Question about Pyramat Sound Rocker Gaming Chair
No sound and how do you connect to a wii system
Just makes a hissing sound and how can it possibly hook to a wii system which has square plug ins in back and rocker has regular speaker plug ins
  • 3 Answers
We hooked up the remote to the television set and had no problems. Could the problemn be the chair???
Posted on Jan 11, 2009
How to hook up the wii cords
First, you are posting a question about the Wii under the PS2 heading. Problem number one! Number 2! If your TV is new enough, it might not have the connections for A/V jacks like the yellow red and white. Here is how they connect. Yellow, video, Red, right sound, white, left sound(mono)
Jun 11, 2014 | Sony PlayStation 2 (PS2) Console
I have a intec for the wii induction charger how do i hook it up it didnt come with directions
The square shaped plug goes into the back of your Wii where the power cord usually goes. The power cord for the console then plugs into the other end of the square piece.
Jan 03, 2011 | Nintendo Wii Console
I stopped getting sound from the microphone on rockband 2 for wii. Bought a new one, same problem. Bought a new disc, same problem. I hooked it all up to a new system and now all the instruments show they...
I would have checked the USB dongle that you are probably plugging into. There are many things you can check... 1.) usb dongle 2.) mic volume in the game. 3.) way you are using the mic 4.) for the new problem with no sound - make sure you have batteries in your instruments, they are plugged into/connected to the system (synched) and turned on. That you have a good connection from system to the stereo/tv audio.
Jan 02, 2011 | Nintendo Rock Band for Wii
No sound on wii
Hello :
1: Make sure you have the volume on the TV turned up and the audio-video connections plugged into the same-colour plugs. Sound only kicks-in once you are at the Wii menu. If this doesn't work, continue to step 2.
2. Test the Wii with another TV. If you have sound there, then it is possible that the HDTV's sound inputs plugs are damaged. Send your HDTV off for repairs.
3. If the Wii does not work with the other TV, then it is likely that the audio cables are damaged. Order a replacement from Nintendo (instructions are in the Wii user's guide)
good luck .
rate please !
Mar 26, 2010 | Nintendo Wii Console
No sound for wii sports
Hi friend,
try this:
a). Make sure you have the volume on the TV turned up and the audio-video connections plugged into the same-colour plugs. Sound only kicks-in once you are at the Wii menu. If this doesn't work, continue to step b.
b). Test the Wii with another TV. If you have sound there, then it is possible that the HDTV's sound inputs plugs are damaged. Send your HDTV off for repairs.
c). If the Wii does not work with the other TV, then it is likely that the audio cables are damaged. Order a replacement from Nintendo (instructions are in the Wii user's guide),
I hope this will help you out.
Please vote for me thanks in advance.
Feb 09, 2010 | Nintendo Video Game Consoles & Games
Trying to hook my Wii up using the AV audio Jacks
Connect the Wii to your television. Then connect the variable audio output from the TV to the audio in on the monitor section of the receiver. Then use the TV/SAT input selection on the receiver and dolby prologic 2 as your sound mode.
Dec 23, 2009 | Sony STR-DE575 Receiver
Have good picture, but no sound from Wii
Make sure no other game console is hooked up to the spliter then turn everything off... turn the TV on first, then the game system, if the system still doesn't produce sound then get a NEW dedicated cable Hope that helps
Aug 21, 2009 | Nintendo Wii Console
Bought wireless connection still cant connect to internet on wii system Belkin_G_Wireless_9430BF is the namw of the wireless connector can connectwith ps 3 but not wii
does the wii see the router do you have a laptop to make sure its sending a signal try this dis connect everything plug in the modem let it symc up by it self then plug in the router and hook up the cat 5 cable to the router
the try to sync the connection with the wii by searching for the router
it helps to name your router first with a laptop but that should work if not let me know iam a cable tech with a few tricks
Aug 01, 2009 | Nintendo Wii Console
How to hook up wii to surround sound
You need to connect your amplifier to your TV, (Video Out of Amp to video In of TV), then select the input where you connected your WII in amp.
Or you could just connect the yellow plug to the TV directly, and the white and red plug to your amplifier.
A note thou, Red and White will not give "True" surround sound as it has only 2 channels, you need to connect a digital input to the amp to get true surround.
Let me know what happens
Alex
www.CAS411.com
Mar 15, 2009 | 2006 Chevrolet Uplander
The Wii will not come in color.
Check to make sure the component cables are hooked up correctly, or you may need another set. Try hooking the wii up on another tv if you have one to see if it's just the cable or maybe the jack where you connect it to on the device it's plugged into (i.e. tv or entertainment system)
Let me know if this helps.
Jan 25, 2009 | Nintendo Wii Console
Pyramat Sound Rocker Gaming Chair  Logo
301 people viewed this question
Top Pyramat Video Game Consoles & Games Experts
Michel Laprise Sr
Tom Chichester
Are you a Pyramat Video Game Console and Game Expert? Answer questions, earn points and help others
