Question about Whirlpool Ultimate Care II LSQ9549L Top Load Washer
Washer tub seems to be continually out of balance
Even with a minimal amount of wet clothes, the tub seems to continually rock back and forth. I'm thinking that a previous washer had rubber straps on each corner of the tub that held the top in place while the tub spun, but I can't seem to get the top off without taking the whole thing apart...
  • 2 more comments
  • ackhouse4 Jan 08, 2009
    seems out of balance when spinning and clothes arent wrung all the way dry
  • Ladybug Feb 11, 2013
    Is the machine standing reasonably level? We have a whirlpool and if it is standing 2 inches to the left of level it's goes out of balance. A word to the wise: Don't run a washer if you are not home : I've had a washer literally walk 2-3 feet away from it's spot before shutting off. I Suspect a belt may be stretched out. Also when loading things make sure the load is balanced. It should run reasonably smooth and not rock back and forth. Checktheleveling legs - use a level!
    oh, and small loads are notorious. Try to throw an extra towel in with a small load to give it something to spin.
    In one place we lived the building superintendent had built frames around the washers to keep them in place if they did that. But I think it's better to get to the root of the problem. No washer should be strapped down - unless it's on a boat.
  • 90 Answers
You may have to turn your washing machine upside down and check the balance bolts and springs, to make sure that they are snug or secure.
Posted on Jan 19, 2009
Washer is always of balance
Is the machine level? Does it rock if you push down on any corner? The machine must be level with all 4 feet firmly settled on floor. If you are satisfied level is good then open the loading door and move the tub back and forth (kind of vigorously, but no need to get carried away.) You should hear sloshing sound from the balance ring. If no slosh balance ring will need replaced.
Dec 29, 2012 | Whirlpool WTW6400SW Cabrio Washer
Washer will not spin at all no code . will drain and tumble back and forth,when it comes time to spin it turns off.
A washing machine is basically a big tub that repeatedly fills with water and then drains, spins to wring clothes dry, and has a device for stirring things up-- either an agitator in the middle of a top-load machine or a rolling drum in the case of a front-loader.
The four cycles that every washer performs are fill, wash, drain, and spin. Though these functions are pretty basic, a number of things can go wrong with them.
There are a number of problems that you can fix quite simply; some issues, however, are better left in the hands of an appliance repairperson.Problems that commonly occur with a clothes washer are discussed in depth below.If your washer doesn't run, be sure it's plugged in and that the receptacle works (the circuit hasn't overloaded). Before working on the washing machine, be sure to unplug it.
To prevent problems, follow good maintenance procedures. Use the right amount of detergent for your washer and your water hardness, make sure the machine is level, and don't overload it for the cycle chosen.
Washing Machine Does Not Fill
If the washer doesn't fill, the water inlet screens may be blocked. Clean or replace them. (Check your owner's manual for the location of the screens; they're often located at one end of the supply hoses, or you may have to remove a panel to access them.) Other reasons for not filling may be that either the timer or temperature selector is broken--both of these are repairs for an appliance repairperson.
Washer Does Not Spin
If your washer doesn't spin, check to see if the clothes have jammed or are unbalanced in the drum before calling a repairperson. Unbalanced clothes will also cause a w
asher to shudder or "walk." If straightening out the load doesn't stop the washer from shaking, look at the feet underneath and be sure they are properly adjusted to keep the washer sitting level on the floor (you just turn them to move them up or down).
Clothes Are Wet After Spin Cycle
If your clothes remain wet after your washer's spin cycle, perform the following diagnostics:
1) Lift the lid during the spin cycle. If the tub is not spinning, you may have a damaged motor coupler. Call a repairperson to replace this part.
2) If the tub is spinning, recheck the load to make sure it is balanced. If you are certain the load is balanced but your clothes are still wet, you may need to call a repairperson to replace a damaged motor pulley, tub bearing, belt, or clutch.
3) You can also follow the troubleshooting steps outlined in "Washing Machine Doesn't Drain." You may have a problem with your drain hose or pump.
Oct 27, 2011 | Washing Machines
My maytag washer shake a end of rinse cycle.
