Question about Kitchen Ranges
My oven doesn't work
I am having a problem with my Kenmore Electric Range
(model # C880.666530.J0)
The cook top seems to be working fine, but when I try to turn on the oven it will preheat for 1-2 minutes and then the display screen will flash all of it's lights and then will read "PF 9:13" until i push cancel. At that point the "PF" is cleared but the clock still reads "9:13" and continues telling time from this starting point. Can you guys diagnose this problem for me? It was suggested that I should replace the fuse, do you think this is the solution? If so, where do I find the fuse panel?
Thanks a lot for your help
Duncan
    Scholar:
  • 31 Answers
PF probably means "Power Fail." Check your manual to see if this is true. It seems that there is a bad connection or wiring somewhere on the path to the range that is causing the voltage to droop under load. Ensure the plug for the range is firmly seated in the socket and make sure the plug feels like it is making a good connection and is not loose.
The fuse is likely located behind the back panel on the range. If you feel comfortable doing your own repairs, disconnect power from the range and remove the back panel. Locate the fuse, remove and inspect it. If the fuse is okay, re-seat it and try running the oven again. You can also check the line voltage while the oven is running with a volt or multimeter. If the voltage droops excessively while the oven is on, this indicates a bad connection or inadequate wiring. If the voltage is okay, the oven controller might be malfunctioning. If you aren't familiar with using checking the line voltage, you might want to call and electrician or appliance repair man. Is this range under warenty?
Posted on Jan 07, 2009
Oven will not maintain heat
possible thermostat problem in the switch
call the technician or get the part from tyhe servide agent spares
Feb 28, 2018 | Whirlpool Ovens
The rarely-used back right burner on my glass top GE electric range doesn't work, but the rest of the burners and the oven seem to be working just fine. Is this something I can fix myself, or do I need to...
Open the oven door and look for screws that hold the cook top down. Take those out and the cook top lifts off from the front. Make sure that you unplug it first. Then you can see the coil that is not heating. IT could be the wires, connector or the coil itself that is bad.
Sep 27, 2013 | Kenmore 95592 / 95594 / 95595 / 95599...
The oven heating element won't turn off
I would thing if you called an appliance service store or retailer and gave them the make and model number of the stove they can sell you one and maybe install it if you need them to but I would thing it would be called the oven switch
Jul 24, 2012 | Kenmore 91112 / 91114 / 91117 Electric...
Top heating element does not work but it still cooked our turkey in the cooking bag just fine. the stove is only a little over a year old.
If your electric oven is taking too long to heat or just not heating up right,then check out this tip that will give more detail about your problem.
Oven Problems Electric Oven is Heating Slowly or Poorly
heatman101
Nov 26, 2010 | Frigidaire FEF366 Electric Kitchen Range
Kenmore Gas Oven doesn't heat
Here is a tip that I wrote that will help you with that problem...
The ignitor for your burner has faied...
http://www.fixya.com/support/r3663023-oven_not_working_or_oven_not_heating
heatman101
Apr 07, 2010 | Kenmore 40494 / 40495 / 40499 Electric...
Gas range won't ignite. We had PGE and come over
This sounds like a failed burner igniter, also called a spark module. These are pretty easy to replace since the module itself is located at the back of the stove under an access panel. The price is around 40 to 60 dollars. Lately it seems that these newer stoves have weaker spark modules. I see dead modules on models less than 2 years old, where it used to be more like 5 or more years on the older ones.
Mar 24, 2010 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
Preheat taking long time
If your oven has the hidden bake element then it is probably working properly. A standard oven with an exposed bake element will usually take about 12-15 minutes to preheat. The hidden element models take a little longer but they usually heat a little more evenly.
Post back if you have any more questions.
Oct 29, 2007 | Kenmore 96212 / 96214 / 96219 Electric...
Oven gives me an -F3- message and stops working
F3 - E0 Oven temperature sensor or oven temperature sensor fuse opened Replace oven temperature sensor or fuse
May 21, 2007 | Kenmore 91112 / 91114 / 91117 Electric...
Kitchen Ranges Logo
308 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
