Question about Philips Magnavox 9P6034C 60" Rear Projection Television
WONT TURN ON
I REPLACED THE COOLANT IN ALL THREE PROJECTORS,I TOOK THEM OUT SO NOT TO GET THE FLUID ON THE CIRCUIT BOARDS. I TOOK THEM CAREFULLY OUT ONE BY ONE AND MADE SHURE HOW THE WIRES WENT. AFTER THEY WERE DONE I WENT TO TURN ON AND GOT NOTHING BUT A CLICK. THE UNIT HAS POWER AND I MADE SHURE THAT ALL CONNECTIONS WERE TIGHT. IT HAS ME PUZZLED PLEASE HELP
  • Philips Master
  • 3,459 Answers
Check the wires and boards to make sure they are all connected tightly.
Posted on Jan 12, 2009
Power bottom light flashes amber and the temperature light is steady amber after DMD chip replacement.
Sounds like a board problem or a bad temp sensor. Those things get pretty hot (charred) and you may have open circuit it when you swapped. Did you put the old one back in?
Nov 25, 2014 | Dell 4610X Wireless Dlp Multimedia...
IT POWERS ON , ONLY BRIGT WHITE LIGHT APPEARS ON THE SCREEN.wHAT IS THE PROBLEM?
I had the same exact problem. I found a suggestion fix on FIXYA that actually worked. What is happening to your projector is that the video signal is not being comunicated to the lens. The reason for this is that the circuit board facing the back side of the projector has a connector about 2" wide and aprox. 1/8" thick at the bottom left corner that inserts into a socket located on back of the lens. This connection comes loose due to dropping of the projector or in my case after I opened up the projector and lifted the top circuit board up to remove the third single fan for lubrication.
What you need to do is open up the projector by removing the lamp first (three philips screws), then remove three torx screws that hold the bottom casing to the top casing (screws about 1 1/2" long).
Carefully lift the top cover making sure the rear connectors clrear.
Using a thin wooden or plastic ruler or any other flat tool no wider than 1", very carefully insert the ruler down the space between the plastic casing and the rear circuit board towards the left corner. once the ruler is all the way down, try putting enough presure against the circuit board untill you see it and even hear it seat fully against the lens.
Be very carefull not to drag the ruler against the circuit baord or cause any damage to it.
Nov 22, 2012 | InFocus LP70+ Multimedia Projector
Sanyo plc xu115 new bulb wont fire. power light turns green at first but after a few seconds it turns flashing red. the old bulb exploded on this projector.
Could be a burnt capacitor on the circuit board. Replace capacitor if you can determine which one it is. There are only a few.
Apr 20, 2011 | Sanyo PLC-XU115 Projector
If I turn on the main power switch to my projector, the led's on the power switch and the 4 way (left, right, menu exit) switch come on, however, the power indicator does not nor does the lamp. I just...
I had the exact same problem, I followed the advice of Victorbello on this site, and found a bulging capacitor where he suggested to look. Read where below.
I soldered in a new one from Radio Shack ($1.50) and the projector works again.
PB6200 symptoms: Back fans were not working Bulb won't light (but is in perfect condition) LEDs on control light, but not three status LEDs Internal fan will not turn off.
Solution: The mainboard had a bad capacitor The board is the one where all 3 fans are connected, and which is facing upside down on top of the powerboard.
The bad capacitor on my projector was a 25V 470uf 10mm diameter, 16mm high, 5mm lead spacing capacitor.
"I recommend you to open your projector, unplug all connections to the fan board, turn it upside, and inspect the capacitors and other components. Bad capacitors have a bulge and/or a black stain or fluid coming out on the top."
