Question about HP PSC 1510 All-In-One InkJet Printer
HP PSC 1510 All in One paper jams and wil not feed properly.
We have to feed paper one sheet at a time manually,it will not pick up a second sheet if it is left in the loading tray.We have tried new paper different brands as well as fannig the edges of the paper.
  • 88 Answers
Www.hp.com/support the people at HP have been very helpful to me try this and see what you get
biigg53566@gmail.com
Posted on Jan 07, 2009
Paper not picking up
There are feed rollers that pull the paper through. When they get a slick spot on them, they will not feed properly or not at all. This will be your first remedy, to replace them.
May 04, 2016 | HP PSC 1510 All-In-One InkJet Printer
A sheet of paper had remain in the cylinder
  1. Remove the rear cleanout from the printer.
  2. Gently remove any jammed paper or bits of paper.
  3. Close the HP Paper Feed Cleaning Kit software on the computer.
  4. Load plain paper in the printer paper tray.
  5. Press the Power button to turn the printer off.
  6. Press the Power button to turn the printer on.
  7. Try printing again. If the printer still does not pick up paper or if a paper jam occurs again, service the printer.
Other solutions customers found helpful » HP Paper Feed Cleaning Kit -- Clean the Paper Feed Rollers with the HP Paper Feed Cleaning Kit in Windows XP and 2000 » HP Deskjet, Photosmart, and PSC All-in-Ones -- 'Out of Paper' Error Message and the Printer Does Not Pick Up or Feed Paper » HP PSC 1600 and 2350 All-in-One Series Printers -- 'Paper jam: Press OK to continue' Message Displays on the All-in-One
Dec 15, 2010 | HP PSC 1610 All-In-One InkJet Printer
Paper jam indicator keeps coming on but nothing visable in machine, grabs a sheet and feeds it half way, and then error light comes on.
You might have a bit of paper stuck deep inside the printer. Read your printer's user guide manual. for how to remove paper that is jammed inside the printer. If you haven't got your printer's user guide manual, then just download a pdf version from your printer manufacturer's website.
Jul 04, 2009 | HP PSC 1510 All-In-One InkJet Printer
HP PSC 1510 keeps coming up with a misfeed
There may be a very small jam in the printer. Also, test with a different **** of paper. Put in one sheet to test.
Jun 11, 2009 | HP PSC 1510 All-In-One InkJet Printer
HP PSC 1510 ALL IN ONE
salut ROSENEDKER !
demonte entierement ton hp psc 1510 entierement et regarde du cote droit a la station de nettoyage;il ya une petite target qui doit etre cassee du cote haut ou bas . je dis bien cette target se trouve au bout du bloc des rouleau avance papier avec un ressort de rapel accrocher dessus . Merci et bonne chance
May 26, 2009 | HP PSC 1510 All-In-One InkJet Printer
Paper jammed cannot get paper out-
in hp if paper is jammed u just switch it off with the button over the printer not the main plug
the paper just comes out if tat doesnot work u just pull it out nothing wil happen
Mar 17, 2009 | HP PSC 1510 All-In-One InkJet Printer
HP PSC 1507 paper jam after changing cartridges
i have to intall my HP PSC 1510 All-in-One Printerand i lost the cd for do that what can i do ?
Sep 28, 2008 | HP PSC 1510 All-In-One InkJet Printer
HP paper jam
That is usually caused by the paper feed rollers being cover with paper dust. Take a clean cotton pad and alcohol and clean the rollers :turninig each roller as you clean it. if it has a rear dor, open it to get better access to the rollers.
Please remember to rate all users who assist you for free :)
Sep 03, 2008 | HP PSC 1610 All-in-One Printer, Scanner,...
Hp psc 1315 paper jam
. Switch off the printer and disconnect the power supply. Allow any residual charge inside the all-in-one printer to dissipate before putting your hands or any metal tools inside the chassis.
2.
Pin down the exact location of the jam. The 3 hot spots for a jam are before a sheet completely leaves the paper tray, anywhere between the feed tray and print carriage or between the print carriage and output tray.
3.
Take off the front paper tray if the sheet jammed while still in the front area of the printer. If here, you should be able to see most of the paper.
4.
Pull the sheet with both hands and steady pressure. Do not tug as you might rip the paper, leaving a piece deeper inside the machine.
5.
Open the back panel to reach paper jammed between the feed-tray area and print carriage. Carefully remove the jammed paper.
6.
Use the carriage access door to get at a jam further inside the printer. You may need to remove the print carriage to get to the jam.
7.
Replace all parts and return any access panels to their closed and locked positions. Plug your printer back in and flip the power switch.
Jun 18, 2008 | HP PSC 1315 All-In-One InkJet Printer
HP PSC 1510 All-In-One InkJet Printer Logo
194 people viewed this question
Ben Johnson
