Question about HP Pavilion dv1000 Notebook
RE: HP laptop no power
I ma just wondering what might be the cause if ever the problem is really on the motherboard?Because the last time I used it, its still working fine.
Thanks!
  • jafacan Jan 18, 2009
    I have the same problem. My charger burnt out so i used my g/f charger for about a month, from a similar model HP. One day the computer no longer took any charge ( I have tried about 10 diffrent chargers but nothing gives my comp any power) Is this something i can fix at home, or do i send her to China for scrap metal?
  • DEKR
    DEKR May 11, 2010
    you have no power at all
    Did you ever have trouble charging the battery did you have to get the plug in a certain position for it to charge
  • 41 Answers
Give this a try -
1. Unplug all usb devices.(Printers, MP3 players, webcams, etc etc)
2. Remove the battery and power cable.
3. Press and hold the power button for 30sec.
4. Plug in just the cable (no battery)
If this doesnt work then it most likely needs a repair.
Also check the USB & power port for damage or if the charger jack is loose when you plug it in.
Posted on Jan 18, 2009
Problem with HP dv3 power cables.
Sounds like the charging board may be malfunctioning/shorting out inside the laptop itself causing these ac adapter failures.You really need to have it looked at before other it causes you motherboard to fail or any components connected to it.The power jack may be shorting as well which is attached to the motherboard
Dec 17, 2011 | HP Pavilion Dv3-1075us Notebook
HP compaq 6730s laptop won't turn on
I have an hp 6735b that shut down on me and wouldn't restart due to a heat related problem on the motherboard. I wound up replacing the motherboard for $115 from getcomputerparts.com in China. And, the labor was like $75 to do the job at a local computer shop. I understand that hp laptops have a problem with dust building up in the fan area and causing the motherboards to overheat, melting solder on the video chip.
Some companies can 'reflow' the solder by disassembling the laptop and applying heat to the video chip with a reported 90% success rate for a fee of $75 to $125, I've read on Ebay.com.
Good luck with this repair.
Dec 10, 2011 | HP Compaq 6730s Notebook
So all am seeing here are suggestions so what really works cuzz my hp pav dv6000 was working well last nite swtchd it on in the morning and nothng only the blue lights but the screen is not coming on..is...
your motherboard has overheated causing the connection between your motherboard and your graphics card to become corrupt. you need a new motherboard or to get the one you have reflowed. sorry to give you bad news
Jan 13, 2011 | HP Pavilion dv6000z Notebook
Hi, I really need some help. I want to know whats wrong before taking my hp pavllion dv600 to service centre. Problem is that the charger doesn?t charge the battery at all. Charger is fine with other...
If the power supply does not run the laptop without the battery, then the problem is the jack in the laptop, over time the plug breaks free of the motherboard causing intermittent operation or no power. If the power supply runs the laptop without the battery, it is the charging circuits on the motherboard that is the issue.
Jan 04, 2011 | Computers & Internet
I have a hp pavalion dv6000. It is not coming on.
there is a motherboard issue with this model. hp did offer a free repair on the motherboard.If you still have warranty, then you will need to contact hp to get your laptop motherboard repaired. they also offered an extended warranty due to this problem, you will really need to contact them ASAP so that you don't loose out, cause the motherboard replacement cost is around $600USD.
Sep 25, 2009 | HP Pavilion dv6000z Notebook
HP Pavillion HDX 9000- No Power I was using the laptop when suddenly I got a message saying I had mimimal battery power and I needed to plug in my AC power. But the AC power supply was already plugged in....
Sandytoo,
Sometimes the AC port on the motherboard can become loose or disconnected and will cause the powercord to not charge to the batteries or run power to the motherboard. If you changed out the Power adapter and that didn't help, then this would be my best assumption. The AC connection on the motherboard can be replaced pretty easy by someone knowledgable in motherboard repair with sodering. Most of the time with this issue, a motherboard replacement is not required, Even though its alot easier to just replace the board. Most Repair places will probably talk you into replacing the board, even though its really not necessary, with this issue.
Sep 22, 2009 | HP Pavilion dv9000z Notebook
My hp laptop won't start.
This is more than likely whats going on
HP website says what to look for
"HP has identified a hardware issue with certain HP Pavilion dv2000/dv6000/dv9000 and Compaq Presario V3000/V6000 series notebook PCs, and has also released a new BIOS for these notebook PCs, version F.39 for dv2000/V3000, and version F.3D for dv6000/dv9000/V6000."
Good luck..
Aug 18, 2009 | HP Pavilion dv6000 dv6100 dv6200 dv6300...
HP Pavillion 6000 battery issues
Hi Steve, If you haven't gotten any batteries to work properly at all and the problems are different each time, I would say the motherboard is shorting out the batteries and causing weird problems. One last thing to try if possible..
Try a known good working battery, if that battery doesn't work then its verified that the motherboard is bad. If the known good working battery works in that laptop then you got a bad batch and it will be a battery problem.
Since your laptop turns on with the ac adaptor means that the ac adaptor is good.
Jun 02, 2009 | HP Pavilion dv6000z Notebook
HP Pavilion tx 1000 Won't Start-Up
as a last resort,(or first, when I have laptop boot problems, is to unplug battery and power, and hold power button down for about 30 seconds, release, plug in and test.This Solves alot of laptop boot problems regardless of manufacturer. Hope this helps, if so thanks for any ratings
Mar 31, 2009 | HP Pavilion TX1000Z 12.1" Touch Screen...
HP dv8000 power source problem
There is a class action lawsuit currently being initiated against HP for this issue. The Complaint alleges that HP misrepresented and concealed material facts regarding certain laptops including a design defect, which causes the power jacks of the laptops to fail.
Sign up here:
http://www.sfmslaw.com/pages/cases.php?id=300
Dec 04, 2008 | HP Pavilion zd8000 Notebook
HP Pavilion dv1000 Notebook Logo
122 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
