Question about Hotpoint Aquarius WD63 Front Load Washer/Dryer
Door remains locke when cycle has finished
I cannot open the door i have tried turning the machine off at power point ( be it only for a few minuets) I have set it to "drain" only. I can hear the sound of it being "unlocked" but still it will not open any suggestions? I have an Electolux EW 1087 I purchased May 08.
Thank you
  • Anonymous Mar 05, 2009
    Exact same. Cycle finished, hear the door unlocking but the handle is unresponsive as if the catch is not connected to the handle.
    Problem Solver:
  • 5 Answers
Yea if it's still under warranty take it back. these new washers are a piece of #$%%#@
Posted on Jan 07, 2009
My Hotpoint wdl540 has finished its wash cycle but the lock light remains on and the door is locked. Tried all sorts to get it to unlock including running another cycle.
Firstly, to get the door open, if you unclip the bottom kick plate, you will find a small green tag hanging down on the right hand side. It is a door lock bypass. if you pull gently down on the tag about a centimetre, while it is pulled down, you will be able to open the door.
Turning to the problem its self, two issues can cause the door to remain locked. In order of which is more likely:
1) While it's ucommon, it's not unheard of that the 3 wire connector that clips to the bottom of the door swich inside the chassis develops a poor connection. Typically, this will cause one of the connectors to arc and burn the connection on the connector and if you're unlucky, the door lock mechanism as well. Remove the lid of the machine. Remove the door lock mechanism by unscrewing the 2 screws that can be accessed through the door aperture and lift the lock mechanism out to examine it (Note that the green tak is on a long strip that connects to this mechanism, so take care to lift this away in conjunction with the lock as you remove it. You may need to replace the connector and possibly the switch too.
2) Since power to the door lock runs through the motor circuit, if the motor brushes are heavily worn, the door lock won't disengage until they are replaced. This is absolutely counter-intuitive and it took me a few years of experience to figure out this little gem!
Sep 21, 2015 | Hotpoint Washing Machines
Door remains locked after wash, no error code or anything.
if there is water left in the machine it will not open pull out the washer if under work top tilt the machine back wards the door should open thwn clean filter and try
Dec 02, 2012 | Washing Machines
Door wont open
Most washing machines electromagnetically lock when on a cycle and remain so for a few minutes after it has finished. If you turn the electricity off/switch it off before it has unlocked, the door may not open.
Try turning the power on for a few minutes and see if it will release. If that doesn't work, put it on the shortest cycle, eg spin and wait for it to complete before you turn it off
or check their is no water in the drum, if their is check the drain pipe isn't creased.
If not pull out your machine if reqd , and check the pump is not blocked, more common than you think. Can be located at the front or back of your machine.
If none of these turn off your socket for 10 mins.
Apr 30, 2011 | Washing Machines
I have a front loader Samsung washing machine. JI045AV. The cycle has finished and the door will not open. Have tryed putting it through another cycle, turning power on/off and trying different settings,...
Your door interlock has failed & needs to be replaced.Usually the computer should come up with error code DE error,& if your machine's main p.c.b/computer may have been taken out also,If this is the case it will need to be rewired to fix the problem,hopefully it is just the door lock if not it may cost up to $500 dollars to repair.GOOD LUCK.
ECO KIZZA.
Feb 24, 2011 | Samsung Washing Machines
My Electrolux ewf1090 front loader door wont open
Turn the power off and leave for 5-10 minutes then turn on. This should release the door lock the problem could be the pump drain filter is blocked clean this and it should resolve future problems.
Apr 25, 2010 | Electrolux Washing Machines
Bosch axxis door won't open
michele99, So when you put it on drain, do you here the machine trying to drain the water? After it finishes draining, (you have to wait a few minutes, it should then have a blinking light
on the Finished/Door locked light.
Are you waiting for it to finish?
May 08, 2008 | Bosch Axxis WFL 2060 Front Load Washer
Control lock is on but door opens it finished the cycle but the control lock wont shut off can you help thanks
Try some WD40 spray on the door
lock; on machine, not on door. And open & close for a few times with the power off.
Apr 13, 2008 | Whirlpool GHW9150 Front Load Washer
Door Locked and wont open
Mine is crazy too! Sometimes, if I open the soap dispenser it will open, othertimes not. Sometimes, if I pull up on the big, round knob (that you use to turn on the cycle), because it gets stuck down. Once in awhile, I just put it on the last 2 minutes of spin cycle again.
Nov 16, 2007 | Frigidaire GLTR1670A Front Load Washer
Hotpoint Aquarius WD63 Front Load Washer/Dryer Logo
83 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Todd Arndt
Todd Arndt
puggy666
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
