Question about Zenith L13V36 13" Flat Panel LCD Monitor
Zenith L13V36 When I turn-on the power button to my 13" television, the screen goes on for about 1/2 second with no sound or picture (it's just black, but you can see the channel number in the upper right hand corner), then it automatically shuts off. What to do? Thanks so much for any assistance.
  • Zenith Master
  • 19,396 Answers
That sounds like a bad power adapter, a bad inverter , or a bad controller board.
When TV does not start, and sometimes you hear a clicking noise, that means that the TV is on protect mode.
Try first leaving the TV power cord unplugged for some times, let say one hour or so.
Also ensure that the fault is not coming from a faulty receiver box sending bad signal, check if you get same problem with no receiver box or dvd connected.
If that does not work, and you keep having a flashing led on front of the TV, and tv turning off by itself after a while, that indicates a fault condition.
The flashing light indicates a diagnostic state called protection.
When the TV goes on protection there are only two possible reasons.
1The internal circuits are jammed because of electrostatic charges accumulating on capacitors, or because of a wrong voltage read by the main chip on your monitor controller board. this started the protection circuit.
2 The protection circuit detected a wrong voltage or abroken contact, identified an internal fault and kicked in , startingthe flashing light.
If you are in situation one, then theTV will reset just unplugging power cord for one or two hours,sometimes even minutes.
If you are in situation 2 , then there is an internal fault.
Common faults that can occur are a blown capacitor on power board, a convergence IC has blown, or a fault on Digital board.
Check also the video cable or any external connection cable, if the cable is shorting, or the connector is bad, you can get same flashing state because of the video cable.
If under warranty contact the manufacturer ringing the number on the user manual
If you want to repair at your own expenses, just locate any good qualified repairer.
Posted on Apr 17, 2009
Samsung 50" led un50h6350. The TV is about 18 months old and the picture went out, the audio and back light are working. I've replaced the t-con board and that didn't fix it. Someone please help!
Samsung LED TV Screed goes blank periodically for 1 sec - Forums ...
www.cnet.com > Forums > Samsung
CNETJun 11, 2015 - Lately, my Samsung LED TV's screen will black out from 1 -2 seconds then come back. The TV has been ... The TV is about 6 months old. .... I've only notice this when I'm watching in HD. ... by Stlouib / January 13, 2012 11:18 PM PST ...Mine does the same thing - picture goes black for 1 - 2 seconds and then comes back. Samsung Series 3 (330), won't show any picture/no sound?
Jun 11, 2015
Samsung LCD TV LN32A330 power won't turn on
Jun 11, 2015
Black Line across Samsung 50" Plasma has appeared?
Jun 11, 2015
Samsung LED UN55B7100 turns off on its own.
Jun 11, 2015
More results from www.cnet.com
Are there still capacitor problems with Samsung TVs?
Dec 21, 2015 | Samsung Televison & Video
I get sound, can change the channels, etc, but my Polaroid television screen has no picture whatsoever; it's just a black screen.
lubbarlubab, Looks like you will need to get a power supply repaired/replaced in your unit. Before you call out the service guy, you should spend 30-40minutes at YOUTUBE and view some "LCD-TV repair" videos and also videos of "LCD monitor repair" and LEARN what are the most common components that are causing this plague of "BLACK SCREEN of DEATH" to disrupt your life. If the "cold-cathode-fluorescent-lamps" fail to light-up due to a failure of a single or multiple $2 parts on a power supply board you have a black screen!! This problem is also very common to LCD computer monitors. Try to view a vid by someone called "cal22583" who did his own repair to a Philips 42" or 50" unit. If this was of some help please rate on fixya.
Bye for now. 12fixlouie
Nov 08, 2009 | Zenith L13V36 13" Flat Panel LCD Monitor
Kenmark 20" LCD TV Sound but no picture
My Kenmark Tv Switches its picture off if the PSU voltage drops. Audio is OK but picture does not return as PSU voltage goes back up. PSU's are about £10 online !2Volt 4A Might be worth a punt
May 04, 2009 | Zenith IQC50H95W 50" Rear Projection...
Laptop screen notworking
My laptop screen goes blank from time to time and these are the reasons it happens. If you boot the computer with the screen open while on battery sometimes the screen doesn't connect properly, but closing and re-opening the screen fixes this. Also, if your computer has a video out connection such as HDMI or S-Video look at the F5 key and see if it looks like it might mention switching screens at all. If it looks like it does, hold the fuction (FN) key and press F5, give it 10 or so seconds, if that doesn't work, try it again a few times, waiting each time. If none of this gets your screen back, it is a hardware issue not a settings or user issue.
Jan 14, 2009 | Zenith L13V36 13" Flat Panel LCD Monitor
Zenith 13in flat screen tv has no picture...
Welcome to FIXya
did you try to unplug it and plug it back in
or maybe goto the menu and try to redo the stations
make sure you have the tv pluged in to a power strip
hope this idea helps out if not please let me know have a good day:)
Jul 16, 2008 | Zenith L13V36 13" Flat Panel LCD Monitor
Zenith to
The key lock is a function that can only be reset with a remote. Go to www.zenith.com and under "support" you'll find product manuals. You can enter your model number and get the manual, but once "key lock" is on, you'll need a remote to change it.
Jul 08, 2008 | Zenith L13V36 13" Flat Panel LCD Monitor
Zenith CRT monitor- Z775CP
hay ..my zenith crt monitor does not show any photo with its true colour.. photos are somewhat black not the right brightnes is seen.
can u help me....
Jul 04, 2008 | Zenith L13V36 13" Flat Panel LCD Monitor
L13V36 Dark Screen, picture can be seen in bright light.
welcome to fixya
it sounds like the back light on both monitors are going bad
it might be better to call a repair man and get him to look at it see if it is going to be worth fixing i think it might be better then buying a new one at the prices now days
i hope this helps out have a nice day:)
Aug 08, 2006 | Zenith L13V36 13" Flat Panel LCD Monitor
Zenith L13V36 13" Flat Panel LCD Monitor Logo
137 people viewed this question
Top Zenith Computers & Internet Experts
Are you a Zenith Computer and Internet Expert? Answer questions, earn points and help others
