Question about Kodak EASYSHARE 5300 All-In-One InkJet Printer
Kodak aio printer 5300/software problem
My problem is the software that came with the printer can not download onto my computer (windows xp) coming up with error codes everytime the download gets to the Microsoft.Net Framwork part of the download. Then I get a error message that a setup package could not install.Dear Ron,
I have a huge problem with Kodak Easyshare software since updating it over the holidays while addding an ESP3 Printer.
My G610 Printer Dock no longer transfers photos; my computer keeps shutting off and a blue screen appears telling me Windows has stopped running to protect my computer; Easyshare will not import any photos from anywhere on my computer, even though I can transfer directly via USB from my camera into the Kodak files where they always went.
I have uninstalled, run the clear utility and reinstalled all the software for both devices 9 (yes, NINE) times. It won't work. I am no longer getting error messages, since I paid for a registry clean program to fix whatever errors it found. I also did a complete clean, with a disk cleanup according to Kodak directions on your website.
Yesterday, I had the pleasure of speaking with your technical support line. I was disconnected by four separate people. After speaking with Mark for 1 hour and 10 minutes, he began having me delete registry entries. I am an average consumer with average computer skills. I am not comfortable deleting registry information from my hard drive, because if something goes wrong, or we get disconnected, I'm screwed.
I have had 3 Kodak cameras, and although 2 of them have died seemingly early deaths, have been happy enough to buy new ones each time. I had a series 3 plus printer dock which I loved -- it too began tearing up expensive cartridges and destroying paper. I still went on and purchased a G610 because I liked the quality of my photos I could print at home. I just got the ESP 3 to replace a Lexmark because of all your marketing efforts.
Please advise me as to how to fix this nightmare. Sincerely,
Lynette Sadowy
  • 1 more comment
  • Lynette Sadowy
    Lynette Sadowy Jan 11, 2009
    Hi, thank you for responding and your suggestion to run a Windows Update. I guess I messed up my post and somehow included the post of another member. My question begins with the "Dear Ron" in the first paragraph.
    I did run Windows update, discovered it wasn't working correctly, had an 0x8007043B error,
    Searched for a solution to that error, downloaded and ran "dial-a-fix" which fixed my registry errors (BITS and WUAUSERV were not showing in the value data area under HKEY Local Machine something or other and I didn't want to do the suggested "regedit" process because I truly have no idea what any of this is).
    Turns out I needed to install Service Pack 3 update, which is now done. So thanks for that.
    Kodak Easyshare is still not working. I am going to uninstall it, run the clear utility and reinstall, all while crossing my fingers. Will keep you posted as to my progress.
    LS
  • Lynette Sadowy
    Dear Ron,
    Lynette Sadowy
    Comment posted on Jan 11, 2009
    Kodak Easyshare is still not working. I have uninstalled it, run the clear utiity, reinstalled it and it still isn't working.
    When I dock my camera, the green battery light just flashes, when I hit transfer, both lights flash continually, it goes through all the motions of transferring the photos, right up to letting me select the album I want to put them in, then tells me it's transferring them. After it reaches 100%, it issues a report telling me that some pictures were not transferred. None of the photos transfer and the lights continue to flash until I remove my V1253 camera.
    Any further help would be appreciated.
    Thanks,
    Lynette
  • Lynette Sadowy
    Thank you for your suggestion. I did do a System Restore as soon as I realized the new Kodak Software was not working with my camera and printer dock. It did not fix the problem. It's almost like the software has screwed up the printer dock and I can no longer get it to transfer the photos, even though my computer works perfectly well. Thanks,
    President:
  • 1,990 Answers
Welcom to Fixya! Ok-Unplug ALL of the Cables from the Back of your Printer. Uninstall your Software and Reinstall your Software. Then Restart your Computer. Plug the Cables back into the Printer and Run your Software and Set it up. Let me Know what you Get!
Posted on Jan 11, 2009
    President:
  • 1,952 Answers
Software resides on your computer and enables it to communicate with your device (camera, printer dock, photo printer, card reader, etc.).
Firmware is data or programs that are permanently written to the read-only memory (ROM) on a device (camera, printer dock, photo printer, etc.). The firmware holds code, which runs user programs.
