Question about Acer Aspire 5100 Notebook
Hot to connect acer aspire mini laptop to digital lcd tv?
I tried connecting my laptop to my tv using a vga cable, i cud hear the audio but couldnt see the video. when i restarted my laptop the tv said "format not supported". what shud i do to connect my laptop to my tv
  • raisa_irfan Jan 08, 2009
    yes i used a seperate audio cable. wat did u mean by 'toogle the screen'?
    Problem Solver:
  • 12 Answers
Press the Blue function key and toggle the screens. You can view, the Laptop, the Laptop and Screen, or just the screen.
Also you will need to flick through the channel button on the TV to get to the PC interface. Since you indicated you were using a VGA cable, this is likely the missing element.
Note: The VGA cable does not carry audio, you either had a separate audio interface to the TV or you were using RBG/Composite/S-Video/HDMI. So check to make sure you are using the correct cables.
Posted on Jan 07, 2009
How to connect acer aspire 5315 to LG led tv
Acer Aspire 5315 doesn't come with an HDMI port. So, you have the following options:
1. Use a VGA Cable to connect the PC to TV if the TV has PC-Input facility
2. Use an S-Video cable to the TV's S-Video-in port if the TV has it
3. Use and S-Video to HDMI converter if the TV has HDMI port
(http://www.amazon.com/Composite-S-video-Audio-HDMI-Converter/dp/B003NS0UUQ)
for audio, you can use 3.5mm to RCA (Red/White) connector to connect to TV's audio-in port.
Apr 15, 2013 | Acer Aspire 3680 Laptop
Would appreciate any advice on connecting cable etc. to connect my Compter and TV to display video/film downloads.s
The easiest connection is converting to VGA and using a standard headphone port-to-audio in. Your video out from the laptop varies by model, which isn't included here.
It will most likely be mini-VGA or mini-DVI
Nov 04, 2012 | Computers & Internet
How do I connect my Laptop Acer 5735 to my TV Sony KDL-40NX700, what kind of connection cables do I require?
If Your TV and Laptop have HDMI Port then you just need a HDMI Cable.
But if you dont have HDMI port. then you need two cables one from video and one for audio.
For Video you either VGA Cable(if you have VGA Port in your TV) or VGA to RCA Cable (Yellow Pin will be for video)
For audio You Need 3.5mm pin to RCA (white and Red for audio).
This pic is of VGA to RCA Cable
Sep 10, 2011 | Acer Aspire 5735 Notebook
How to connect my acer D255E to the TV
According to the limited resources that I could find your only video output is a VGA port. Most newer televisions, predominantly LCD televisions will allow a direct connection via VGA. If your TV does not support VGA, can try using:
VGA to HMDI for HDTV's - Amazon search http://www.amazon.com/s/ref=nb_sb_noss?url=search-alias%3Daps&field-keywords=vga+to+hdmi&x=0&y=0
With these I typically recommend a full force converter over a cable, but often times cables will work. Remember that with a VGA to HDMI cable only, this will only pass video and not audio. You will need separate cables for audio.
If you have a non-HDTV try this: http://www.amazon.com/VGA-Adapter-S-Video-Cable-Video/dp/B000Y7T5UU/ref=sr_1_1?ie=UTF8&qid=1315249911&sr=8-1
Use either S-video or RCA connectors to your TV.
Sep 05, 2011 | Acer Aspire One D255E13438 Netbook
I have a vga to hdmi cable for my acer aspire 3680, when I connect the laptop to the tv with the cable, nothing happens. neither device sees the other or even registers that the cables are connected. is...
VGA has only analog video signal. It is not digital and does not have any audio either.
HDMI is a digital connection standard with both digital video and digital audio signals.
A cable with a VGA connector on one end and a HDMI connector on the other still needs a converter box to convert the analog signals into the digital signals required for the TV's HDMI. Click on the following link to go to web page titled VGA to HDMI Cable - An Unfortunate Myth
http://vgatohdmicable.info/
Apr 21, 2011 | Acer Aspire 3680 PC Notebook
How do I connect my acer aspire 5050 to TV?
Since the Acer Aspire One D250 only has VGA output for its video, you will need a VGA cable to connect between the D250 and a TV that accepts VGA input as a video source. The sound is separate. A mini-stereo jack on an audio cable with two RCA phono plugs on the other end would be used to connect the D250 audio output (usually used for headphones) to the left and right audio inputs on the TV. You may need to use the TV setup screens to select the proper video and audio sources. With the TV on and proper video source selected, you now should be able to press Fn and F5 to get a menu in the middle of the D250's screen that allows you to select the video destination by holding down Fn key and pressing the F5 key repeatedly. The single large screen icon (3rd one from the left) is the one to select video output to VGA port only which would send it to your TV. The sound on the D250 does not need to be selected but you may wish to adjust its level and/or properties to be more suitable for TV.
Jan 19, 2011 | Acer Aspire One D250 Netbook
I HAVE CONNECTED MY ACER ASPIRE PC TO MY SAMSUNG LCDTV USING A VGA CABLE , THE PICTURE IS THERE , BUT I CANT GET ANY SOUND ?
The VGA cable only supplies video data to the LCD TV. Connect a sound cable from the audio out from the Acer PC to the audio input on the LCD TV to get sound from the LCD TV's speakers.
Dec 14, 2010 | Computers & Internet
Connecting laptop to hd tv
IMake sure that you have the laptop for an VGA OUTPUT. When you toggle between the function keys. When your laptop LCD goes out it is in VGA OUT mode....when you toggle again it should be in LCD/VGA OUT (both TV and laptop should display). You need to set the TV to VGA mode as well...otherwise you might not get an output. If you still have a problem then test on a regular monitor to see if you are getting an output to the monitor
IF THIS HELPS PLEASE VOTE.....GOOD LUCK AND THANKS..
Nov 12, 2009 | Acer Aspire 1640Z Notebook
HOW TO CONNECT SAMSUNG LCD TV TO ACER ASPIRE
hi if you laptop has the s-video you can connect that to the tv an it would work
Jan 10, 2009 | Televison & Video
How to connect acer aspire mini laptop to digital lcd tv?
You get the audio from PC: you must use a separate audio cable to your TV audio input.
Configure your PC Display properties to a lower resolution until you reach a format your tv can display.
If you use a flat digital screen check the manual to know the resolution to be used with VGA input.
Use Dual screen option or swittch main screen/external/both using FN key + blue key showing screen on your keyboard. (F4 or F7? check manual.)
Jan 07, 2009 | Acer Aspire 5100 Notebook
Acer Aspire 5100 Notebook Logo
348 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
