Question about Zerus Intel Desktop Board D815EEA (Z-D815EEA) Motherboard
I need a pin diagram.
I have an Intel D815EEA motherboard.Switched towers.Forgot to write down the pin diagram for the front panel connectors.Does anyone have a pix with the locations on it?
  • Anonymous Apr 30, 2009
    i want know the pin diagram for zener diode
    Problem Solver:
  • 7 Answers
Pin diagram of motherboard....?which model...
Posted on Jan 07, 2009
Hello .i want know where power led and sw wire go connect on a emachine T3626 i desconnect my self and i forget where the go please help me
ftp://download.intel.com/support/motherboards/desktop/d815eea/a1696401.pdf
If you do not have pdf viewing capabilities, your browser will prompt you to install the plugin, please allow this install once you've followed the above link. In the pdf document, refer to table 48, on page 71 for how to connect your front panel.
Nov 22, 2010 | Zerus Intel Desktop Board D815EEA...
I need the order for placing wires black in place. for front panel and reset, L ED. placement order for which they are placed back on the switch.
The wire placement is usually written small right on the motherboard. Each front panel connector should be labeled.
Here is the owner's manual for the motherboard:
http://download.intel.com/support/motherboards/desktop/d815eea/EA_ENGLISH.PDF
(Hint: Copy the whole link to notepad, make it all one long sentence, copy again and past into your browser)
Mar 22, 2010 | Zerus Intel Desktop Board D815EEA...
Unable to find the power switch to connect to
If you no longer have the manual for you're Intel D815EEA motherboard, open the link provided and download it; http://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&DwnldID=17793&ProdId=385&lang=eng
You will also need Adobe reader installed to view the manual; http://www.adobe.com/products/reader/
Read over pages 65 to 68.
Once completed turn to page 68 Figure 23. Front Panel connectors. Figure 23 shows two views.
View - (left figure), shows J9C1 as you look down at the front panel pins. The right figure will not be needed. Connect each jumper or each pair as shown.
Wire colors are important and do vary from case to case. The common color of each pair will most likely be used for negative. Wire colors such as blue, light blue, green, light green, red and light red are commonly used as positive.
Pin 1 will be positive and pin 3 will be negative. This is letter - C. Hard drive activity LED.
Pin 2 is positive and pin 4 is negative. Case power LED, and so forth.
As mentioned on page 65, the case front panel pins use 5 volts DC. If you make a mistake and place a jumper backwards (No LED light), just power off the switch on the back of the power supply and correct the jumper by turning it 180 deg. If you’re case’s LEDs do not light up than you will need to connect letter G and letter H. The electronic circuits under the motherboard should supply all 16 motherboard pins with the 5 volt DC and ground needed.
Cheers'
Mike
Feb 28, 2010 | Zerus Intel Desktop Board D815EEA...
What is the pin diagram for bcd to excess-3 code
bcd to excess3 code converter pin connection diagram
Nov 17, 2009 | Zerus Intel Desktop Board D815EEA...
I can not find the matching pinsforthepwsw hdd led
Open the Intel link provided; http://downloadcenter.intel.com/confirm.aspx?httpDown=http://downloadmirror.intel.com/17793/eng/motherboards_desktop_d815eea.zip&agr=&ProductID=&DwnldId=17793&strOSs=&OSFullName=&lang=eng
Create a folder on your desktop and name it, Intel D815EEA
Download the file named, "motherboards_desktop_d815eea.zip" in to your Intel folder. The *.zip file must be uncompressed. You can download and install a 45 day free trial program called WinZip. Download WinZip from here; http://download.cnet.com/WinZip/3000-2250_4-10003164.html the program named Winrar will also uncompress the file; http://download.cnet.com/WinRAR-32-bit/3000-2250_4-10007677.html
Once the either program has been installed open the Intel folder. Right click once on the file *.zip and from the pop-up window and click, Extract Here. You will need Adobe reader to view the PDF file. Adobe is free; http://www.adobe.com/products/reader/
Open the PDF folder. Open the "A1696401.pdf" file. This is the manual for your D815EEA board.
Open to page 69 motherboard layout. Item "C". Find pin 1. You can zoom in with Adobe by clicking the + sign in the tool bar. Than go to, Table 48. Section 2.8.3.3 page 71 in Adobe.
Front Panel Connector. Example:
Pin 1 is power for the HD_PWR = Hard disk drive, Power LED. Pin 2 is ground for the HD_PWR. ECT...
Case wire colors vary. Normally the solid colors red, green, blue and green are positive. Except black which is usually ground for the internal speaker.
The wire color solid white is usually - negative. So each pair will have a common wire color used for negative.
Hope you find this helpful.
Cheers!
Mike
Oct 17, 2009 | Zerus Intel Desktop Board D815EEA...
How to cnnect the light cables Power and reset............etc of intel mother Board d815EEA
Connector number J9C1 - power LED pin 2-4, reset switch pin 5-7.
1-3 - hard drive activity led, power switch 6-8 pins.
Connect and enjoy :-)
Aug 10, 2009 | Zerus Intel Desktop Board D815EEA...
Moniter Data Cable Pin Connections
Download the user's manual. Usually such information is given there.
Jul 17, 2009 | Zerus Intel Desktop Board D815EEA...
ASUS M3N-HD - CASE (w/ PS): Foxconn- TSAA-725 . The problem is that the case has a Power led connector which doesn't fit with the module on the board. It like CASE: 10, MB: 1-0. "-" stays for a space...
So, the M/B has a 3 pin connector, but your case only has a 2 pin connector? Easiest way is just to cut the connector from the case in half with a pair of sissors.. It isn't the most nice solution, but it works quite well!
Jun 02, 2009 | Zerus Intel Desktop Board D815EEA...
Can u tell me the pin arrangement for front usb?
where the PIns there is a small shema please try to read it then u willfigure out how that
Feb 22, 2009 | Zerus Intel Desktop Board D815EEA...
How to connect Power LED, Power SW, Power Reset and HDD LED
it is written in the motherboard..
re-reset botton
pw- power botton
hdd led- hard disk led
pw LED- power led
the code is pin 1....
Jan 28, 2009 | Zerus Intel Desktop Board D815EEA...
Zerus Intel Desktop Board D815EEA (Z-D815EEA) Motherboard Logo
889 people viewed this question
Top Zerus Computers & Internet Experts
David Payne
David Payne
Are you a Zerus Computer and Internet Expert? Answer questions, earn points and help others