Posted on Jan 07, 2009
  • 2 more comments
  • mohammed marika thambi
    mohammed marika thambi Jan 07, 2009
    www.kodak.com/global/en/service/downloads/dln_ekn033540.jhtml?pq-path=9106 - 44k -
    had a minor problem in that the printer would not scan to file in stand
    alone mode. I had to use software in the computer to make a scan. I
    send Kodak a question on how to rectify this. They recommended I
    upgrade the Firmware. This is where the problem started.
    I
    downloaded the Firmware file and then ran it. It caused the printer to
    turn on and off maybe a couple times and then the monitor said the
    computer was trying to re-establish contact with the printer. The
    printer was now off. At this point nothing else happened. I let it
    sit several hours with no change so I rebooted my computer and turned
    on the printer. I reinstalled the software and when it recognized the
    printer it said it needed to print a page to set up the printer.
    However when I clicked on print it just started feeding paper out. It
    would continue this until about five pages were fed through then it
    said it was out of paper.
    Now I talked with tech support for
    about six HOURS trying different things. We got to the point where
    they sent me a re-furbished printer. Problem now is that when I
    install the Easyshare software it reaches the point where it asks me to
    connect the USB cable. Once it recognizes the printer it asks what
    software I want to use. Here it doesn't matter what I answer, in about
    a minute the screen just goes black and the computer starts rebooting.
    It will keep rebooting itself continously until I turn the printer
    back off.
    The printer will work, I installed software on my
    laptop and it works fine. So the Firmware update has done something to
    some sort of software in my computer. I have all the latest updates.
    I'm
    using Microsoft Windows XP. I've tried killing my virus protection
    program, no help. Tried killing my firewall with also no help. Tried
    booting into safe mode with same result. The computer is a homebuilt
    PC with an AMD Athlon XP1700.
    I had the printer for a few months with no problem until I tried to upgrade the firmware.
    mohammed marika thambi Jan 12, 2009
    Sounds easy; reload a backup of your system from when print drivers
    worked okay. (Crashes and burns? It bluescreens after booting now?)
    Failing that, the simplest thing to do would be to install XP on a new
    drive and migrate data over once you got the printer etc. running.
    (Then set up backups.)
    If you want to deal with it as is,you need
    to run some monitoring software (Anvir Task Manager etc.) or otherwise
    unreel the install stuff to determine just where the Kodak install
    stuff is complaining, and get it to complain less. Some free tools out
    there can examine system access by a given program and log it; the last
    ones before the install stops (the ones that aren't just cleanup) would
    be of interest then! Some searching in the registry for the related
    keys ought to help (though there isn't anything particularly safe or
    relevant about your 'Kodak' search and destroy, sorry); try the usual
    regcleaner stuff, and don't forget to suspend your antivirus while
    rerunning the installation so that it doesn't get in the way.
    wareseeker.com/free-easyshare-5300/ - 56k
    Scholar:
  • 143 Answers
If u have a capple of earror's then i have to do reniall windows as par my opennion u have to format full pc with fresh installaction of windows then install all necessary software stape by stape
  • 3,037 Answers
Hi HockeyMom10
First of all, which problem is yours the top or bottom one? If it is the bottom one, the first thing I would try is a System Restore to a point before you started having these problems.
Go to Start>Control Panel>Performance and Maintenance> System Restore
let me know whether it fixes the problem or not, if not, then be patient and I will post back within 24 hours
bestdarngood
  • 59 Answers
Run windows updates and see if it helps. It could be a .net upgrade required.
  • Adam Jones Jan 12, 2009
    I would also suggest running combofix.exe on you computer. http://www.bleepingcomputer.com/combofix...
    Its very simple just download and run, it'll look kinda scary but trust me its an awesome program. There's a good chance you've got a virus or adware that corrupted your registry in the first place. Just download run and reboot. This will keep you from making manual registry entries or deletions that you are not familiar with. If you like you can post the scan file back here and I can take a look at it for you.
  • 837 Answers
I would suggest that you remove ALL and I mean ALL Kodak software then starting with the printer reinstall .. after each installation test the current and the previously installed software
  • Jay Glendenning
    Jay Glendenning Jan 07, 2009
    Have you tried any of the suggested "repairs" yet?
