Question about Dryers
GE Gas Dryer wont run
The dryer has been squeeking for a few weeks but other than that running fine. After drying two loads today it sudenly stopped working. Power is ok, the light is on when I open the door and when I attempt to turn the knob to "start" there is a slight buzzing that makes it sound like it wants to start but doesn't.
  • 334 Answers
You had a loose belt. Now you have a broken belt. You can buy a new belt at most hardware stores including Lowes & HD.
They are fairly easy if you are handy.
Remove cover, look for diagram showing belt alighnment (if equiped, some are so simple they don't need one) remove shredded belt and install new.
Dont forget to unplug it first.
Posted on Jan 07, 2009
GE dryer is not working. a few weeks ago the spinning slowed and it sounded like the drum(?) was too heavy and grinding and then it just stopped spinning -my husband said that the three bath mats were...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The
Dryer is not Turning
Dryer Repair - The
heatman101
Jan 17, 2011 | GE DCVH515EFWW Electric Dryer
I have a Kenmore 700 series dryer. It has been making squealing noises as it runs for the past few weeks. Today I turned it on and it worked for awhile. I put in a new load to dry it started working and...
Many dryers use rollers or wheels to support the clothes drum. When these rollers are worn, they can be noisy. You should replace the whole set of rollers at the same time.
Jan 09, 2011 | Dryers
Dryer is squeeking and does not tumble on heavy loads
It sounds like the belt is gone....
Also check out this tip about your problem...
http://www.fixya.com/support/r4416566-dryer_repair_squeaks_grinding_clicking
heatman101
Mar 28, 2010 | Frigidaire Dryers
Taking a ge dryer apart to replace worn belt. the dryer works fine with light load but squeeks with medium to heavy load. drying time is fine.
you will need to replace the drum glides near the front of the drum,just behind the door,which will require you to remove the front panel to access the glide unit,there is a gold and a green glide,you will need to get the right one after disassembly
Jan 12, 2010 | GE DWSR483EBWW Electric Dryer
My GE gas dryer makes a loud squeeking noise running
WE 3X 75 is the part number you need. Take a look at these repair pix
Sep 09, 2009 | GE Dryers
Whirlpool Imperial Electric Dryer wont heat up
Check the following to address this issue.
1. No power to the dryer
Make sure there's power getting to the dryer. Check for tripped circuit breakers or blown fuses. An electric dryer uses two circuit breakers or fuses, and if only one of two is tripped or blown, the dryer might still run but not heat. Sometimes the power cord disconnects or burns at the dryer, if this is the case, the wiring and the terminal block must be repaired or replaced.
2. Heating element
A burned out heating element will show no continuity when measured with a meter. Replace the element if found defective.
3. Thermal fuse
Most dryers have a thermal fuse, which burns out when the dryer overheats, in which case the dryer will either not run at all or stop heating. The fuse is usually located on the vent duct, inside the dryer. A blown fuse will show no continuity when measured with a meter. Before replacing the fuse, make sure the blower wheel is not broken or clogged, and there is nothing blocking the venting.
Jul 22, 2009 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
No heat after drying several loads
the vent in your house may be stop up in the wall.
Jun 15, 2009 | LG DLG3788W Gas Dryer
GE Profile Gas Dryer - Heat goes on and off
The operating coils get hot and quit. They only cost 20 bucks. Read more about it here:
Gas dryer works then quits then works some more
Mar 31, 2009 | KitchenAid KGYS850LT Gas Dryer
My GE Dryer model DWSR483EA1ww will not stop & doesn't dry quick
first thing you should do is check the flow of your vent, a clogged vent can cause all your problems check it outside while the unit is running you should get really good flow compare it to the flow of the dryer with the vent hose off the dryer completly. they should be fairly close or just run it with out the vent hooked up to the vent if you have an electric but not with a gas dryer
Mar 09, 2009 | GE DWSR483EBWW Electric Dryer
GE DBXR463GB Gas Dryer is squeaking loudly when it runs
one of 2 things can be wrong. Back bearing if bad will sound like a bird chirpping, front bearing glide will be more constant squeek. both need to be fixed by experienced tech.
Jan 05, 2008 | Dryers
Dryers Logo
70 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
