Question about Electrical Supplies
Hunter fan model 23272 with remote control
My fan and light comes on and off on its own
  • 37 Answers
Sometimes fan remotes can get interference from several rf sources (maybe another fan remote or garage door opener, etc). You can try to change the DIP switches in the remote and the reciever to a different frequency. The switches in the remote are probably in the battery compartment, and on the reciever which is located in the ceiling canopy (most likely), or in the round box where the light kit attaches.
Posted on Jan 23, 2009
I need a light kit for hunter fan model #23530
  1. Hunter Fan - Accessories
    www.hunterfan.com/Accessories
    Need more control? We have many universal remotes and wall control options for yourfan and light ... Customize your lighting. Add a new light kit or change the lighting hardware on your fan. Complete light kits. Need lighting parts? Glass and ...‎Complete Light Fixtures - ‎Controls - ‎Glass/shades
Jul 09, 2015 | Hunter 52" Ceiling Fan With Light And...
Why does our remote receiver, model #85482-01, keep resetting itself?
That's a tough one; this could be coming from a malfunctioning transmitting or receiving unit, or outside interference.
Did the handheld remote get dropped just before this problem started? Or maybe have something spilled on it? One way of ruling out spurious emissions coming from the transmitter is, once the fan is operating, remove the batteries from the remote. If it still changes modes it would NOT be the remote. Proceed to the next step.
Have you had electrical storms or power outages around the time that the problem started? If so the receiver may have taken an electrical hit. Inspect it carefully for signs of arcing or smoke, fried wires. Also sniff it, if it has a funny (burnt) smell that's where the problem is. Of course the receiver could malfunction without and power surges and that would be harder to isolate.
Lastly, outside interference; This is very hard to determine without any test equipment. If someone living near you installed a garage door opener, Set-up an amateur radio station, or started using some piece of new electronics you might be interfered with you. I have seen electric lawnmowers do some strange things (interference). I was also was once on a call where the guy next door actually went out and bought a programmable remote control to mess with my clients TV, some kind of neighborhood squabble.
Hope this helps, best of luck to you.
May 17, 2014 | Hunter Dryers
Problem with hunter ceiling fan 23272
The problem is with the remote receiver attached to the fan body. It is a small device that acts as a remote switch and this is cradled in a pocket inside the ceiling fan itself. If you are handy, you can replace this device yourself. I believe you need to purchase a new kit from Lowes that comes with a matched transmitter and receiver for fan control. Go to Lowes Lighting section for this product.
Jan 12, 2018 | Hunter Dryers
I NEED TO REPLACE THE CONTROL AND THE HUNTER TELPHONE NUMBER LEAVES ME ON HOLD FOR OVER AN HOUR WITH ANNOYING RECORDINGS!! HELP!!!!!!!!!!!!
i have a hunter ceiling not sure model but i have the model number 23530-300 with a remote ,the remote light comes on when you press any button but the fan does nothing any help good voltage
Jun 28, 2011 | Hunter Ceiling Fan Remote Transmitter...
I installed a Hunter On"Off fan and light control model 27157 on a Hunter Augusta fan model 21338. I tested the remote control and the fan and light on, however, after a period of time, the fan turns on...
Most likely this is caused by radio interference from some other device nearby. Try changing the "channel" by changing the dip switches on both devices and make sure they match. :)
Mar 27, 2010 | Hunter 27185 Remote Control
Light won't work on hunter fan with wireless remote
probably your lights are blown replace them.good luck.
Feb 28, 2010 | Hunter 27187 Remote Control
Can't control light at switch
It is wired so that you control the light with the remote. You cannot have it both ways. You either control it with the wall switch or the remote. Once you kill the power to the receiver by turning off power at the wall switch, you are only applying power to the receiver when you turn power back on. You are not supplying power to the light. You then must turn on the light with the remote. This is the purpose of a remote fan/light control. You could rewire it to control the light with the switch and only control the fan with the remote if you wish, but as you have it now, it is working correctly.
Jul 01, 2009 | Hunter 27185 Remote Control
Hunter fan/light with remote installed turns on by itself
Many times this is caused by stray frequencies in the neighborhood. And, sometimes changing the frequencies on the remote and receiver reduce the occurrence.
But it sounds like this may not be the case, here. If not, the receiver in the fan is the culprit and should be replaced. No danger, just annoying.
Apr 01, 2009 | Hunter 52" Ceiling Fan With Light And...
Electrical Supplies Logo
563 people viewed this question
Top Electrical Supplies Experts
Craig Butler
Craig Butler
Steve
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
