Question about Eureka Vacuums
Possible reset on Thermal Cut-Off
After cleaning scatter rug, machine turned off. OK. thermal cut-off. However, now it will run for 1 second, turn off, then in a few seconds, will run for 1 second and turn off. etc. Do you know if there is a reset button on the thermal cut-off and where is it located? Before taking the motor out of the unit, thought I would try to find out if it has a reset button or can the thermal cut-off be replaced and where do I find one?
  • 126 Answers
This is not really expert advise but I have a vaccuum with hepa filters and if the filters get dirty My vaccuum acts like your what you are describing.
Posted on Jan 07, 2009
Was using ok, turned off for a while, would not restart.
If it does have a thermal cutout it should have reset within half an hour. Could be that the long operation caused motor to over heat and damage some of the windings.
Also make sure that the motor is receiving power. And check for the condition of the brushes - they may be worn and not making contact. on the commutator.
Oct 16, 2015 | Vacuums
Hoover 5163 Fold Away
Cutting out the thermal protector is a way assuring a sale of a replacement motor in the near future.
Apr 04, 2014 | Hoover Vacuums
Light keeps blinking
http://www.searspartsdirect.com/partsdirect/user-manuals/uh30010com-hoover-parts-vacuum-manual
WARNING: TO REDUCE RISK OF PERSONAL INJURY - UNPLUG CLEANER BEFORE SERVICING
PROBLEM POSSIBLE REASON POSSIBLE SOLUTION
2. Blown fuse or tripped breaker.
4. Thermal protector activated. (power
light is flashing)
1. Disposable bag is full. ("Check Bag"
indicator illumJnated red)
1. Disposable bag not installed correctly.
3. Brushroll is worn out.
2. Check fuse or breaker in home. Replace fuse/reset breaker.
4. Turn the cleaner off and disconnect it from the electrical
outlet. Then allow cleaner to cool for 30 minutes. If the
thermal protector continues to activate see Needs Service
solution #5.
1. Replace disposable bag - Pg. 9.
1. Review disposable bag removal and replacement - Pg. 9.
3. Replace brushroll - Pg. 10.
Mar 11, 2014 | Hoover UH30010COM Bagged Vacuum
Turn vacuum on it run for a few seconds then stops power on light is blinking
Whats your model number? A lot of machines contain a circuit that cuts the motor power when it gets to hot. Try cleaning/replacing filters and a fresh bag.
Dec 17, 2013 | Hoover Vacuums
My problem/// cleaner turns on for a around ten (10) seconds and then shuts off wait a few minutes and it will turn on but goes off again at ten (10) seconds?????
These units have a automatic resetting thermal fuse near the motor to help to protect it from burning up by running too hot. This will need to be inspected and tested to see if it's holding it's proper temps., if not it will have to be replaced. There should also be an inspection of the machine to detect what was causing the reset to shut down that quickly, so that can be repaired as well.
Oct 22, 2013 | Rainbow E series Canister Wet/Dry Vacuum
How do i replace dc17 thermal switch. i have
I don't believe there is an external thermal reset. It is most likely built into the motor.
Oct 22, 2013 | Dyson Vacuums
Reset switch
There is no reset button it as a Thermal Cut Off
This vacuum cleaner has a special thermostat that protects the cleaner in case of motor overheating. If the cleaner suddenly
shuts off, turn the switch off and unplug the cleaner.
Check the cleaner for a possible source of overheating such as a blocked hose or clogged filters. If these conditions are found, fix
them and wait at least 30 minutes before attempting to use the cleaner. After the 30-minute period, plug the cleaner back in and
turn on the switch. If the cleaner still does not run, then call 1-800-282-2886 for customer assistance
this link below is the manual
http://dl.owneriq.net/b/b7517422-db37-404e-9da2-d898185942e5.pdf
Sep 05, 2013 | Eureka 4700A Maxima Bagless Upright Vacuum
My Rainbow E Series Vacuum won't turn on at all after it just worked fine
Allowing to sit on water pan for only 3 hours is not going to kill your Rainbow by itself. If there is no more information to this issue than what you described, the problem could be the motor is going bad and the thermal cut off is tripped. Possible reason it didn't do it while you were running the unit, is the motor cooling fan kept the temperature inside the motor just below the tripping point and then when you turned the machine off, this allowed the temperature to creep up past the limit and trip the thermal cut off.
RainVac
www.rainvac.com
800-523-0510
Oct 01, 2012 | Rainbow E series Canister Wet/Dry Vacuum
Water will not dispence while cleanning
Before using tool
It may be necessary to remove air from
the system ("prime the pump") so the
clean solution will flow to the tool. Follow
these steps:
1. Attach tool to hose and turn the carpet
cleaner ON.
2. Put the tool on a hard surface or
against your hand to block off the suction.
3. Wait a few seconds (can take up to
15 seconds). Then squeeze the trigger
and begin cleaning
.http://hoover.com/file/604/
Sep 18, 2012 | Hoover SteamVac F5914-900 SpinScrub...
The machine shuts off after 2 - 3 minutes. Turning it off and back on gets about 10 secnd run. The batteries are NOT discharged. Have to it off and back on repeatedly ot finish the job.
The problem is not the battery pack. It is in the electronic over current circuit that prevents a possible overheating of the battery pack. My unit will run for 10 - 15 seconds and then shuts off. The over current sensor is reset by moving the power switch to the "OFF" position. If you turn the vacuum back on it will run for a few more seconds before shutting off again. There is a small circuit board in the vacuum that contains the over current protection circuit. It uses an NXP Semiconductor HEF4001BP quad 2-input NOR gate. If you are good at soldering you might try replacing this chip. Otherwise, buy a new vacuum. The problem is not in the thermal circuit breaker located in the handle. I have bypassed the breaker and the problem still occurs.
Mar 22, 2011 | Eureka 109A Easy Clean 2IN1 Cordless Stick...
Vacuums Logo
521 people viewed this question
Top Eureka Vacuums Experts
charlesjo336
Level 1 Expert
JoeVacs
Are you an Eureka Vacuum Expert? Answer questions, earn points and help others