I have lost my disks fore Kodak easyshare Ai0 printer and have a new computer i would like it to work it with is there a way to get the software?
Welcome to FixYa.
You can download the installation software from manufacturer's support website by clicking this link
On the page which opens, click the "Download" button to start the download process.
Kindly refer the detailed installation instructions given on the download page to install the printer.
For your reference, here are the installation instructions again:
Installation Instructions
  1. Verify that your computer meets the system requirements.
    NOTE: WINDOWS XP 64-bit Operating System is not supported.
  2. Disconnect your all-in-one printer from your computer.
  3. Verify that you logged on to the computer using the administrator account.
  4. Close all programs.
  5. Download the software onto your computer.
  6. Double-click the *.exe file, then follow the on-screen instructions.
  7. When the installation is complete, connect your all-in-one printer to your computer.
  8. Select Start > Programs > Kodak > Kodak AiO Home Center.
Hope this helps. Thanks.
Nov 24, 2011 | Kodak EASYSHARE 5300 All-In-One InkJet...
I think im missing the driver for the scanner part of my 5300 kodak all in one, it wont comunicate with the computer dj icant scan a picture to the computer from the printer
Go to: http://support.en.kodak.com/app/answers/detail/a_id/32108/selected/true
Download the software for your Printer
  1. Verify that your computer meets the system requirements. note.gif WINDOWS XP Operating System, 64-bit, is not supported.
Mar 05, 2011 | Kodak EASYSHARE 5300 All-In-One InkJet...
HIGH DO YOU KNOW WHERE I CAN GET THE SOFWARE DOWNLOAD TO INSTALL MY AIO 5300 PRINTER ONTO MY COMPUTER?
Sure I do! You can find your printer software at Kodak's website. Find "downloads" and click on it. Then enter your printer name and model number and choose your operating system and follow the prompts from that point and your good to go!
Oct 01, 2010 | Kodak EASYSHARE 5300 All-In-One InkJet...
Kodak 5300 all in one printer will not scan. Cannot get on line with 5300 a10 home center program, tells me printer is not connected
try to unplug replug the usb cable of the printer.
You may also go to control panel printer and faxes and look for the printer of your 5300 now if you see 2 icons delete them both then exit to printer and faxes. and unplug/replug your USB cable then restart computer.
If this issue not solve try to uninstall the software and download the clearutility kodak.com/go/clear. then after doing this restart computer.
Nov 07, 2009 | Kodak EASYSHARE 5300 All-In-One InkJet...
Kodak esp 3 all in one printer home center wont work
hello,
Run the clear utility. Go to www.kodak.com/go/clear
Step by step instructions are provided in that website.
after that uninstall the AIO Home center.
In the Control Panel, select Add or Remove Programs (WINDOWS XP OS) or Program and Features (WINDOWS VISTA OS).
Choose KODAK All-in-One Printer Software
Click Remove (WINDOWS XP OS) or Uninstall (WINDOWS VISTA
OS).
When the Install Wizard appears, click Next.
Select Remove from the drop-down menu for the Kodak All in One Printer, then click Next.
Click Next.
Click Continue.
Thanks
Neerak21
Sep 25, 2009 | Kodak EASYSHARE 5300 All-In-One InkJet...
I have a kodak esp9 on win xp wireless connection. Constantly get the 1-2010 error code and kodak aio home center will not open and the printer will not connect any solutions?
  1. From your computer, access Device Manager.
    • For WINDOWS XP OS:
    • Right-click My Computer, then select Properties.
      • Select the Hardware tab, then Device Manager.
  2. Select View > Show hidden devices.
  3. Select Printers.
  4. Select Action > Uninstall.
  5. Select Action > Scan for hardware changes.
  6. Double-click the KODAK AiO Home Center icon. If the error occurs again, go to the next step.
  7. Set administrator rights for the Home Center application:
        • Right-click on the Home Center icon.
        • Click Properties.
        • Click the Compatibility tab.
        • Clear all the check boxes.
        • Click Apply and OK.
    1. Double-click the KODAK AiO Home Center icon. If the error occurs again, go to the next step.
      IMPORTANT: In the next step, before you install the Home Center Software, make sure you disconnect the USB cable. Then, connect the USB cable when the software installation instructions tell you to do so.