After the rinse cycle, the washer rapidly spins the tub to get as much water out of the clothes as it can. It works basically the same way as a salad spinner. If the weight of the clothes in the washer is not balanced, the washer will shake and maybe even jump around during the spin cycle. This is pretty normal. If all of your jeans end up on one side, and your t-shirts on the other, the jeans will hold more water, their side of the tub will be heavier, and the washer will shake a lot during the spin cycle.
If the washer is shaking too much, open it after the rinse cycle (wait for the tub to stop before reaching in) and spread the clothes out evenly in the tub. Try to balance the weight. Then close the lid/door and let it continue spinning.
Mar 05, 2011 | Maytag Washing Machines
We just bought a front loading machine and it seems to have hardly any water while washing. How much water should there be? Right now it looks like only the clothes are wet but no other water sitting in...
Front load washing machins are very water conservative. In fact a lot of moldern F/L washers use so little water that it doesn't even come up to the bottom of the door.
If the machine completes it's cycle, it obviously 'thinks' it's getting enough water to continue..
IMPORTANT...Do not overuse detergent!! This can seriously shorten the life of a F/L...! You're treating the amount of water...NOT the amount of clothes...Happy Washing
Good luck....Nomess
Aug 04, 2010 | Samsung WF203ANW Front Load Washer
Washer Tub Balance
A "professional" does not really balance the tub of a front-loader, they balance the washer. You can do this as well... there are 4 feet, just get a level and move feet up or down to get the machine leveled. Check the horizontal level and then the vertical level. Not too hard unless the feet, legs, are rusted shut in which case you can attempt to shim it up. The unit should not rock back and forth at all in any direction when it it leveled. Front loaders will vibrate, sometimes a lot, until they reach the full RPM of the spin, this is normal.
Jul 21, 2009 | Washing Machines
Maytag neptune frot load will not reach full spin speed.
It will not spin while washing, it's more of a rocking back and forth. As far as the spin cycle. If it's not reaching full speed I bet you'll notice that it's not doing the full cycle because the load is bouncing around and cause the washer to shut off. take some of the clothes out and watch it spin the water out.
Mar 26, 2009 | Maytag Neptune MAH5500B Front Load Washer
How can i fix my washer myself?
The washer will not ever completely drain according to Maytag. A certain amount of water stays in the outter tub for balancing the machine for final hyper-spin. However if the machine is not spinning all of the water out and your clothes come out sopping the long thread I typed out to another person's about 2-3 questions up on the same topic
Dec 11, 2008 | Maytag Neptune MAH5500B Front Load Washer
There are only springs that balance the machine. An even amount of clothes inside the washer keeps it balanced. But on the ropers the tub is designed to be very loose like it is. Load the machine evenly and you should be fine.
Apr 26, 2008 | Roper RAS8445KQ Top Load Washer
Error code 20
i think your on the right track but a couple of things you need to know first that model washer wont spin tiny loads or one articles of clothing it has a device in the motor called a tacho generator to balance if you have only a small load it cant sense the balance and most of the time will only rock back and forth second your pump is the most likely culprit if you look in side the washer you will see a seem in the tub next to that will be one of the washer tumblers take the screws out of that tumbler slide it forward there will be a hole there rotate the tub to your right and you will find the hole going down to the drain pump can check it there but i don't think you'll find any thing as that is a larger hole it think your drain pump is now if you have a shop vac this is time to vacuum the water of the tub and all the way down the drain hole for the next stage usally i tell customers to remove the drain hose from the stand pipe and vacuum the water ou of the washer from the drain hose but because of the pillow this might not work in your remove the two screws on the front lowerpanel and pull the panel
Jan 13, 2008 | Frigidaire ATF6000ES Front Load Washer
Does this happen with every load? I've had this happen occasionally but it was caused by one or two heavier when wet pieces of clothing that caused the tub to get off center and it would wobble out of control. By just rearranging the wet clothes to balance the tub it stopped wobbling. But only after making sure that the heaviest objects were on opposite sides if the tub.
Nov 11, 2007 | Washing Machines
Whirlpool Ultimate Care II LSQ9549L Top Load Washer Logo
168 people viewed this question
Dan Webster
Dan Webster
Sal De
