Question about Microtek ScanMaker X6 Flatbed Scanner
How to Clean a Scanner? I bought the Microtek x6 scanner second-hand in order to scan a photograph for my business card. As a designer, I'll need a scanner for lots of projects, but this one leaves white speckles in specific places, no matter what I scan. I can tell that the dust or lint is on the inside, as I've cleaned the glass and lid thoroughly. There are 2 screws on the top of the glass face; dare I open and spray with forced air?
5 Suggested Answers
SOURCE: Microtek Scanner
I am having the same problem with mine. Have you been able to get it working? Please let me know how.
Thanx!
Posted on Oct 19, 2007
SOURCE: Scanmaker x6
Didn't find the manual, but I managed to get it working with my C2D MBP.
Thanks again!
Posted on May 23, 2008
SOURCE: Yellow Streak on Images
I took the scanner apart. Then using a dampened eyeglass cleaning cloth, I gently cleaned the 3 internal mirrors.
No more yellow streak! :)
Posted on May 28, 2008
  • 857 Answers
SOURCE: need to remove top of scanner microtek scan wizard
Follow these steps to clean the scanner :
Open up your scanner's lid. It does not matter if the scanner is on or off for this basic, regular cleaning.
Wipe down the glass surface with a dry, lint-free microfiber cloth. This will remove any dust or other fine particles that have accumulated on the scanner. You should remove excess dust every day or two.
Scan a blank sheet of white paper into your computer and look for visible discoloration. A white sheet will provide a clean, blank slate to view the scanner's overall quality. If you notice any irregularities on the white sheet, you need to do more thorough, semi-regular cleaning.
Semi-Regular Cleaning
Turn off the scanner and open up the lid.
Spray a small amount of "mild glass cleaner" on a soft, clean cloth as recommended by Scanner-Magic.com.
Wipe the scanner's glass to thoroughly clean the area. You should perform this semi-regular cleaning at least every two weeks or sooner if a white sheet of paper indicates discoloration.
Keep the scanner's lid open for a few minutes until all excess glass cleaner has dried.
Posted on Nov 26, 2010
Microtek Scanner thinks it's busy when it isn't
Check using a new USB cable. Unplug everything else plug into USB except for mouse and keyboard. If not work. Un-install driver and software. Download driver and latest software. Reinstall printer using driver only. Then use Paint to test it.
May 05, 2017 | Microtek MRS-1200X6U ScanMaker X6 Flatbed...
Scanmaker x6
Thanks again!
May 21, 2008 | Microtek ScanMaker X6 Flatbed Scanner
Help !! ,Microtek scanmaaker 3840 problem
maybe you have to clean up your scanner.. and ur settings of scanner might have the wrong configuration....
Feb 24, 2008 | Microtek scanmaker 3840
Software and driver
You should be able to download the proper drivers for your Operating System directly from Microtek:
http://www.microtek.com/
Since you didn't tell us which country you're located in, or which OS you're using, I can't provide any more specific information for you...
The Download page is located here, for users in the US:
http://support.microtek.com/downloads/
From what I could determine, the X6 model was discontinued some time ago, and there were at least THREE versions of it; you'll have to find it listed under the Product Category in the Discontinued Products section, then choose the version (parallel port / EPP, SCSI, or USB), in order to download the driver you need. Seems that the SCSI version has drivers ONLY for Apple computers; if you're using Windows, you'll need to choose one of the other options...
Jan 27, 2008 | Microtek ScanMaker X6 Flatbed Scanner
Windows vista driver question
According ti the following link this device is Windows Vista compatible.
http://support.microtek.com/downloads/bymodelname.phtml?srch_in=scanmaker%205950&axn=2&slct_mdl=29
See note below OS list that nonlisted OSes are not supported.
Click Windows Vista 32 bit
Select your connection speed
Click go
Download and install your files
Notice the note in red to save existing data
Dec 23, 2007 | Victory WorldCard Office Card Scan...
Scanner Malfunctioning
Lines in the ourput could be because of dust on the glass, clean the glass. Dont use any solvent. Try and reinstall the software driver after removing the existing. Run Scandisk on the computer. Soem scanners cannot work continuously for long hours.
S. Mohan, Chennai
Dec 22, 2007 | Microtek SCANMAKER I900 Flatbed Scanner
Error 600
I bought the pro version of the 8700, used it about once a month--very light use. When it died, I found that Microtek won't even sell parts! I agree, NEVER buy another Microtek product! This thing cost me over a $1000 and after one year, NO support! Any company but Microtek.
Dec 06, 2007 | Microtek ScanMaker 8700 Flatbed Scanner
Microtek Scanner
Thanx!
Sep 25, 2007 | Microtek ScanMaker X6 Flatbed Scanner
Microtek x6 scanner and lightlid instruction manuals
A Scanner this old is not likely to work with a computer that is current. You did not say if you have the driver disk to try. If you have and have loaded the MiraScan software,right click on the program icon and click on properties then campatability and set to run as W98 and see what happens You will not find driver for this one now. I assume you are running XP or 2000 This scanner designed to run with W95/98 is not compatible with modern NTFS systems.
Apr 26, 2007 | Microtek ScanMaker X6 Flatbed Scanner
Open Questions:
Microtek ScanMaker X6 Flatbed Scanner Logo
42 people viewed this question
Top Microtek Office Equipment & Supplies Experts
Alun Cox
Tony
Are you a Microtek Office Equipment and Supply Expert? Answer questions, earn points and help others