    2. Upgrade the software and firmware for your printer:
Jul 17, 2009 | Kodak EASYSHARE 5300 All-In-One InkJet...
Greetings Jackie,
Sounds like you have a failed .netframework installation. This is a Microsoft feature, but is delivered during installation of Kodak software as well. To fix this, do the following.
1. Open the Control Panel.
2. Double-click Add / Remove Programs (Windows XP only).
3. Select Microsoft .NET Framework 2.0.
    IMPORTANT: If other versions of Microsoft .NET Framework are listed, do not perform this operation on those other versions. Follow this procedure ONLY for Microsoft .NET Framework 2.0.
4. Click Change / Remove.
5. Select Repair, and click Next.
NOTE: A progress bar shows the repair progress.
6. After the repair is complete, make sure the Restart the computer check box is selected, and click Finish.
7. After the computer restarts, start the KODAK AiO Home Center software.
IMPORTANT: If the KODAK AiO Home Center software fails to start or continues to display an error message, completely uninstall Microsoft .NET Framework 2.0 and do a clean reinstall KODAK AiO Home Center software. The Microsoft .NET Framework 2.0 will also be reinstalled with the KODAK AiO Home Center software.
    1. Follow steps 1 - 4 above.
    2. Select Uninstall, and click Next.
      IMPORTANT: Uninstall ONLY Microsoft .NET Framework 2.0. If other versions of Microsoft .NET Framework are listed, do not uninstall them.
    3. Restart the computer.
    4. Perform a clean re-installation of the KODAK AiO Home Center software:
      a. Disconnect all USB devices from the computer, including the Kodak EasyShare all-in-one printer.
      NOTE: Do not disconnect your mouse or keyboard.
      b. Uninstall the Kodak EasyShare 5000 series all-in-one software:
        i. In the Control Panel, select Add or Remove Programs (Windows XP).
        ii. Select one of the following software programs from the list of currently installed programs, depending on which one appears in your list:
          • Kodak EasyShare software
          • Kodak all-in-one printer software
          • Kodak EasyShare 5000 series all-in-one software
        iii. Click Change or Remove (Windows XP).
        iv. When the Install Wizard appears, click Next.
        v. Depending on the issue(s) you are experiencing, do the following:
          • If you are experiencing errors with the Kodak EasyShare software, such as a Tricode, in addition to errors with the KODAK AiO Home Center software, select Remove, click Next, and follow the on-screen instructions for removing the software.
          • If you are not experiencing errors with Kodak EasyShare software, select Modify to uninstall only KODAK AiO Home Center software, and click Next.
        vi In the Custom Setup window, select Remove from the drop-down menu for the Kodak All-in-One Printer, and click Next.
        vii. In the Ready to remove the program window, click Next.
        viii. In the Uninstall Complete window, click Continue.
        ix. Restart the computer.
      c. Delete the files and folders that can interfere with the installation:
        • Printer folder in C:\Program Files\Kodak
        • Both the Eastman Kodak Company and KDS_Kodak folders in C:\Documents and Settings\All Users\Application Data
        • Kodak 5000 Series AiO folder in C:\Documents and Settings\All Users\Application Data\Kodak
        • Printer folder in C:\Documents and Settings\All Users\Application Data\Kodak\EasyShareSetup
      d. Run Disk Cleanup.
        i. Open My Computer.
        ii. Right-click Local Disk (C:) and select Properties.
        iii. Click the Disk Cleanup button.
        iv. When the Disk Cleanup for (C:) window appears, select the Temporary Internet Files, Recycle Bin, and Temporary Files check boxes.
        v. Click OK , then click Yes to delete all files and begin the Disk Cleanup.
        vi. When the Disk Cleanup is finished, click OK in the Local Disk (C:) Properties window.
      e. Shut down all background applications.
        i. Select Start > Run.
        ii. Type msconfig in the Open field, and click OK.
        iii. Select the Startup tab.
