Question about HP Pavilion dv1000 Notebook
No power HP laptop
I have this Hp pavilion dv1000 laptop, one time I tried to open it but it didnt open.I looked on its power indicator led but there is no light or indication that there is power tried to just plug it thinking that the battery is the problem but still it wont work no lights on the indicator led aswell showing that it is plugged. I cant open it anymore it is as if its a dead unit.Thanks!
  • Yannie Pascual Jan 07, 2009
    Jaddude,
    I really feel sorry because the last time I used it it is working very well.Thanks for the advice.
    bdouglas,
    Thanks for the advice aswell, I will also try to have it fixed in a service center here in the Philippines. I am still not loosing hope.
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 144 Answers
This is not very good because based on my experience i would assume its a dead motherboard which costs more than the system to replace. I recomend that you sell it as a dead motherboard computer and get 200 dollars out of it. Sell it on ebay but dont fix it it will be too expensive, upgrade to a new one. if your data is on the hard disk then see if a newer computer can support thats hard disk and continue with the data.
Sorry for the loss
Jaddude A helper of FixYa
Posted on Jan 07, 2009
    Sergeant:
  • 290 Answers
Sounds like the unit's power supply may have failed you will probably need to take it to a repair center.
How do i fix my LCD?
I have got a hp pavilion dv5000, when I turn on it the screen goes blank.
Power led glows, I hear for a few time the fan, disk led flashes intermittently and also I feel that the DVD player tries to load.
If I try to click on caps lock or num lock, leds don't respond to commands. I tried the hard reset pressing the power button for 30 seconds with the battery and the power removed. Nothing to be done by connecting an external monitor....
Thank you
Jun 11, 2013 | HP Pavilion dv1000 Notebook
How to connect my HP Pavilion dv1000 PC Notebook to led tv please help me
Doesn't you have a manual to do it,it is just a simple problem if we have a picture instruction,you only need to connect with them rightly,and make a correct setting in HP pavilion dv1000.
Feb 17, 2011 | HP Pavilion dv1000 Notebook
Hp dv1000 screen does not show anything
there is a common problem with these laptops the motherboard faults if the power led lights up but nothing else then that the problem
May 28, 2010 | HP Pavilion dv1000 Notebook
Is this hp pavilion dv1000 battery a cheap one?
From the link you gave its seen that its comparatively lower than the other series.. Brand: HP Laptop BatteryBattery Info:
Li-ion, 4400 mAh, 11.10V, Black, 310.00(g), 205.15 x 59.20 x 37.50 mm
Rating: rate4.gif
Capacity Voltage Price($) 4400 mAh 11.10V C $ 57.79
8800 mAh 11.10V C $ 79.69
Availability: In stock
Notes for charging Hp Pavilion dv1000 Series battery :
  1. You must fully drain the Hp Pavilion dv1000 Series battery until the laptop goes into hibernation for your first use it.
  2. Store it in a cool and dry area. Do not expose battery to water or other moist/ wet substances.
  3. Do not forget to take away your Hp pavilion dv1000 battery from the laptop if you will not use it for a long time.
  4. Know that after that plug in your charger and allow it charge for 12 hours or depending on what the technician has told you. 12 hours is the max and you can use it while charging .
  5. Charge new Hp Pavilion dv1000 Series battery for three times at first. After that it will take less than 2 hours to fully charge your Hp Pavilion dv1000 Series battery.
  6. It is normal for HP laptop battery to become warm during charging and discharging.
  7. Learn that this is recommended so that the Hp Pavilion dv1000 Series will heat up for the time allowing ions to reawaken.
Jan 20, 2010 | HP Pavilion ZV5000, ZV6000, ZX5000 Series...
I have a hp pavilion dv1000 laptop and it randomly hibernates
Go to the control panel > Power Options, click on the hibernation tab and uncheck it. Click on apply and ok. Hibernation can damage older HP systems such as the DV1000 that is running XP, make sure it is turned off and also go through the power settings and change the setting for closing the lid on the laptop. Change the setting to "Do Nothing". This will keep your system from getting corrupt.
Nov 26, 2009 | HP Pavilion dv1000 Notebook
My hp pavilion turs on and the led lights stay light but the computer won't boot up
look remove every drive connected to you computer and then remove the battery and connect the computer on the charger only and try to open the computer
Nov 08, 2009 | HP Pavilion dv1000 Notebook
Screen dim HP pavilion dv1000
The lid actuator switch may not be working correctly. It's a small switch above the keyboard and led's on either the right or left side. Try pressing it 2 or 3 times to see if the display starts working correctly again. If so, it will need to be replaced.
If that doesn't work, you can also turn it on with the ac adapter plugged in. After it boots, press the power button and hold it in until it shuts off and then turn it on again and see if the display has returned to normal.
If neither of these options work, your laptop may need to have the backlight replaced.
Aug 13, 2009 | HP Pavilion dv1000 Notebook
No power
All lights come on HP Pavilion dv1000 but will not boot. looked at motherboard and by power connector there is a blown part the number on the board shows PD27. I need to know what thhe part is or a schematic showing
Jun 23, 2008 | HP Pavilion dv1000 Notebook
All 3 usb ports not working
You didnt get a Flat cable hooked correct and recheck the Secondary board that has the Interface block..(To the systemboard)..
Good luck..
www.ikenfixit.com
Feb 14, 2008 | HP Pavilion dv1000 Notebook
Power LED flashes three times-no boot
Try this. Power down. Remove the battery. Remove the memory. Replace the memory. Replace the battery.
Try to power back up.
Best of luck...
R-
Nov 05, 2007 | HP Pavilion dv1000 Notebook
HP Pavilion dv1000 Notebook Logo
139 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
