Question about Optoma EP759 - HDTV Compatible DLP Projector with 3,200 Lumens Multimedia Projector
Optoma ep795 projector won't power up after lamp replacement
  • Anonymous Apr 23, 2009
    I have the same problem with my HD640. I spoke with Optoma Canada and they said there's probably a manual reset that needs to be performed. I asked them for instructions on how to do it because I'd rather not send it in if it's something I can do. I haven't heard back from them yet (it's only been a day).
    Does anyone know how to do this?
  • Anonymous May 24, 2009
    After the lamp burn out, it still has the power. Then, I removed the burnout lamp from the case so that I can see what looks like with a burnout lamp. Then, I put it back but never got power on again.
Is the bulb cover seated correctly? It disables the power if it isn't.
Posted on Nov 26, 2012
  • 82 Answers
Did you replace the lamp because of this issue? if so, the ballast may be bad on this unit
Posted on Jul 26, 2009
Optoma EP781
if all lamp are red, and no light on, It is power supply issue,
you need to replace power supply, it will be ok.
you can send me your old power supply photos, perhaps i have same parts,
Jul 06, 2014 | Optoma H30 Multimedia Projector
Optoma HD66 replaced lamp, LAMP WARNING light keeps flashing, still won't turn on?
i just had the same problem i took the top of the projector off and cleaned the color wheel and sensor seemed to have fixed the problem that is for now. seems to happen to me once a year on the dot but last time it was warranty. good luck hope it helps.
Mar 17, 2012 | Optoma Office Equipment & Supplies
I went to replace the bulb and when I plug it back in there is no power, no power light or anything. DS303
this is a common problem with optoma projector, if you replace the lamp yourself, it won't start!! let's sue them
Jul 16, 2011 | Optoma DS303 DLP Projector
I have an Optoma DS303 projector. It stopped working. We replaced the lamp and it worked for about 3 hours and then when we tried to turn it on again, it won't fire up. Sometimes if I hold down the...
Check the voltage at the lamp input from the ballast after connecting projector to mains supply. (Warning: Do not switch on the projector while checking the voltage. It will damage your multimeter) The lamp connection shall be removed. If the voltage is around 60 to 80 volts AC, then your ballast is OK. Check for fragments inside the lamp.
sonsunny
Jun 14, 2011 | Optoma DS303 DLP Projector
Where do i find the ballast unit, both inside my projector and for sale?
In the optoma hd-81 there is a lamp unit housing.It goes faulty the lamp unit housing .There is no ballast in the hd-81 projector.There is lens ,the lamp unit housing and the circuit board.In most of the cases the lamp unit housing goes faulty.In that case the lamp housing needs to be replaced.It can be replaced and replacement lamp is also available. -------------------- Buying original lamp is always advisable.But there is compatible lamp also available.The original lamp housing is costly and compatible housing is bit cheaper.In some rare cases the compatible lamp does not work.But the compatible lamps also are good. To buy original lamp.Click this link directly:--- http://www.partstore.com/Part/Optoma+Technology+Inc/Optoma/HD81/Optoma+Technology+Inc/Optoma/BLFS300B/New.aspx ------------ this is link for compatible cheaper lamp.Click this link:-- http://www.partstore.com/Part/Optoma+Technology+Inc/Optoma/HD81/DNGO/DNGO/BLFS300BRL/New.aspx --------------- The procedure to replace the lamp:--- to get this procedure.Please click on the link below:--- http://www.partstore.com/Part/Optoma+Technology+Inc/Optoma/HD81/DNGO/DNGO/BLFS300BRL/New.aspx ------------ this link is for the user manual of optoma hd-81 and the procedure to replace lamp is mentioned on page number 59.Please read the instructions before replacing lamp.----------- This will help.Thanks.Helpmech.
Feb 03, 2011 | Optoma HD81 DLP Projector
My Optoma HD72 projector operates for about 1 minute and then shuts off. I kept my old bulb around "just in case", I've replaced the bulb with the old one and have the same problem.
The problem is not over-heating. The Optoma HD72 has a known problem that Optoma won't advertise. The lamp driver is faulty. They simply have to replace the lamp driver. I purchased a spare lamp with my original purchase. I had the exact same experience as you at around 1200 hours on the lamp in ECO mode. I used the spare lamp. Same thing happened at about 1200 hours. I had a friend at Optoma. he confided to me the problem. I sent it in and they replaced the lamp driver at no charge. I got another 800 hours out of the first lamp and am now using my second lamp and have about 600 hours on it. The pic quality is so good with this projector (used Digital Video Essentials to calibrate) that I'll just order a bare lamp or two and use the existing lamp housings when I need a new bulb.
Apr 12, 2010 | Optoma H30 Multimedia Projector
How do I remove the lamp on a optoma ep716?
Lamp Replacing Procedure:
  1. Switch off the power to the projector by pressing the Power/ Standby button.
  2. Allow the projector to cool down at least 30 minutes.
  3. Disconnect the power cord.
  4. Use a screwdriver to remove the screw from the cover.
  5. Push up and remove the cover.
  6. Remove the 2 screws from the lamp module.
  7. Pull out the lamp module.
  8. Replace the lamp module in reverse the previous steps.
Nov 11, 2009 | Optoma EP716 Multimedia Projector
Optoma EP755 new lamp when power standby button
you need to reset the lamp timer, usually done by holding some buttons while turning on
Mar 10, 2009 | Optoma EP750 Multimedia Projector
Projector has no power
close lamp compartement door firmly because door switch can disconnect power from projector if not closed firmly.
Aug 27, 2008 | Optoma EzPro 739 Multimedia Projector
Optoma EP759 - HDTV Compatible DLP Projector with 3,200 Lumens Multimedia Projector Logo
320 people viewed this question
Top Optoma Office Equipment & Supplies Experts
jasbo
jasbo
color wheel light...
Are you an Optoma Office Equipment and Supply Expert? Answer questions, earn points and help others
