Question about Tools & Hardware - Others
New DeWalt DW735 planner not pulling wood through machine
I have a brand new planner. My first project is recycling some 100 year old oak boards that were a table top. The planner started out fine but after I have taken off just about all the varnish / old finish, the feed rollers seem to be slipping. This is only a guess on my part as this is my first planner. Do the rollers need to be cleaned due to the old varnish or finish? What do I use to clean the rollers with? Will I need to disassemble the unit to do this?
  • geofrapkoch Apr 19, 2009
    I have a 4 year old 3 blade Dewalt planner can the rollers wear out as boards seem to hang up when planning hard woods such as walnut
Just wax the table and support tables, and clean the feed rollers with mineral spirits. I have a 20" 5hp planer and it will stop feeding if i don't keep the table waxed. They sell planer table wax, but I find that a good paste floor wax works just as well. DO NOT use WD40,it will prevent finish from bonding.
Posted on Aug 15, 2010
    President:
  • 2,692 Answers
Planers were not designed to remove old finish, They were designed to plane new lumber which would be much softer., so likely the need for cleaning seems reasonable. I woudl think a wire brush on the serations of the feed rolers woudl serfice.
Posted on Jan 18, 2009
Planner just stop running.power @ outlet.
It may have overheated. See if there is a reset button on the motor after it has cooled off.
Oct 11, 2015 | Dewalt DW735 13 Inch 2 Speed Planer With 3...
My dewalt planer dw735 just made a loud pop sound. Then, a piece of metal launched out of the dust ejector, a few sparks flew. I tool the top od and found a hunk of wood that broke of the board jamming the...
have you checked you have not taken a chunk out your blade. also you have to make sure the blades are set spot on. other wise it will affect the balance. good kuck
Dec 20, 2014 | Dewalt DW735 13 Inch 2 Speed Planer With 3...
Replace v belt on dw735 planer
REMOVE COVER SO YOU CAN SEE THE BELT, PULL THE BELT AS YOU TURN IT AND IT SHOULD COME OFF
Nov 07, 2014 | Dewalt DW735 13 Inch 2 Speed Planer With 3...
My planner won't draw the wood thru my planner.
check that blade is correct and guides correct
Mar 20, 2014 | Dewalt Planer (DW734)
Feed extremly hard to push board thru
my be you planning to much wood at once or the cutter is dull
Mar 15, 2014 | Dewalt Planer (DW734)
Plainer won't adjust up and down
Wood chips are probably jamming the height adjustment, and need to be cleaned out. Lubricate the machine once it's clean.
Feb 01, 2014 | Dewalt DW735 13-Inch Two Speed Thickness...
Dw735 planner thickness
Is it cold in your shop? The rollers won't work if they're cold because the rubber gets stiff. Clean your rollers also with mineral spirits. Hope that helps.
Jul 11, 2013 | Dewalt DW735 13 Inch 2 Speed Planer With 3...
Cutting 19mm oak veneered mdf with my new 28v
check to see if u can increase the speed, or try on a thinner piece of wood. or even try a new blade with more teeth.
Aug 13, 2009 | Dewalt DWS520SK Track Saw Kit with Short...
Tools & Hardware - Others Logo
1,268 people viewed this question
Top Tools & Hardware - Others Experts
J.D. Browning
J.D. Browning
Are you a Tool and Hardware - Other Expert? Answer questions, earn points and help others
