Question about Kenmore Washing Machines
How do you get the pump off kenmore washer 110.24086200
The pump will not pump the water out of the washer pump is runing how do you get the water pump off the macnine
Pry the two clips on the sides off, and it should slide right off.
Posted on Jan 07, 2009
The dish washer runs but does not pump the water out sounds like the pump is runing and nothing seems to be plugged
Dec 31, 2009 | Bosch 24 in. SHU43 Built-in Dishwasher
Machine empties water of the wash and rinse cycles all over the floor-no crack in the drain pipe - no sign of leakage in the drain hose attatched to the washer
Most likely have a bad water pump. If not you have a bad tub seal. Just hope it's the water pump. It's located just under the front. It's white and has either 2 or 3 hoses coming from it. Some models have 2 some have 3. No problem to replace and cost around $40.00. Good luck
Nov 17, 2009 | Kenmore Washing Machines
Leaks out when it is filling.
Make sure the drain hose is higher than the top of the washer tub.
Sep 21, 2009 | Kenmore 24032\24036 Top Load Washer
Describe your Kenmore 24032 \ 24036 Top Load
Hi, When the washer is set for cold water only, can you hear the inlet valve humming? Remove the fill hose from the inlet valve and look inside the valve to see if anything in plugging the screen. If the screen is open or the valve doesn't hum when there is power to it, the valve is most likely bad.
Please let me know if this helps you or if I can assist you further.
Thanks
Vic
Jul 17, 2009 | Kenmore 24032\24036 Top Load Washer
My Kenmore washer makes a whining noise while pumping water
This is caused by the pump. Replace or clean out the pump.
Feb 01, 2009 | Kenmore 24032\24036 Top Load Washer
Not spinning changed clutch
It is not suppose to work on the first time because it hasa spin pawl which allows the transmission to not spin while the washer pumps out the water. It is called a neutral pac tranny. from what you descibe it is a timer problem if anything at all.
Jan 31, 2009 | Kenmore 22422 Top Load Washer
WILL NOT CYCLE FROM WASH TO RINSE
You have to check your filter for any block. Then put in some water & try to spin it out; if the water does not flow out easily you have to look into your pump, could be a block in there. Refer to user's manual.
Feb 13, 2008 | Kenmore 43052 Front Load Washer
Washer filled with water & then stopped & will not work in any cycle.
could be a bad pressure switch did it fill all the way is it a top loader or front loader any noise or nothing
Dec 31, 2007 | Kenmore 24622 Top Load Washer
HELP!!!!!!
Before spinning, washer draining water aut & than start spinning,,,,if motor runing without drainig water, chek the belt, if belt is OK,and runing pupm, chek the pump,,,,disconnect hoses and clean pump... if washer do not draining & spinning, replase lid switch..... If you need instruction how to replace lid switch, i will post you instruktion....
Sep 01, 2007 | Maytag Performa PAV2200
Washing Machines Logo
76 people viewed this question
Sal De
fordexpert
Robert Rankin
