning.
Wipe up any spills and messes inside the oven first, using warm water and a mild soap. Ovens smoke more during cleaning when there is food inside. Wash the inside of the oven door as well. Do not scrub the door gaskets, just gently wipe them off. Damaging the gaskets prevents the oven from sealing.
Lock your oven door manually if your model does not lock it automatically when you clean.
Open a window near the oven for ventilation. There is a certain amount of smoke when you clean the oven. The dirtier the oven is, the more smoke is created.
Turn the control on your oven to "clean" and set the timer for 2 to 5 hours depending on how dirty your oven is, and what the manufacturer recommends.
Wait for the cleaning to finish and the oven to cool before opening door. When oven is fully cooled wipe up any ash inside. If your oven is not completely clean, next time set the timer for longer. If your oven is spotless you might want to see if you can get away with a shorter cleaning time.
Tips & Warnings
Because self cleaning ovens are better insulated, they are more energy efficient when used for cooking. However, if you run the self cleaning feature on your oven more than once a month, you offset the savings you realized. With light to moderate use your oven should be able to be cleaned every one to three months.
Save on the electricity used with a self cleaning oven by cleaning the oven right after use at a high temperature. For example, if you set your oven to clean after making French fries at 450 degrees, it takes less energy to get the oven up to the required 900 degrees.
If you have pet birds, take them out of the house before cleaning your oven. Over heated cooking surfaces, oils and fats, can create fumes that are harmful for a bird's delicate respiratory system.
Hope it helped.
May 28, 2011 | Ovens
Linking F3 when trying to turn on the oven
While using the self clean feature you burned out the oven temp sensor.
Replace the oven temp sensor.
Do not use self clean on any oven unless you want to replace parts,
Feb 24, 2009 | Kenmore 30172 / 30174 / 30179 Gas Single...
Need to activater self-clean
Every self-cleaning oven is different. It's best to consult the owner's manual for the correct procedure for your oven. But often the steps are:
  1. Set the Start time for the time you want the cleaning to begin.
  2. Set the Stop time to a time 2-3 hours after the start time.
  3. Close and latch the oven door.
  4. Set the selector switch and/or thermostat to "Clean."
Jan 09, 2009 | Farberware FAC900R Toaster Oven with...
Self-Clean gets too hot on JTP56 double-oven
Your husband is correct, kind of. You should not try self clean again until you get the oven repaired. You have a temp sensor going out. I doubt that the oven actually got too hot, most likely the resistor in the sensor is failing as it heats up and giving a false temp reading.Since the lower oven was operating at the time, it is probably the sensor in the lower oven. Don't use it for baking until you get it repaired. It will go out completely and shut down both ovens. You should be able to get a new sensor for around $30 and they are not hard to replace.
The oven won't set your house on fire during clean mode if the cabinets were built with the correct air space and dimensions, but they do get very hot, about 800 degrees F. Most ovens give no trouble during the clean cycle, but if there is any weak components in the electronics system it will show up then. It will give you less trouble over time if you don't use the self clean mode and just manually clean it.
Jan 18, 2008 | GE Profile JTP56 Electric Double Oven
Self cleaning oven
http://www.frigidaire.com/support/Result... just need to identify exactly which model you have and download your manual. May your burners be eternally clean Hope this helps :)
Mar 14, 2007 | Frigidaire FEF366EC 30" Freestanding...
Maytag PER5705 Performa Electric Kitchen Range Logo
549 people viewed this question
Top Maytag Kitchen Ranges Experts
vince
gbob59
freddyfox
Are you a Maytag Kitchen Range Expert? Answer questions, earn points and help others
