Question about Compaq Presario 2190US Notebook
Memory upgrade problems
I asked you a question about the memory upgrade not registering in the compaq presario 2190 and yousaid that i had the wrong memory for the laptop. i have since received the correct memory for the laptop however it still does not register any other thoughts.
  • pontelemon
    pontelemon May 11, 2010
    How much memory are you trying to put right now?
RAM capacity ?
Memory Upgrade Specs for HewlettPackard Compaq Presario SR1215CL Computer. The HewlettPackard Compaq Presario SR1215CL Computer takes the PC3200 DDR SDRAM 184-pin DIMM Memory Type, and comes installed with 512MB (Removable) of Memory. You can upgrade your HewlettPackard Compaq Presario SR1215CL Computer to up to a maximum memory capacity of 2 GB Memory, the system has 2 Sockets to install Memory, already with 512MB (Removable) standard Memory installed. For best Compaq Presario SR1215CL Computer performance use the maximum amount of allowed Memory per slot for your Computer.
If you're not sure if a module is right for your system, use the Crucial Memory Advisor tool for a list of guaranteed compatible modules. first you will need to select the manufacturer from a drop down list then select your product line from a drop down list then select the model then click find it will take you directly to compatible ram also you will have an option to scan your system you should always ask for a guarantee on the compatibility before making any purchase and try to buy for working pairs if possible http://www.memorystock.com/memory/HewlettPackardCompaqPresarioSR1215CL.html
Apr 20, 2013 | HP Compaq Presario SR1215CL (82916052980)...
Compaq Presario 5LOXE1 Memory upgrade
So you mean only 1 video card is working and the other one is not?
May 04, 2008 | Compaq Presario 5000 PC Desktop
Memory and harddisk upgrade for compaq presario 1692
Compaq has a upgrade tool you can use for this ... find it at www.compaq.com/support
May 30, 2010 | Compaq Presario 1692 Notebook
Wont stay off
sounds like it needs a new power supply.
Feb 04, 2009 | Compaq Presario 2190US Notebook
Memory upgrade
Well...digging through HP's web page is always fun...;-)
but it looks like you've got the wrong memory. You should only use PC2100 DDR-266 MHz or higher RAM, according to HP.
(You can find the manual here.)
Sometimes the so-called "Memory Finder" on vendor's pages give you the wrong information. If that is the case (and it's their fault), talk to them and try to exchange it to the correct modules.
Jan 01, 2009 | Compaq Presario 2190US Notebook
Memory Upgrade for Compaq Presario 2580US
no 'coz these two memory card differ in size and slot especially when the mainboard doesn't support ddr2
Nov 18, 2008 | Compaq Presario 2580US Notebook
RAM upgrade gone wrong?
Did you already try using last know good configuration?
When your computer boots instead of f10 press F8. Then select last known good configuration and enter.
if it didn't work try booting up the computer without the memory see if it will have the same problem.
May 12, 2008 | Compaq Presario 5000 PC Desktop
Compaq presario 2500 notepad
Well,you already have a DVD burner in your machine, and A DVD ROM refers to memory.. you just need to download the upgrades available at Compaq's website. find out which Cd/DVD burner you have by downloading a marvelous freeware program called Belafrc Advisor, which will list all hardware and sofware on your
computer, compete with versions and access codes. then go to
http://h10025.www1.hp.com/ewfrf/wc/softwareList?os=228&lc=en&cc=us&dlc=en&product=320163&lang=en
which lists all upgrades available for your model. DVD burners stopworking correctly when your non-microsoft burner program becomes corrupt, so be sure to upgrade that. If you have any problems, ask support.
Mar 10, 2008 | Computers & Internet
Compaq Presario 5352 memory installation recognizing
be sure that the memory u got is compatible in your presario 5352. I tell you that adding 512mb to current 64 mb maybe a problem. you should remove the 64mb and replace it by 512mb and be sure that the new memory is compatible. want more information about your presario go to www.hp.com then search "compaq presario 5352"
melnavz
Dec 12, 2007 | Compaq Presario 5000 PC Desktop
Compaq Presario 2190US Notebook Logo
53 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