          IMPORTANT: If not all the applications in the Startup Items list are selected, write down which applications are selected so you know which ones to turn on again later.
        iv. Click Disable All , then click OK .
        v. When prompted, restart the computer.
      f. After the computer restarts, insert the KODAK EASYSHARE 5000 Series All-in-One Software CD into the computer CD drive to begin the installation.
      g. During the installation process, when prompted, select to search for an updated version of the software on the Kodak Web site and install the updated version.
      h. Before restarting the computer again, turn on the background applications.
        ii. Type msconfig in the Open field and click OK.
        iv. Under Startup Items:
          - If only some items were originally selected, select the check box in front of the items that you noted in Step e-iii.
          - If all background items were originally selected, click Enable All, and click OK.
      i. Restart the computer.
      Once restarted, you should be OK.If not call our 800 421 6699 and they will help further.
      Best Regards,
      Ron Baird - the friendly Kodak guy
Sep 18, 2008 | Kodak EASYSHARE 5300 All-In-One InkJet...
Kodak easyshare 5300 aio printer
i CANT OPEN MY AIO HOME CENTER WITHOUT GETTING AN ERROR THAT SAYS ENCOUNTERED A PROBLEM, HAS TO CLOSE. ALSO, MY PICTURES ARE NOT VIBRANT COLORS.
Jul 21, 2008 | Kodak EASYSHARE 5500 All-In-One InkJet...
Kodak EasyShare 5300
Sorry to hear about your trouble. Since I am not sure of the details, let me offer a long review and suggestion. It may work for you, especially if the AiO software is not installing correctly.
If the KODAK AiO Home Center software fails to start or an error message appears, there may be a problem with the Microsoft .Net Framework 2.0 installation. To resolve this condition:
2. Double-click Add / Remove Programs (for Windows XP) or Programs and Features (for Windows Vista).
4. Click Change / Remove (for Windows XP) or Uninstall (for Windows Vista).
1. In the Control Panel, select Add or Remove Programs (Windows XP) or Program and Features (Windows Vista).
2. Select one of the following software programs from the list of currently installed programs, depending on which one appears in your list:
3. Click Change or Remove (Windows XP) or Uninstall (Windows Vista).
4. When the Install Wizard appears, click Next.
5. Depending on the issue(s) you are experiencing, do the following:
- If you are experiencing errors with the Kodak EasyShare software, such as a Tricode, in addition to errors with the KODAK AiO Home Center software, select Remove, click Next, and follow the on-screen instructions for removing the software.
- If you are not experiencing errors with Kodak EasyShare software, select Modify to uninstall only KODAK AiO Home Center software, and click Next.
6 In the Custom Setup window, select Remove from the drop-down menu for the Kodak All-in-One Printer, and click Next.
c. Delete the files and folders that can interfere with the installation.
For Windows XP, delete:
i. Printer folder in C:\Program Files\Kodak
ii. Both the Eastman Kodak Company and KDS_Kodak folders in C:\Documents and Settings\All Users\Application Data
iii. Kodak 5000 Series AiO folder in C:\Documents and Settings\All Users\Application Data\Kodak
iv. Printer folder in C:\Documents and Settings\All Users\Application Data\Kodak\EasyShareSetup
For Windows Vista, delete:
ii. Eastman Kodak Company folder in C:\ProgramData
iii. Eastman Kodak Company folder(s) in C:\Users\your name\AppData\Local
Jan 31, 2008 | Kodak EASYSHARE 5300 All-In-One InkJet...
Home Center will not open...Can't scan
I needed to reload my AiO Home Center software and no one seemed to have the correct procedure. Maybe if you remove & reinstall yours it will resolve your problem. This procedure worked for me on my XP-machine:
1. got to Control Panel/Printers&Faxes and delete the printer
2. go to your Hardware/Device Manager/Universal Serial Bus Controllers, right-click on USB Composite Device and select Uninstall
3. go to Control Panel/Add/Remove Software and remove the EasyShare software
4. disconnect the cables from the Printer
5. download from Kodak.com the program "install_aio.exe"; run the program
(I selected only AiO+EasyShare+Software Updater to load)
6. followed the prompts after the sw installed to reconnect the Printer cables
7. rebooted
WORKED for ME !
Jan 13, 2008 | Kodak EASYSHARE 5300 All-In-One InkJet...
Kodak EASYSHARE 5300 All-In-One InkJet Printer Logo
22 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
