Question about LG Flatron L1718S LCD Monitor
Monitor screens doesn't stop
Startup screens doesn't stop.. when windows xp screen appears.. it hangs and then starts again.. it's not the cpu.. i've tested it with my friends monitor.. i'm not sure if it's the cables.
    Problem Solver:
  • 12 Answers
It is a compatibility issue. If you plug the monitor/tv into the PC after you boot the PC it should show fine and not hange.
Posted on Jan 07, 2009
My windows loading takes so much time
Slow Windows Machine! Sounds like not enough resources such as RAM and CPU. Check Performance in Task-Manager (CTRL-ALT-DELETE). High CPU levels causes hang ups like freezing. Try disabling startup programs. Go to Start > Run (search in Win 7) and type MSConfig. In Startup tab, uncheck anything that you don't want Windows to load automatically. It will make Windows boot faster and use less resources while running. This just disables them in startup. Programs will still load, but when only you initiate. Consider increasing RAM. Uninstall any extras like those pushy toolbars, and add-ons.
Nov 23, 2012 | Computers & Internet
How can i log in my Delloptiplex 760 computer,when its auto logging off
If running XP
A log-on loop on your Windows XP computer is a difficult situation where the computer never completes its boot cycle, restarting intermittently ad nauseam.
This issue indicates a major problem with the boot functionality of your XP system.
Restore the computer to working order by utilizing the repair and restoration utility on your XP system disk.
Insert the XP disk into the computer.
Restart the computer.
Press any key when prompted to boot from the disk.
Press "Enter" at the first screen and "F8" at the license terms.
Highlight the drive containing XP and press "R," repairing the operating system boot files and removing the log-on loop.
or
Windows XP sometimes has a glitch when you are logging in to your user account in order to boot the operating system.
The glitch logs you in and then logs you off the account.
This problem is usually caused by one of the programs that load during the computer's start-up.
Fixing this issue is a matter of ensuring that whatever program is causing the problem doesn't start up as soon as you start your computer.
or
Power on the computer and allow it to get to the user logon page normally.
There is no need to start up the computer in "safe mode."
Click the user who is having the issue and type in the user's password if one is set up.
Press and hold the "shift" button on your computer keyboard as soon as you see the tool bar load up at the bottom of the screen but before any other program has a chance to do so.
This stops any "Startup" program from running and logging you off.
Right-click the "Start" button on the bottom left of your screen.
Select "Explore" from the menu that appears.
Double-click "Programs" from the list on the left side of the window that pops up.
Double-click "Startup."
Select all the files inside the "Startup" folder by dragging a box over them.
Right-click anywhere on the selected files.
Select "Delete" to delete those files.
Note that deleting the programs from the "Startup" folder does not delete them from your computer.
All this does is make it so that these programs no longer start as your computer is starting so that any error in the running of the programs doesn't interfere with logging in to your account.
Hope this helps
Nov 13, 2012 | Dell OptiPlex 760 PC Desktop
After powering on monitor says no sync
I've almost the same problem. When the system turns on the monitor doesn't sync. After a variable trials with down/up the sync is enabled and the computer starts.A very clear event occurs : when the monitor can''t sync ( and system doesn't boot)you can hear very clear a high fan rotation. When I look/hear in the system the Isuspect the cpu fan. The system boots ( monitor syncs) when the fan rotationgoes from high to low. So the system hangs on an internal check on the rotation speed of the cpu fan.I've googled a lot , but until now doesn't find an answer . Possibilties which I think about : replace cpu fan , clean cpu fun ( but it looks clean).I cannot measure the fan rotation speed when the system is hanging. At normal rotation all info can retrieved witth the program cpu-z.Did you already have a solution ?
Dec 07, 2011 | Compaq Presario 5000 PC Desktop
I have a VP201m. display flashes at startup and goes black
That's not monitor problem, it's your CPU, probably the Operating System crash!!!( Windows,etc).
Try reinstall it to solve the problem...
Oct 18, 2009 | Computers & Internet
Sound card Driver problem under Win XP
download new drivers from driver detective..
or click bharatgulati.blogspot.com.
i do hv 1 problem..
"iam getting yellow vertical lines at startup screen..the lines are moving.system hangs after few sec. & sometimes it works perfectly.cant even format the system as it hangs.help"
Jul 22, 2009 | Computers & Internet
No beep at startup, powers up but will not load windows xp just get a blank screen
blank screen a lot of cause.
firs chek the os is available,,. check the ram, cpu, of board.. vga,,
Jun 29, 2009 | Foxconn 760GXK8MC-S Motherboard
I have corrupted files in Windows XP and EMachines provides "Restore CDs" But with my NEW LG widescreen monitor the instructions on how to startup the CDs is actually cut off. So when I attempt to load the...
hi there! if you can configure your bios set up and go there, priority yout cd rom as first on the list,2nd your hard drive, in able to start and configure your windows set up promptly.How to open your bios set up,after switching on your pc, press F2 or delete depend on your start up windows appear on left bottom of screen if cmos/bios appear on blue screen select the boot sequence and arange the list of booting up your windows.In your screen resolution this will be adjusted after you finished the windows set up to new xp,you can adjust your scrren resolution, by left clicking on your windows xp on screen,click proreties, on properties box there adjustment of screen resolution there slide function key to 1680 X 1200.then click apply,click ok then restart your pc for effetivity or sometime it was auto restart after you change your screen resolution...,regards
Mar 27, 2009 | E-Machines W3052 PC Desktop
Laptop won' boot up.
The blue screen means the system is experiencing a fatal error... a error from which it cant recover.... so while booting press f8 and boot using safe mode... then analyse the startup programs of your system using Start->Run and then typing msconfig in the window that appears and then going to the startup tab... one of your latest installed program might be misfunctioning....
Nov 19, 2008 | Compaq Presario Notebook
Will come on-then say no signal
If you mean the monitor is fine during the Windows booting process and then just as your about to go into Windows goes black then do this...
Start the computer
When the bios screen goes start pressing F8
A Windows Startup screen will appear
If you see the Windows Logo (the loading one) then hit reset and try again
At the Windows Startup page, select Safe Mode and press enter twice.
Windows will now load. Go into Device Manager (Start-Settings-Control Panel-System-Device Manager)
Select the video card, and uninstall it.
Restart Windows
Reinstall your video card using the Installer package (if it's ATI or nVidia)
If this dosn't work, then post back and we will try something else
Apr 16, 2008 | Gateway FPD2275W LCD Monitor
Input not supported
You may have a video resolution selected on your computer that the screen doesn't support.
The reason you see the the initial startup message is because that is loaded from the bios, prior to the settings for the graphic card output being loaded.
Try booting the computer in safe mode and adjusting the display resolution.
Dec 29, 2007 | Acer AL1916W 19" LCD Monitor
LG Flatron L1718S LCD Monitor Logo
65 people viewed this question
Top LG Computers & Internet Experts
Alun Cox
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
