I have a Rheem (Criterion) unit and i'am having promblems with the main burner staying on. When i turn the unit on everything operates like it should up to the main burner staying on.Once the main flame kicks in it will stay on for five second and the flame will go out along with the draft moter( for about three second the trouble shooting light will flash four times) then the unit will start cycling all over again from draft moter purging, glow plug will operate like it suppose to up to the main gas. once the main burner kicks in the flame will stay on for five seconds and go out. This time the indoor fan will kick on and the unit will not cycle anymore. I changed the flame sensor and the control board and still the same problem what can i do next. thanks in advance
  • 1 more comment
  • Anonymous Jan 07, 2009
    I bypassed the plug, and ran the wire from the sensor down to the control board. The problem is still there. Once the flame goes out for the second time, the computer board LED trouble light stays constant and doesn't show a code. What could be the next step I can try? Do you think that the gas pressure would have anything to do with it? Thanks
  • Anonymous Jan 08, 2009
    It doesn't flash at all.
  • Danny Clark
    Danny Clark May 11, 2010
    Look for a flash code on the wiring diagram. What does it say 4 flashes are?
  • 61 Answers
Run a wire from the sensor down to the control board conector. Bypass the sensor wire around the connector in the blower deck.
The connection can be wire nutted on the sensor lead with the wire (16 or 18 guage stranded wire works) routed through the blower deck to the other side of the plastic wire connector on the blower deck.
The Sensor operates at high voltage but very low current. The connector will sometimes fail due to humidity or wear.
I have seen this on the Rheem or Ruud furnaces.
Hope this helps.
Matt
Posted on Jan 07, 2009
I have a Rheem Criterion Furnace that won't stay on! Starts and stops 3 times then shuts off!
Check air filter is clean , jump out pressure switch see if it lights
Jan 08, 2013 | Heating & Cooling
How do I get the covers back on my Rheem Criterion
Here is the manual for the furnace.
Make sure you do not have the panels mixed up..just saying it can happen.
Oct 23, 2011 | Heating & Cooling
My Rheem tankless water heater has been flashing a C8 and 76 code. I can turn off the heater using the power button on the unit, but my hot water will only last for a shower or so. Any suggestions? ...
Before calling service technician, open following link for troubleshoot resources including Rheem chat and contact, possible manual, error codes, etc.:
http://waterheatertimer.org/Troubleshoot-Rheem-Tankless-water-heater.html
C8 76 is generally bad PC board. Call 800-432-8373
Just like a motherboard on your computer, the tankless PC board is operational center of tankless water heater.
Various sensors gather information from water pipes, gas line, vent pipe, and air supply to determine when to activate burner.
Most people understand that when their computer motherboard needs replacement, that computer will probably not work reliably again.
Tankless is basically connecting a complex computer to your plumbing and electrical lines and to a gas burner with a vent pipe to outdoors, despite knowing that plumbing lines, vent pipes, gas burners, and household electrical systems have plenty of problems on their own.
Age factor: When tankless is new and everything operates perfectly, the tankless works correctly.
And each tankless manual recommends yearly and monthly maintenance, just to maintain operation, the cost of which can exceed the expected 1-8$ monthly savings. And who wants to clean the water filter each month and delime the exchanger every year?
http://waterheatertimer.org/pdf/Tankless-maintenance.pdf
Don't buy a tankless water heater because the only folks promising unlimited hot water and effortless water heating experience while saving money with a tankless are the tankless promotors.
Solve most tankless problems yourself, same day, any brand for about $350.
http://waterheatertimer.org/How-to-install-gas-water-heater.html
Sep 22, 2011 | Rheem Tankless Water Heater Main Remote...
My Rheem Criterion II Gas Furnace seems to be igniting and then shutting off soon after that. It will turn on when the room temp. is the same as the setting temp. I have two green lights and one yellow...
There is a flame sensing rod in the burners and it gets dirty and the unit controller cant tell if the burner is on, so it shuts down. Look for a rod that is bare metal and may be L shaped that extends from the edge of the burner frame into the burner. There should be one wire attached to it. There is a screw that holds it in place, you can remove it and unhook the wire, clean it or replace it.
Nov 20, 2017 | Heating & Cooling
I have a Rheem Criterion II Gas Furnace that has been acting up the last couple of days. It is model #RGPH-12EARJR. It will cycle on, ignite the pilot, 4 burners light and stay lit from 5-10 seconds then...
Turn off the power to furnace.
on the last burner to light there is a small metal rod in front of the burner. This is a safety called the flame sensor. It is dirty. Unscrew it from the bar ( 1 Screw) unplug the connector wire from it and clean it with steel wool. it will be kind of burnt. Plut back in place and turn on the furnace to cycle.
Apr 04, 2010 | Heating & Cooling
Have a rheem criterion II. Model
The way it lights is that the gas is spread from one burner to the next by either a flame tray or small holes drilled in the burner tubes. If the flame does not get all the way across the burner tubes within a few seconds, the unit goes out on failure. Clean and inspect each burner tube, not just the orifice. Clean any tray that connects the burners. You can use a small wire brush or tooth brush but be careful near the glow igniter as it is very fragile.
Dec 12, 2009 | Heating & Cooling
Rheem/GE power vent water heater, pilot lites, but not the main
I would check to see if the switch on the blower pressure sensor is closing...When T-stat calls for flame, the circuit starts the blower, then the blower pressure sensor switch closes to allow the main gas valve to be powered.
Jul 08, 2009 | Water Heaters
Rheem criterion II flame stays lit for a few seconds then only cold air blows through the house
Your furnace needs a tune-up. MODERN FURNACES REQUIRE REGULAR MAINTENANCE!
Mar 10, 2009 | Goodman GMS90703BXA Heater
Heating & Cooling Logo
214 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
