Question about Alpine CDA-9885 CD Player
My kenwood amp wont push my 10" rockford falsgate punch sun
I got it all intalled and it worked fine then a week or 2 later i turned my radio on and it didnt work. i have power to the amp and good channels. Everything is fine it just wont push it. But when i hook my two 6"s to the amp it pushs them untill i turn it up about a quater of a way then it will kick off untill u turn it back down. I evened tried changing subs, rewiring all the wires in and out of the box, and put it on another cheannel. It just cant push it anymore. Could it be a bad conection on the ground or pire wire? If not do you know exzactly what it is?
    New Friend:
  • 57 Answers
It sounds like a bad ground, I would go through all your connections
Posted on Jan 10, 2009
Kenwood kac-6295 shuts off then turns back on at high volumes
Did you wire the speakers in series or parallel? 4 ohm speakers in parallel actually come out to equal 2 ohms wich most amps would see as a short causing protection issues. 4 ohm speakers in series equals 8 ohms which should be fine for your amp. been there : expert-tech / SAM
Mar 27, 2012 | Car Audio & Video
I have a rockford fosgate punch P325.1 subwoofer mono amp that blows a fuse every time i start the car. I have a second pioneer amp but that works with no problems. How can i fix this?
Is it the correct size fuse ? Is it the power fuse or remote ? Either way check your connections going into the amp . Try this hook your other amp to the set of wires for the rockford if that amp has a problem its a wireing problem if not chances are its an interal problem on the rockford . Hope this helps !
Aug 19, 2010 | Rockford Fosgate Punch P325.1 Subwoofer...
Fried 3 amps. Is it my car? 93 mustang gt. I had my original amp Rockford Fosgate punch 500@2 for about 8 years then the whole system got stolen. Bought the same one on Ebay and it was fine for a few...
make sure you run your ground and power wires on one side of the car and the rca's on the other, keep them sepparate. if you have all wires running to your amp(rca's/12v power/remote), then you run the chance of either getting interference from the alternator, or if you have a pinched wire(usually by the door step) it may short with your battery wire. Double check your rca's and make sure they're ok and also check for corrosion on your wires.
Jul 05, 2010 | Rockford Fosgate Punch 500a2 Car Audio...
Rockford Fosgate Punch 500a amp wont turn on
check the internal fuses inside the amp its self these burn up real easy plus if it is them it will save you some money
Mar 31, 2010 | Rockford Fosgate Punch 500a2 Car Audio...
My amp only powers the subwoofer when the radio is on but wont when the cd player is on
The person(s) who hooked up your system made a boo boo. They wired your remote turn on lead to the power antenna lead instead of the amp turn on line (both are blue and easy to mix up). Thus when your radio is on it sends a signal to the amp and the amp turns on, but when you set to CD the signal goes away and your amp shuts down. Easy fix, just re-wire the amp turn on lead and the problem will be fixed.
Jun 24, 2008 | Rockford Fosgate P3001 Car Audio Amplifier
Rockford Punch 550.2 amp wont play
The amp is blown and need to be repaired.
You can contact Rockford direct to find a repair dealer.
Apr 16, 2008 | Rockford Fosgate Punch P550.2 2-Channel...
2 channels not working on 4 channel amp
Well firstly are you using a parametric crossover with your radio and how much rca cables do you have coming you head unit (car radio) if you going to bridge the front up with you rear speakers u wont be able 2 hear the rear speakers try hookinking it up 2 your head unit's front speaker output and have ur rca cable connected to your amp running on your rear output of your head unit by doing this you can use your fader on your head unit to control your front and rear speakers
Nov 07, 2007 | Rockford Fosgate Punch 300X Car Audio...
Rockford Fosgate 501bd question
that amp should work fine with those speakers,just make sure that they(speakers)are wired for 2 ohms.at 500-600watts coming from amp, you should be getting 250-300 watts per speaker,just dont crank your gain too high on the amp.
Aug 29, 2007 | Rockford Fosgate Power 501BD Car Audio...
No power
hi, some car amps need a high current remote supply to turn on. first make sure that you are using the proper gauge b+ and gnd cable for this particular rockford amp. then try switching the remtote turn on to this amp thru a simple Relay.(use the remote supply from your headunit as a trigger for the relay). do these connections without connecting any spks or rca line inputs. once amp is switching on then connect all other cables. OR lastly check the main fuse on the RF amp?? cheers
Jul 22, 2007 | Rockford Fosgate Punch P325.2 2-Channel...
Hooked my punch Punch P450.4 up to speakers and ran rca cables to front and it wont work
Hi Jon,  you need to hook the Remote wire up to the Radios  Blue remote wire.  The car battery power stays on all the time.  The blue Remote wire watches to see when the radio turns on, and signal the amp to turn on as well.
Dec 12, 2006 | Rockford Fosgate Punch P450.4 60W x 4 Car...
Alpine CDA-9885 CD Player Logo
67 people viewed this question
Top Alpine Car Audio & Video Experts
xxxxxx xxx
hoyzee1
Tygh Duval
Tygh Duval
Are you an Alpine Car Audio and Video Expert? Answer questions, earn points and help others
