Question about Jenn-Air JES8850 Electric Kitchen Range
Jenn-air JES8850AAW range touchpad keys 7-0 not working
I purchased the range in Oct 2002. The touchpad keys 7,8,9,0 stopped working recently. I'm suspecting I need to replace the control panel or the electonics behind it. Both are expensive parts. Is there a way to diagnose which part is bad. Or is there a secret to get these touch buttons working again?
Thanks!
  • Anonymous Jan 23, 2009
    I have the same problem.
  • frcom Apr 22, 2009
    same problem, on my Jenn-air model JES9800ACS (bought november 2002) the buttom 0, 9 , 5, 1, "vent fan and now "convect roast" is not responding. Only the touchpad need to be replace but all the panel including the touchpad is avaiable for replacement.
5 Suggested Answers
SOURCE: Jenn Air JGS8850ADS Range
this model is a lemon. Maytag knows and does not care. My panel has been replaced 8 times already. Stay away from Maytag.
Posted on May 25, 2007
SOURCE: jenn-air jes9800AAB keeps buzzzing, front function panel flashes on and off
Your control panel is getting ready to quit. Mine did the same thing, I ignored it and now nothing on the touch panel works. About $150.00 for the part.
Posted on May 30, 2008
SOURCE: Jenn Air slide in range JES9750AAB - Touch Pad
put on tree belt . having the same problems replaced ERC $200.00 now they are telling me touch pad touch pad is $240.00 .the stove cost $1300.00. $1740.00 how much more will i have to put in this stove
Posted on Jan 06, 2009
ee-214 m-214
Posted on May 30, 2009
fixyourboard
  • 310 Answers
SOURCE: Jenn-Air model #sve47600b. Today put new display
Make sure that you properly plugged in the keypad cable. There is the wide connector that brings all the keypad touches up to the display board, and there is the small 4-black wire connector that brings power to the control board.
For future reference, we repair electronic control boards at www.fixyourboard.com, maybe we can help you in the future.
Posted on Oct 08, 2009
Jenn-air Model S176 shows a f1 fault.....will not stop BEEPing......oven and burners work
The F1 error code means that the computer thinks a button on the touchpad is stuck. Sometimes this can be resolved by making sure the touchpad connector fits tight into the control board. The F1 code can be cleared by pushing CANCEL/OFF. If it returns the touchpad needs to be replaced .
Aug 08, 2011 | Kitchen Ranges
The Jenn-Air Gas Range Electronic touch control 800. The key pad does not work. You can not set the clock or work the oven. Help.
My Jenn Air has the same problem with the computer touchpad. The only temperature I can get to work is from the left hand column, 411 degrees. I don't want to waste another dime on this oven. I've read so many complaints from other owners. No more Jenn Air products for me.
Nov 22, 2010 | Jenn-Air Ovens
Jenn Air slide in electric range JES8850 - numbers 9 and 0 no longer work on the touch pad. Trying to find the part number for replacement touchpad
Hi, could you send me the complete model and serial numbers from the tag on the range? There are some letters after the JES8850 that are needed to look up the correct parts.
Thanks!
May 13, 2010 | Jenn-Air JES8850 Electric Kitchen Range
Trouble code F1-7 on display. What does that
its confused. the problem maybe in you touchpad menbrane
Feb 15, 2010 | Jenn-Air JES9750 Electric Kitchen Range
F1 fault code on Jenn-Air jwg 8130
hi,
The F1 ErrorOn a number of ranges this can mean a number of things, the most common being a failed ERC(EOC, Clock assembly)or a faulty touchpad. Firstly if you are using a recent Maytag range it may pay to test the oven sensor as described above as this may cause an F1 error if faulty (may apply to some other ranges as well) this is not a common cause but is worth discounting. To check the ERC and touchpad
Disconnect the power
Gain access to the back of the ERC
Disconnect the ribbon cable that connects the ERC to the touchpad
Check nothing will short when power is reconnected
reconnect the power and switch on
Watch for F1 and listen for the beep
If you get the F1 and the beep this means the fault is with the ERC and it will need replacing
If after 30 mins you do not see the F1 error and hear the beep, replace the touchpad
or follow the link for more info:
http://www.appliancefactoryparts.com/applianceshvac/help-center/fault-codes/fault-codes-ranges.html#Admiral
thanks for your question.
Jan 03, 2009 | Jenn-Air JGW8130DD Gas Single Oven
Two of the oven controls do on function on SVE47500W
We own a Jenn-Aire model W27400W oven. The display module has gradually gone dim over a period of several months prior to the end of the warranty, and the display is no longer visible. It is apparent that several Jenn-Aire oven models use the same display. Does Anyone else have the same problem, and If so, are they willing to join a class-action suit against Jenn-Aire with us?
Steve Patterson
303-256-8494
stevieb4019@comcast.net
Nov 24, 2008 | Ovens
Jenn Air Oven Model # SVE47600B Error Code F7
I have a jenn air SVE47600F.It just started beeping and giving a code 7.None of the controls work when it brings the code up,but controls work fine when code is not there. We have to turn the breaker off to reset it.Sometimes when we have been gone all day we'll come home and the range will be beeping and flashing a code 7
Sep 09, 2008 | Jenn-Air SVE47100 Slide-In Electric...
Jenn-Air Convection Oven
Our 7 year old "Jenn-Air Convection Oven", Canadian Model # SVE47600 also has a very dim display. We can barely read the temperature on the oven. Does anyone know what is wrong, how to fix it, and what it may cost us?
Dec 20, 2007 | Jenn-Air SVE47100 Slide-In Electric...
Numbers
This is the same problem I'm having with my Jenn-Air electronic touchpad. I see you posted on Nov 26, 2007, but don't see an answer. I just posted my problem today (Jan 2, 2008) and hope to get a response. I have in the past had to have something behind the touchpad replaced, for a different problem. I don't like these touchpads, and would rather have mechanical controls as I had on my other 2 Jenn-Air ranges. If your warranty is still good, call and get it taken care of before it gets expensive. Since I didn't have any more problems for a couple years I didn't continue to purchase Sears' warranty. Now will try to fix it myself. I think a $1500 machine should be better built. One thing I did read, not on this site, but elsewhere, was to be careful to not get any kind of liquid on the panel. How does one do that and keep the steam and splatter cleaned up?!!!
Nov 26, 2007 | Jenn-Air JES9860 Electric Kitchen Range
Touchpad woes
I had a tech come out and look at mine and he told me that the F1-8 means a faulty touchpad. He wanted nearly $600 to fix it. I had already taken mine apart and put it back together so I knew it wasn't a really tough fix. A little challenging but possible for anyone that is a handyman or woman. I found the touch pad online for $230 and just completed a successful installation in about 1 hour. Unfortunately, the repairman said that you have to purchase the entire front piece - the metal panel where the touchpad is imbedded. Once I removed the panel, I pulled the touchpad off and it had a price tage of $26 and a part number, so now i'm looking online to see if you can purchase just the touchpad. At any rate, even if the touchpad can be purchased separately, you still have to remove the front panel to install it so that you can plug the ribbon cable in.
Sep 24, 2006 | Jenn-Air JGR8850 Gas Kitchen Range
Jenn-Air JES8850 Electric Kitchen Range Logo
551 people viewed this question
Top Jenn-Air Kitchen Ranges Experts
Mike Carew
Dan Webster
Dan Webster
 Fix Your Board
Fix Your Board
Are you a Jenn-Air Kitchen Range Expert? Answer questions, earn points and help others
