-   I have a B200 machine. Mine stopped working, I drained it, refilled to prime, after priming is says" priming heating please wait". It never changes at this point. If I drain the machine the water is hot, so I know it is heating, also when the machine has been drained and the request for water to be added to prime, the pump turns on but instead of taking H20 to the tank it comes directly out of the dispenser instead, leaving same message, "priming heating, please wait".
I descaled the brewer and am still having problems- when the brewer says ready to brew and I hit...
(More)
I descaled the brewer and am still having problems- when the brewer says ready to brew and I hit brew the amount of water that comes through is not the same amount as should come through. THere is also water that drips through the line in the reservoir at the same time. What should I do?
the water doesn't come out through the needle- it seems clogged or disconnected and the water comes...
(More)
the water doesn't come out through the needle- it seems clogged or disconnected and the water comes out over the edges of the needle & coffee grounds housing
