Question about Tannoy Revolution R3 Main / Stereo Speaker
How can i know the original of the tannoy r3 bass driver
Could you give me some pictures in detail(picture in front and back of bass driver)of bass drivers of tannoy r3. how can i find that is the original or false. thank you very much i am waiting your reply soon
How do you take speaker apart front or back ?original 501 a series no visible screws seen.
Derrick, not all cabinet speakers were meant to be replace, not saying it can not be done, but they could be epoxied in.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Mar 19, 2016 | Tannoy Reveal 5A Speaker
I have a Fender Precision Bass Guitar serial #503122. I'm curious about its age and value? It is in excellent condition.
this should be a 1960 bass and there was 18,000 of them made so it is not rare but the questions that must be asked to put it in the rare category is the bass 100% original = this means everything /pots /pickups /tuners /frets /finish and then the overall functioning of the parts EX. bent tuner that turns restricted causing tuning problems / pots that cut out / input jack that's screwed up / buzzing or severely worn frets /and or fret board wear /worn finish on the body/neck so you must go down the list of everything to come to the overall condition of your bass then you can grade it by it's condition and then see where the basses category is (PRISTINE) =never used still tags & case (fine) = slightly used tags & case (excellent)= used but no finish chips scratches everything original & working so you get the picture I am curious about this because most players know there basses very well so this tells me that you have acquired this bass recently or that it belonged to a family member? and was passed down to you post back with more info/pictures of the bass I'd like to see it Stephen
Sep 30, 2014 | Fender American Precision Bass
I dropped my caplio r3 and need to find a similar camera to replace it with. Any suggestions?
Crickets, as with other insects, have compound eyes which do not contain pupils. You are going to be very disappointed if you are seeking a camera to photograph that which does not exist.
Aug 27, 2017 | Ricoh Caplio R3 Digital Camera
Hi, I am looking for a replacement bass cone for a pair of Tannoy 611's mk1's. I had them from new in the early 90's but a few years back, my son picked out all of the foam that joins the plastic cone to...
If you found second hand 605s you can swap entire sub speaker. Your other option is check your local yellow pages for a pro audio repair shop that does re-coning. Re-coning is a specialty operation and it's not a procedure for the novice. You can also check online for re-coning services.
Jan 06, 2011 | Audio Players & Recorders
New Yamaha AV Receiver and Tannoy Speakers muffled weak bass only
Maybe some wire is faulty... Try to disconnect everything and connect each speaker one by one, first trying only radio tuner and then trying to connect the TV and other devices. Using that you can isolate the fault into the specific component/wire.
May 26, 2010 | Yamaha Rx-v365 A/V Home Theater Receiver
Wiring schematic for YahamaR2X200F fretless bass
http://www.sonfatherguitars.com/Schematics/P-Bass.GIF
this is a seymore duncan wiring diagram. its standard bass wiring, and by the looks of the picture it should be close. luckily, most electrical manufacturers use universal wiring color codes.
yostamplifier.com
Mar 25, 2009 | Yamaha BB414 Bass Guitar
Tannoy Saturn s10 Dual concentric problem
tannoy dc speakers are built to very high tolerances. they are very easy to damage if taken apart so i suggest you contact a specialist tannoy service shop.
i know a shop in london who sells a lot of
vintage tannoy speakers and he says very few repair shops are capable of fixing these dc drivers. good luck
Apr 19, 2008 | Audio Players & Recorders
No signal on subwoofer out in Onkyo TX-SR703(E) - similar to TX-SR803
Hey Tad, I have the same problem and perhaps a solution. I just moved to the other SW "pre-out" and it seems to be working..the green light is on . Whatever works i guess.
Jan 24, 2008 | Onkyo TX-SR703 Receiver
Manual for Ricoh Capital R3 7.1 X optical wide zoom 5.0 mega pixels
I have a Ricoh r3, but everytime i take a picture using the flash the pictures come dark.
can anyone help me please.
Thank you.
Nov 27, 2007 | Ricoh Caplio R3 Digital Camera
Tannoy Revolution R3 Main / Stereo Speaker Logo
90 people viewed this question
Top Tannoy Audio Players & Recorders Experts
 Grubhead
Grubhead
Andrew Taylor
Andrew Taylor
Trippy Tripp
Are you a Tannoy Audio Player and Recorder Expert? Answer questions, earn points and help others
