Question about HP Photosmart C6180 All-In-One InkJet Printer
Manual printing how do you use the manual feed on top of printer
    Genius:
  • 2,035 Answers
Please click here
Good luck...
Posted on Jan 07, 2009
How to print both side in hl-2130
Hi there.
The HL-2130 does not have an auto-duplexing system included in the machine. If you wish to duplex print you need to print the first page then feed that page through the Manual Feed system (Side to be printed up, top of page first) and print the second page on the manually fed page.
Aug 17, 2014 | Brother HL-2130 monochrome laser printer...
Its prints one page at a time and a pop up appears that says "press cancel button (manual feed mode)". I do this and nothing happens. Why will it not just print the entire document at one time? I...
You need to change the default tray. Thats the reason its printing one page at a time. You can change the default tray to draw paper from two ways, by using the controls on the printer itself or by changing the settings when you print a document.
To change it on the printer, go to menu on the printers keys and scroll the options until you find the print settings. Use the up and down arrows to scroll and press enter or OK when you find print settings. Continue to scroll until you see the default paper tray and change it from the manual feed choice to the default paper tray.
If changing from the print settings in the computer, when in a document that you want to print go to file at the top of the page and then print and click on preferences. Click the tabs at the top until you see the paper tray that is currently being used and click the arrow next to it to change it to another. Then click "ok" and close everything.
Dec 07, 2010 | Samsung ML 2010 Laser Printer
I have a Dell 5210N mono printer. And I want to use the manual feed tray as a second paper drawer for letterhead paper only, ie leave a whole stack of paper in the manual feed. Then when I select manual...
Check the software provided or installed on your Computer you use for work(printing software), look for print properties, check for print settings, look for manual Feed, Under manual Feed, set it for letterheads, however this has to correspond with the Applications you are using to print letterheads out of( under print, into the preferrences you should be able to have the settings as well). If your printer software does have these settings, then you will have to do it Manually upon every print.
Dec 03, 2010 | Dell 5210n Laser Printer
Printer is saying manual feed insert paper. Will not print
To load paper or other media in the Manual Feed Slot (directly above the Paper Tray)
You can load envelopes and special print media one at a time into this slot. Use the manual feed slot to print or copy on labels, envelopes or thicker paper.
1. Slide the paper guides to fit the paper size.
2. Using both hands put one sheet of paper in the manual feed slot until you feel the front edge of the paper touch the paper feed roller. Let go of the paper when you feel the machine feed the paper in a short distance.
Note: When you put paper in the manual feed slot, please remember the following:
■ The side to be printed on must be face up.
■ Put the leading edge (top of the paper) in first and push it gently into the slot.
■ Make sure that the paper is straight and in the proper position on the manual feed slot. If it is not, the paper may not be fed properly, resulting in a skewed printout or a paper jam.
■ Do not put more than one sheet or envelope in the manual feed slot at a time or you may cause the machine to jam.
■ You can remove smaller sizes of printed paper from the output paper tray more easily if you lift the scanner cover using both hands as shown in the illustration.
You can still use the machine when the scanner cover is raised. You can return the scanner cover to its home position by pushing it down with both hands.
If you would like to disable Manual Feed Mode, check that the manual feed mode is not selected in the printer driver.
Here is a copy of the User's Manual for the Brother MFC-7820N.
Jul 07, 2010 | Brother MFC-7820N Laser Printer
When printing back side of paper, paper turns sideways and tears in half.
see that u r feeding the oaper straight. Try to feed the paper manually instead from automatic feed. Also remove the curl of the paper form the top end by hand before feeding
Aug 11, 2009 | Canon imageCLASS D680 Laser Printer
My printer says i am out of paper but i am not
Check if the software you are printing from is set to feed from the manual feed (top back) instead of the main paper tray. You can put a sheet of paper in at the top to see if it takes that instead of the main tray, If so, change the settings in the Printer properties to feed from the main tray first.
Aug 04, 2009 | HP LaserJet 1100 Printer
Hp laserjet p3005dn tray1 manual feed problem
you can choose mp first in "paper handing" printer menu or print tray1 is A4 default in properties of printer software.
Jul 25, 2009 | HP LaserJet P3005n Printer
Not printing
Please open the manual feed and try to print using manual feed if you are able to print fine using manual feed that check pickup roller of Tray 2.
First of try to print using Manual feed and let me know if it is printing from Manual feed or not.
Jun 30, 2009 | HP LaserJet P2015 Printer
Can't print from top
Replace the manual feed roller and separation pad.
Feb 13, 2009 | HP LaserJet 4250n Printer
Printer switching orientation
Make sure that manual feed is set to letter, on the printer front panel. This is a tabloid printer, so letter size sheets are fed long edge. The cassette will print okay because the media size info for the cassette is read by the printer from the cassette cams.
Dec 21, 2006 | Xante 4G Printer
HP Photosmart C6180 All-In-One InkJet Printer Logo
80 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
