InFocus X2 Projector Logo
A
Anonymous Posted on Nov 14, 2012
Mancha escura lado direito da tela projector infocus x2
5 Related Answers
A
Anonymous
  • Posted on Dec 30, 2007
SOURCE: infocus x2 dose nothing
Assuming the power outlet and cable is OK the most likely problem is the power supply and needs to be replaced.
fpreston
  • 7 Answers
  • Posted on Nov 05, 2008
SOURCE: X2 board
I have ballast problems with several X2 X3 projectors and even a C180 (Proxima) although with different ballast power layout. My X2 units mostly seem to have blown a pair of output FETs (2SK3568), but that is only part of the problem. One unit powers up, but just won't strike the lamp. Installing a good ballast power supply board fixes the problem, but I can't find any place to buy or repair these without sending the whole projector in for repair.
Perhaps it is time to trace out the schematic of these boards and have someone start repairing them at big profits.
projdoc
jasbo
  • 2239 Answers
  • Posted on Jun 04, 2009
SOURCE: Ballast
you have to go to an infocus authorized service center. you may be able to purchase it from them without having them put it in. check the infocus website for an asc. but for reference, the part # for the ballast/power supply is 520-0126-00 if there is a "0" in the 5th to last position in the serial #, and 520-0143-00 if it's an "a" in the 5th to last position.
projdoc
jasbo
  • 2239 Answers
  • Posted on Sep 04, 2009
SOURCE: Infocus projector power supply dead
the caps dry out. look for bulging caps. you won't find a schematic for the ps boards. infocus had someone else make them. the problem seems more like a overheating issue. as for the other one with the "just the fans", check the colorwheel.
projdoc
jasbo
  • 2239 Answers
  • Posted on Jan 29, 2010
SOURCE: I have an infocus X2 projector that has a shadow
the light tunnel has collapsed and needs to be replaced. it's pretty simple to repair. there are directions on the "tips" part of my profile. so, you can get the part from an infocus service center and do it yourself or send it in to them for repair. either way, try www.avsolutionsny.com. they're really good.
1helpful
COMO RESOLVER ,POIS O MONITOR NAO LIGA?
Oi Anonymous, Verifique a ficha n?o est? solto no monitor eo computador .... e se nada solto em seguida, O link abaixo ? um v?deo do YouTube mostrando como corrigir tela preta, tamb?m h? v?deos para o lado direito do link que voc? pode considerar a pena olhar, bem como, infelizmente, o link est? em Ingl?s ..... espero que isso ajude ... .CHEERS ..
How to FIX Windows 10 8 7 Black Screen of ***** With Cursor After Login...
Tela escura
Google for the service manual, should be available online for free, the G2 voltage should come from the D board where the high voltage circuit is.
Como tirar apenas um lado da folha?
Para imprimir dois lados documentos utilizando o software Lexmark, por favor siga os passos abaixo:
  1. Com o arquivo aberto, clique em Arquivo> Imprimir.
  2. Na caixa de diálogo Imprimir, clique no botão Propriedades, Preferências, Opções ou Configurar (dependendo do programa).
  3. A partir da guia Layout de impressão, selecione o layout e as configurações de duplex para o tipo de documento que pretende imprimir.
  4. Depois de ter aplicado todas as configurações desejadas nas Propriedades de impressão, clique em OK na parte inferior da tela para retornar à caixa de diálogo Imprimir.
  5. Clique em Imprimir para concluir a tarefa.
Nota: Esta é traduzido usando translate.google.com.
How do you remove the "Top Cover" off the InFocus
Michael,en la parte de abajo del lado dellente tiene un tornillo que tienes que quitar y tambien tienes que quitar la tapa de la parte de atras,del mismo lado donde esta el lente tienes que levantar la tapa porque tiene seguros,antes de levantar la tapa desconecta el cable que va hacia los botones de menu,source y reser para que te sea mas facil. espero que esto te ayude . Atte.Rivas.
PS3 to Infocus LP 350 projector using HDMI
M1-DA is a type of DVI connection that produces both analogue and digital signals, the easiest and most quality source cable for you to get is a HDMI to M1-DA cable which is now widely available for purchase.
Infocus should have included this cable in with your projector, but instead the power at bee decided to put a M1-DA to DVI-D cable instead when most visual devices now support HDMI and not DVI nowadays.
Thanks
Doest function.no image projection,fun does not function
fuse on ac filter board. if that's ok, there is a power supply issue.
3answers
Infocus x2
first try another computer cable. if same results, press the "auto image" button on the projector. if that doesn't work, press menu, select settings, then factory reset, and "yes". if you still have the same problem, the eca (main board) is bad.
Infocus x2 dose nothing
Top InFocus Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
ZJ Limited
ZJ Limited
matt martin
matt martin
Are you an InFocus Office Equipment and Supply Expert? Answer questions, earn points and help others
