Question about Sony Playstation 3 (PS3) Console
Connecting ps3 to a standard tv
We are using the av cable supplied in our new ps3 and are hooking them in correctly color to video in line on back of standard definition tv and we are getting no picture or sound....anyone give us some help please!
    Scholar:
  • 65 Answers
Hello
I think that you should have a button on the remote which lets you switch to the auxilliary connection of the TV (it won't switch automatically). Try putting it on AV1 AV2 or AUX or such modes you have to refer to your TV manual to see how to switch exactly to the Video Line in Connection.
This should solve your problem :)
Cheers :)
Posted on Jan 07, 2009
Ressetig the ps3 on a new tv
Sounds like the Tv your using is faulty. Its could have hardware failure. You did say it PS3 was working on hdmi on a plasma. If your using the default hdmi cable that came with ps3 that also can be faulty. I have always had problems with the default hdmi so i bought a new one that was not SONY and it works beautifully. Another thing the black screen with green is a video cable or graphics issue.
Does this tv work if there is no ps3 connected? if so i recommend using the standard PS3 Component AV Cable. see if that will let you reset your ps3.
Jun 24, 2014 | Sony Playstation 3 (PS3) Console
Why cant i get my wii console to work in color
Well it might either be the tv or the av cables that is causing the wii system to be in black grey and white then.
Picture Is Black and White or Does Not Appear Situation:
  • The console powers on and shows a black and white image on the television screen
  • The console powers on and there is no image on the television
What to do:
  • Determine whether the Standard AV Cables (packaged with the system) or the Component Cables (sold separately) are being used.
  • AV Cables
    • Ensure the yellow, red, and white cables are connected to the correct corresponding inputs on the TV. (How To)
    • Try another set of inputs on the TV, or hooking the Wii console up to another TV.
    • If the TV does not have the yellow, red and white inputs, it will most likely have component inputs which allow standard AV cable use. Try these AV hookup steps. (How To)
  • Component Cables
    • Ensure the red, blue and green video cables are connected to the correct corresponding inputs on the TV. (How To)
Still Not Resolved:
  • If the television is continues to show a black and white image when powering on the Wii console, then the problem is likely with the system and it will need to be repaired. Please call 1-800-255-3700 so that we may assist you further.
Mar 06, 2012 | Nintendo Wii Console
Can't get video to work on Ps3 system compossite cables
First make sure that all of the connections are securely connected. If it still doesn't work try another set of cables. Also ensure that your setup menu on the PS3 is set to the correct resolution. If you are using the standard definition connection (3 RCA type connections labeled VIDEO L-AUDIO-R) make sure your resolution is set to 480i. If all of those steps are correct and you still can't get it to work then your Analog Video board might be defective. You will have to get this serviced by your local PS3 repair center.
Mar 04, 2010 | Sony Playstation 3 (PS3) Console
Origiannly had my son's PS# hooked up to our HD TV
You must reset your PS3 in order to accept the new TV configuration.
  • If the video output settings on the PLAYSTATION®3 do not match those of the cable or TV in use, there may be no picture. If the screen goes blank, turn off the system.
  • Then, with only the PLAYSTATION®3 and the TV connected, touch the system's power button for more than 5 seconds to turn the system back on. The video output settings will automatically be reset to the standard resolution.
  • From: http://playstation.custhelp.com/cgi-bin/playstation.cfg/php/enduser/std_adp.php?p_faqid=967&p_sid=1frk_Cuj
    Hope this helps please remember to rate my response, thanks!
    OpenSource13
    Apr 06, 2009 | Sony Playstation 3 (PS3) Console
    PS3 Video Connection--Lines on TV
    this may be due to the fact that your ps3 will be set up to hd. go into video settings when you switch it on and this should solve the problem. i had similar problems and bought a hdtv until someone pointed this out to me. however once you have experienced ps3 in hd you will not go back!!! hope this helps
    Jan 13, 2009 | Sony Playstation 3 (PS3) Console
    PS 3 Hookup to Sony Grand Wega
    this is a very simple fix leave cords in your sony with ps3 on standby hold the power button on ps3 itself down for 10sec your ps3 will switch back to av cables
    Jan 05, 2009 | Sony Playstation 3 (PS3) Console
    PS3 streches off the TV Screen
    Try holding the power button on the ps3 for about 10seconds. It should beep as it normally would turning on, carry on holding the button until it restarts. This should restart the ps3 in standard mode so that it can be viewed via rca/scart connection.
    Aug 17, 2008 | Sony Playstation 3 (PS3) Console
    Pic
    if you have a SD TV. ( standard display, not HD ) but chose the HD display option on system settings you wont see picture but hear sound. and same goes if you've chosen SD display but own a HD TV. so try to reset your system somehow or take it in for inspection.
    Jul 13, 2008 | Sony Playstation 3 (PS3) Console
    PS3 Connection to TV problems
    so, you tried the Video Reset with your standard av cable hooked up...turn off rear power switch, then back on. Hold front power button to turn unit on for 8 seconds or so, which will reset the video settings....unit will give some double beeps letting u know this was successful. then turn off and on again.
    Dec 31, 2007 | Sony Playstation 3 (PS3) Console
    Sony Playstation 3 (PS3) Console Logo
    393 people viewed this question
    Top Sony Video Game Consoles & Games Experts
    Iron
    Iron
    Troy Gorman
    Troy Gorman
    Jonathon summesfield
    Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
