Question about GE APH10AA Air Conditioner
GE air conditioner
The unit does not drain. Where can I find a hose? L
    Problem Solver:
  • 16 Answers
What type of unit is it, window ect?
Posted on Jun 07, 2007
  • louis fernandez Jun 07, 2007
    ok my bad on the model.......missed the model number.....you have a drain pan built into the unit. i figure the drain pan fills too quickly for you. it should take a simple hose you can find at any hardware store. you will also need a hose clamp to hold it in place. yes the pan can stay off the unit. i would recommend a clear hose so you may see through it in the event there is a clog down the road. this will allow you to source the issue right away. i beleve its 3/8". dont hold me to that...take a measuring tape to it.
    gl
    k
HOW TO CLEAN THE DRAIN PAN ON A GE WINDOW AIR CONDITIONER
you have to remove it from wall & wash coil with hose add a little bleach to pan.
Jun 12, 2014 | GE APN08AA Portable Room Air Conditioner
Does the GE a/c asr05lcs1 take water
No you do not add water to A/C unit,its job is to remove moisture from the air,so make sure it is draining out the back ,if it wont blow cold after that get rid of it ac units are not to expensev anymore good luck
Jul 21, 2012 | GE ASR05LC Air Conditioner
Air conditioner is leaking into the house
Hello
First the unit needs to be on a tilt towards the outside.Check that the drain pan is clear of any debris.
Use a hose to flush out the drain hole located outside on the bottom of the unit.
Jul 21, 2011 | GE Electronic Room Air Conditioner AGW12AH
We have a GE model aeh08fmg1 window air conditioner that is leaking water inside our house.
I presume its a refrigerated air conditioner ?? Not an evaporative type. All refrigerated airconds have an internal drain which collects the moisture buildup off the evaporator coil. This drain will have a hose which runs through the wall to the outside. Have a look outside where all the aircon pipes come out. This hose could be blocked by dirt or a mouse may have chewed a hole in it. Try blowing air up the hose to clear it.
Jul 03, 2011 | GE Heating & Cooling
I HAVE A 5000 BTU G E WINDOW UNIT I PURCHASED AT LOWES LAST YEAR, IT DRIPS DOWN OVER MY PATIO IS THERE A WAY TO INSTALL A DRAIN ?
a plastic pan under the unit with some small hose can divert the water elsewhere. use silicone calk to seal the hose in the hole you drilled in the bottom of the pan NEVER DRILL THE PAN OF THE AC UNIT ! use something to catch the water.. if you drill the unit, you take the chance of hitting one if the AC lines !!! there no fix'n that
Jun 06, 2011 | GE AEV05LN Air Conditioner
Unit is leaking underneath and onto my carpet....
Check your manufacturers warranty to establish warranty period and also Sam's customer service to see if they will support you. Hose and
connector need to be replaced to eliminate moisture. This can breed
mold if not properly addressed.
Aug 04, 2009 | GE APH10AA Air Conditioner
MY split ac is leaking water from the wall unit, it has been doin
Usually an AC unit builds up condensation. If you have a drain hoole or hose that is clogged up therefore not allowing the build up to drain off it will spill over the top of whatever housing the condensation goes into. If you can look for that issue first.
Aug 03, 2009 | GE Quiet-Aire Ductless Split System Air...
Ge ape08akm1 portable ac unit
the port out the back has to be pushed down so it angles down. If its level it will drain into the tank
Jul 27, 2009 | GE APN08AA Portable Air Conditioner
Wont no water to empty or drain
Either the unit is really dirty or it is low on refrigerant. A unit tha is low on refrigerant will start off cold and withing a few minutes, start warming up. If you aren't seeing any water its because of one or both causes listed.
Apr 01, 2009 | GE APN08AA Portable Air Conditioner
GE APH10AA Air Conditioner Logo
218 people viewed this question
Top GE Heating & Cooling Experts
ray gallant
Todd B
danoyachtcap
danoyachtcap
Are you a GE Heating and Cooling Expert? Answer questions, earn points and help others