Apr 11, 2010 | BenQ PB6100 Multimedia Projector
My VPL-VW50 suddenly stopped working a couple months ago. It turned on, the fans started, then it would stop and a red light began blinking three times. I looked up the code and found that it needed a new...
fisrt, did you reset the lamp timer? if the projector turns on again, go into the menu settings and reset the lamp timer. 3 flashes also mean that the lamp is too hot. let the projector go through it's cooldown mode and shutdown before you unplug it. remove the filter case and vacuum or blow the dust out of the filter. you can also blow the dust out of the projector (if any) with canned air. lastly, be careful where you buy lamps from. you get what you pay for. cheaper isn't always better.
Dec 08, 2009 | Sony VPL-VW50 Projector
Oil leaked from rear projector tv's central projector
The substance that you are looking at is ethylene glycol, which is better known as anti-freeze, but it is optically clear. If it leaked on to a circuit board, this is not a good sign. I have not been able to repair a set that has been contaminated with this fluid. If your set still works you can replace the fluid and the set will be fine, do not run the set without this fluid as it will cause the CRT to overheat and may crack.
I usually order my parts from Andrews Electronics in California, they will have the OEM components that you will need.
Their site is http://www.andrewselectronics.com/welcome.aspx
And their phone number is a 24-Hour Order Desk: (800) 274-4666
I recommend the phone order so you can talk to the person about type of fluid that you need. I think it is referred to as CRT coolant, and is sold by the bottle.
I hope that this helps
Thanks for using fixya
If you need any further assistance please respond to this post.
asnowman
Oct 05, 2009 | Televison & Video
Projection oil spill on main circuit board
The coolant in the CRT's is made up of 70% ethylene glycol and 30% glycerin. The coolant is highly conductive and somewhat corrosive. Since you already tried to turn it on im not sure but hopefully you wiped it up first. Take some 100% denatured alcohol and use that to clean the spill you can just pour it on and wipe it off with the set unplugged of course. then let the remainder on the board evaporate (It evaporates very quickly when open) and repeat the process. if your lucky and it did short the first time you turned it on the fuse just blew.
Jan 20, 2009 | Philips Magnavox 9P6034C 60" Rear...
Just got a broken TV
Man you may have a big mess on your hands the cooling fluid has probably gotten on a circuit board(s) and ruined it them and using the set with a cooling fluid leak is dangerous. You may need to replace the small signal board large signal board and the cooling fluid in the crt. I suggest this job to a pro
Sep 26, 2008 | Philips 9P6444C 64" Rear Projection...
51 magnavox projection tv-color mixing wrong
The are controls on the inside of the tv above the circuit boards for focus and to turn up intensity of the projector lamps (red, green, and blu). If you turn it up too far all three projector lamps kick off. If this happens, power off the set and turn down the lamp that you turned up. Power it back on and slowly turn the projector lamp up until the picture looks OK. You have to take off the panel on back of set to get to the controls.
Nov 19, 2007 | Philips Magnavox 51MP392H Rear Projection...
1998 mitsubishi big screen model VS-50603
this model is famous for fluid leaks. each projector tube has a reservoir on the front of it with a fluid in it. this keeps the face of the tube cool.
this depends on how bad the damage is in the tv. in most cases we can reseal the tube and clean up the fluid 400-600.
Once you
take the tube out you will see where it leaked. The problem is that the
frame on the CRT that the heavy screws with springs are mounted on (that
hold the lens coupled to the CRT) is weak and they can bend. We have seen
several that have leaked after the customer moved the set. You can only
tighten them down so much because the frame bends. It is just stamped metal
and not welded at the corners to support the bend.
We remove the CRT, clean it all up, add a very small amount of RTV sealer to
the gasket, reassemble, let the RTV cure thoroughly and refill with coolant.
The extra sealer should prevent future leaks. Haven't had a recall yet.
Mits says replace the CRT...too costly.
You msut check the yokes carefully as well. If any coolant gets into them
you can end up with shorts there and a mess.
Clean the boards carefully and repair any corrosion damage. The coolant is
ethylene glycol and glycerine which is water soluable.
Jan 12, 2007 | Mitsubishi VS-60707 60" Rear Projection...
Philips Magnavox 9P6034C 60" Rear Projection Television Logo
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
