Question about Hitachi 50FX18B/19K 50" Rear Projection Television
Hitachi 50fx18b 50" projection no power
I got this tv for free from craigs list and was told it needed a new tube, but it wont even power on. where do i start?
  • Hitachi Master
  • 3,459 Answers
Does it chirp? If so you need convergence chips replaced.
Read the link below.
Yes - You will need to either remove the circuit board or lift up the tray. If you are not sure how to do it yourself read the link below.
  • This is a very common failure on Projection TV sets.
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV Makes Chirping Sound
You can see some example photos and find a solution here...
http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Posted on Sep 19, 2009
I have a 50fx18b and it wont power up i took the back of the set off it has a red light on but nothing happens when i turn power on
the red light = shutdown led
all the green ones indicate the voltage lines that came up
there is a diagram inside that shows all the leds plus fuse locations. you need to check the fuses with an ohm meter to figure out which one is blow or which voltage doesn't come up. with that info, i can direct you.
Jun 04, 2010 | Hitachi 50FX18B/19K 50" Rear Projection...
I have a hitachi 50FX18B and the convergence lines are not aligne
  • Screen looks 3D
Feb 24, 2009 | Hitachi 50FX18B/19K 50" Rear Projection...
I have a hitachi 50FX18B and the convergence lines are not lining up and the picture looks like you are looking through 3D glasses. How do I fix this??
This is a problem with the convergence circuit. If you can solder, you can fix this yourself. Please note as well that there are potentially dangerous high voltages present even when the set is unplugged. That being said... Open up the back and locate the convergence ICs (large black ICs attached to a heatsink and marked STKxxx). Try resoldering the pins on these ICs first. If that fails to resolve the problem, replace the ICs. There may be other related components that need to be replaced as well, but start with the ICs.
Keep us posted.
Dan
Jan 22, 2009 | Hitachi 50FX18B/19K 50" Rear Projection...
50 inch rear projection Hitachi looks like your watching in 3d
This is a convergence problem and igf you can solder, you can probably fix this yourself. If you feel comfortable working inside the set, and are aware of the dangers of the high voltage present there. try the following: Resolder the pins on the convergence ICs. If that fails to resolve the problem, replace the ICs. These are large black ICs attached to a heatsink and should be marked STKxxx.
Keep us posted.
Dan
Nov 24, 2008 | Hitachi 50FX18B/19K 50" Rear Projection...
1996 Hitachi 50FX18B 50"
  • Screen looks 3D
Jul 24, 2008 | Hitachi 50FX18B/19K 50" Rear Projection...
Hitachi 50fx18b
Press "shift" on remote to write to Rom. "Rom write" is displayed. Press shift again. Wait about 25 seconds, then press "mute" to return to convergence mode.
Mar 02, 2008 | Hitachi 50FX18B/19K 50" Rear Projection...
Hitachi 50" Projector 50FX18B
Common problem. You can get a repair kit that includes the C707 and E994 + repair instructions from www.TvRepairKits.com
Nov 27, 2007 | Hitachi 50UX57B 50" Rear Projection...
Hitachi 50FX18B
KIT10 $29.50
Repair Kit for Hitachi convergence Chassis DP-14G
KIT10 Includes 2 pcs STK392-150 , 1 each of the following 1W axial lead fusible resistors:
http://www.digitalhome.ca/forum/showpost.php?p=564268&postcount=220
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Nov 13, 2007 | Hitachi 50FX18B/19K 50" Rear Projection...
Televison & Video Logo
148 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
