Question about RCA D52W20 52" Rear Projection HDTV-Ready Television
Tv has problems cuting on
It is a RCA d52W20 52 inch projection screen tv. when turning on green light on the front panel lights up for few seconds and goes back off it does this 3 times then you have to wait a while before trying it again it takes several times before the tv will cut on.
  • 1 more comment
  • smitsca Jan 09, 2009
    I have the same problem. The green light comes on for about 5 seconds, then goes off for the same amount of time. It does it 3 times then you have to wait for a while to try again. What I do know is just leave the T.V. on and put it on a different input selection so that the screen goes black, but it doesnt turn the T.V. off.
  • davis5113 Jan 16, 2009
    i went ahead and changed out the capacitors cp150, cp114 and cp120. i have turned it on and off several times and seems to be working ok. i will keep optimistic and thanks for the help.
  • Joesipaq May 11, 2010
    I just answered this on another post, so I will copy and paste here because i believe the same solution will suffice :)
    Problem Solver:
  • 8 Answers
I had this problem with mine. And it is caused because it is a safety shutdown-
The Safety shutdown may be broken into five distinct sections:
• Audio Power Supply and Audio Output Monitoring
• Main Run Power Supply Loss (PS LOSS)
• Rear Projection Instrument Safety (CRT Scan Loss protection)
• Startup Delay
• Power Supply Overvoltage
When taking measurement I used Pin2 of IP250, It is located in G-0 on the Voltage regulator board.
First off, check the main safety transistor, TP210 located at G-2 on the power supply/scan Bord. It will have 3 semi large heat sinks and the main tube power cables coming off of it.
The Emitter should always be 5Vs, The emitter is also the Furthers pin form the heat sink it is right by, So if looking at it face on to the flat side of the transistor the emitter is on the right.
The base when in:
normal high
protect low
off low
The collector goes to the power switch and should be
normal low
protect high
I pulled mine out to check to see if it was bad because it was reading odd like a shored EC, and it checked out fine. After re-soldering it back in, my set worked fine! Over my TV's life it seemed to have produced a weak point in its solder joint I guess. That in your case seems like it is about to go out for good.
I would say just re-solder that and you should be good to go!!
It this does not work for you let me know, I have much more information.
Regards
Joe
Posted on Jan 10, 2009
I have a 60" RCA D56W02B rear projection TV. I've
Yes,the power supply board,where the actual power a/c cord plug into it,are most of the causes of power LED light blinking problems.
Feb 17, 2011 | RCA D52W20 52" Rear Projection HDTV-Ready...
Rca model# d52w135d screen won't turn on
Are you saying that the screen goes black after the DVD player stops working?
Jan 10, 2008 | RCA D52W135D 52 in. TV/DVD Combo
I have an 52 inch RCA in projection T.V. and one day it quit turning on. If you use either the remote or button on the front of set the green light turns on for a second then goes off. I you try to turn...
CP150, CP120 and CP114 capacitors will usually cause that symptom. The RCA repair kit by that same name is available at www.tvrepairworld.com the kit contains the capacitors and the CD with instructions
Oct 09, 2010 | Televison & Video
52 inch rca big screen tv will not come on
ck capacitor cp150 if it is bad replace 2 other caps in same circuit 2200uf 16v -220uf35v cp111 cp114?
Dec 09, 2008 | RCA D52W19 52" Rear Projection Television
RCA HD 44"
replaced bulb green light continues to blink screen fails to light
Jul 27, 2008 | LG RU-44SZ51D 44" Rear Projection...
52 inch RCA - green light turns on & off, BUT no picture
CP150 is a capacitor in the power supply circuit....feel top to
see if flat....change if "pooched" or swollen..................T.
Apr 15, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
TV Picture Goes Black
I had the same exact problem.
I removed the bulb and cleaned it. There is a small screen at the top of the bulb and it was covered with dust. Once it was cleaned I replaced the bulb and it solved the problem.
Thanks to those who posted the solutions
Jul 28, 2007 | Sony Grand WEGA KDF-60WF655 60" Rear...
RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
119 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
