Question about Epson Stylus Photo R200 InkJet Printer
Epson r200 green flashin light
Whenever I turn on my epson r200 and it starts to prime or whatever, it stops a little bit through and refuses to move afterwards. It always stops in the same spot (on the far left side). The green power light then remains flashing slowly. After waiting awhile I press the power button again and the green light begins to flash faster. After this nothing will work. I can't use any of the other two buttons at all. I know this is a printer problem and not a problem with the wire because the priniter reacts in the same way when the USB cord is disconnected. I'm not sure if this will help, but whenever I try to retrieve ink levels from the printer via the control panel, the ink levels are blank. Thank you in advance.
  • Epson Master
  • 419 Answers
It sounds like the printhead may be "lost" due to a problem with the sensor on the back of the printhead becoming disconnected.
Check for a brown flat piece of plastic with a circuit printed on it that travels round the back of the printhead. It's likely this has become loose from the connector that it normally slots into.
If you push this carefully back into place you may find this fixes the issue.
I'd also recommend checking the thin transparent plastic strip with very thin black lines running vertically across it. If this is soiled or dirty it will cause problems as this is what the printer uses to orientate itself on the print track.
Hope that helps.
Posted on Feb 18, 2009
Stop the two red lights on my epson r200
Please try this procedure one more time using the instructions below.
  1. Turn the printer off, and disconnect the interface cable.
  2. Turn the printer back on.
  3. If the error lights disappear, turn the printer off and reconnect the interface cable. Turn the printer back on and try printing again.
  4. If the error lights continue, unplug the printer power cord for a few seconds and reconnect it to a different power outlet.
  5. If the printer is plugged into a power strip or surge protector, try plugging it directly into the outlet.
Note: Also check that the ink cartridges and lids are pushed down fully.
If the problem persists, an unknown printer error has occurred. The printer may require service.
Sep 24, 2014 | Epson Photo Office Equipment & Supplies
My epsom r200 has both red lights flashin when i turn it on how do i cure this prob?
Please check all of the printer doors are closed. If it is closed properly check the cartridge. If the ink is low please change the cartridge.
Aug 06, 2010 | Epson Stylus Photo R200 InkJet Printer
After changing the ink, the red light is still on.
epson stylus photo R200 printer the two red lights are flashing can get it to work help
Jul 18, 2010 | Epson Stylus Photo R200 InkJet Printer
Red warning lights remain on.....
Ink and paper light on : head carriage error/general error. Head can't move extremely to right : head carriage blocked or CR motor error. Turn of printer, unlock head carriage lock. Move head left and back to right (to parking position). Is it move freely?
Jun 16, 2009 | Epson Stylus Photo R200 InkJet Printer
MY EPSON STYLUS PHOTO R200 HAS THE RED A GREEN LIGHT FLASHING
WWW.EPSON.COM/SUPPORT AND DOWNLOADS, WHEN YOU FLIP OPEN THE COVER SEE IF THE UNDERSIDE HAS A INSTRUCTION APPLET ON CLEANING AND REPLACING INK CARTRIDGES, THOSE LIGHTS MEAN 2- THINGS RED-LIGHT, INK IS TOO LOW,NEEDS REPLACEMENT, RED WITH GREEN AFTER REPLACEMENT CLEAN HEADS, I HAVE SAME PRINTER , NOTHING MAJOR, USER GUIDE IS ON SITE ALSO IN PDF, FORMAT.... JON T
Dec 07, 2008 | Epson Stylus Photo R200 InkJet Printer
How to refill Epson Stylus Photo R200 cartridges
The continuous ink kit is on sale in Canada at "The Source" (former Radio Shack stores, now owned by Circuit City --- www dot thesourcecc dot com ). Search for R200. Also the photo Cyan and Magenta original epson cartridges are under $3 and the others under 10.
Jul 28, 2008 | Epson Stylus Photo R200 InkJet Printer
Two red lights blinking, power light off
you need to reset eeprom using the software
http://www.yoreparo.com/foros/download.php?id=2057
today i fix a epson r200 with that
Mar 28, 2008 | Epson Stylus Photo R200 InkJet Printer
Epson Stylus Photo R200 InkJet Printer Logo
61 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
