Question about Toshiba Satellite 1410-S173 Notebook
Toshiba sat 1410 power charging
Hi call it coincedence or not formatted h/d to do new op,since then the power will not charge battery or power the machine.Battery and power supply fine me baffled can anyone help me to get it on ,P.S.i checked power inlet plug it fine too
  • mrchunkie Jan 31, 2008
    i recently removed hard drive & reinstalled it to my toshiba satellite 1410 but lights come on but no sound is heard from spinning hard drive or fan
    screen stays black, no windows music or anything
    i really need help knowin where to go next
    earlier it was sayin the modem was not installed for dialup
  • Anonymous Jul 28, 2008
    same problem will run on ac power but will not power up on battery alone have two good batteries from identical pc's new power supply pull ac adapter and pc immediately goes black battery show 100% charge on battery will not run on battery alone-- starts and run on ac adapter
    Genius:
  • 2,985 Answers
Categorises exactly what is/not happening. Appreciate that you have reformatted the system. So what is the situation now.? Operating system in or not in? Switch on --screen lights up to POST yes /no Machine dead or alive- ie when switched on do fans/drives run ?[listen out for them] How do you know battery is OK or power supply to computer is good?
Posted on May 29, 2007
My garmin 1410 sat navi won't switch on
Most likely, your USB port is loose. This is a common problem with this model. The port needs resoldered and reinforced. When the port is loose, you will not be able to send power to the GPS and charge the battery. Please see this link for more info:
SHARCNET USA Out of Warranty GPS Digital Camera Repair
Jan 28, 2014 | Garmin Nuvi 1410 Car GPS Receiver
Tip
Taking Care Of Your Laptop Battery
  1. Normally, a new battery pack comes in a very low charge condition and must be fully charged before use. Refer to the user manual of your portable electronic equipment for charging instructions.
  2. A new Dell Vostro A860 Battery needs to be fully charged and fully discharged or “cycled” as much as five times to condition them into performing at full capacity.
  3. Your equipment may report a fully charge condition in as short as 10 to 15 minutes when the new Dell Vostro 1015 Battery is being charged for the first time. This is a normal phenomenon especially for Nickel Cadmium (Ni-Cad) and Nickel Metal Hydride (Ni-MH) chemistries. When this happens, remove the dell vostro 1015 battery pack and let it cool down for about fifteen minutes then repeat the charging procedure.
  4. “Conditioning” (fully discharging and then fully charging) is necessary so as to maintain the optimum performance of a sony vgp-bps8 battery, and is recommended at least once a month particularly for Ni-Cad and Ni-MH batteries. Failure to do so could result in reduced charge capacity and can significantly shorten the sony vaio vgn-fz battery pack’s useful life. Lithium Ion batteries do not require conditioning.
  5. It is normal for a acer aspire 1410 battery pack to get warm when charging and during use. However, if the acer aspire 1410 battery pack gets excessive hot, there may be a problem with the portable electronic equipment’s charging circuit and should therefore be checked by a qualified technician.
  6. Rechargeable batteries undergo self-discharging when left unused for long periods of time. This is normal particularly in the case of Ni-MH and Li-Ion chemistries. For best results, always store a battery pack fully charged. It should be removed from the equipment and kept in a cool, dry and clean place.
  7. The amount of runtime a hp 510 battery produces depends on the power requirements of components in your electronic equipment. This could be the hard drive setting, screen intensity and back-lighting on notebook computers, the liquid crystal display (LCD) screen and floodlight feature in a video camcorder, or the tri-mode communications network of a cellular phone. Always refer to your equipment’s user manual for power management settings.
on May 31, 2010 | Computers & Internet
No charge on tom tom 1 sat nav. if i wiggle it it will charge but i cannot hold it all day
the battery is wekend you need to change it try buyng a new battery anf format it to hold more
Feb 24, 2011 | Sony Televison & Video
Battery on met400 seems dead wont charge
Hello :
It seems that your battery is dead [ Lifetime ended] . What you need , is to replace it .
Just replace the battery with a new one ] and problem will be solved .
don't forget to rate if that was useful please !
good luck .
Feb 08, 2010 | Toshiba Gigabeat MET400 Digital Media...
Acer 1410 can't turn on with cord plugged in
The battery isn't charging, from what you describe. Sounds like a bent pin, or a bad charging circuit. Waranty should cover, unless it was dropped or 'abused,' assuming that it was a new present. Take a quick look at the battery connection.
Jan 08, 2010 | Acer Aspire 1410-8414 Netbook
Toshiba 1410-S173 battery charging light blinks amber
did you buy the battery brand new or used?
brand new, deffectibe motherboard, bad charger or bad dc socket.
used, change it.
Mar 03, 2009 | Toshiba Satellite 1415-S173 Notebook
I have a toshiba laptop computer satellite a215-s4807. I cannot get it to power on. The battery went completely dead and I plugged it in to charge. But it will not power on with it plugged into the...
certain laptops rely on a battery being present.
Or a battery that holds charge.
i,d suggest refering to the user manual, or go on-line to the manufacturers website.
the laptop may be in hibernation/sleep mode. or require a hard reset.
visit toshibas support site for further details and faqs ( frequently asked questions )
Mike @ compurepair.
Dec 18, 2008 | Toshiba Satellite A100-S8111TD Notebook
Tomtom300 gps mains charging +
1= My battery is flat, but when i put it on charge in the house it doesnt charge and no green light comes on, on my sat nav why would this be?
Could be your house charger is bad or the power connector on the back of the Tomtom is bad.
2= But when i put it in car charge it works perfect 'Y'?
You are using the "power shoe" to charge the battery. For a test unplug the power cord from the power shoe and hook it to the back of the Tomtom. If this work then the house charger is bad. If this doesn't work then the Tomtom rear power connector is bad
3= If ever i have to change battery how is this done?
You will have to remove the faceplate and disassemble the Tomtom in order to get to the battery. Or you can find a shop that repairs small electronic. Find the battery on Ebay.
Jan 12, 2008 | Tomtom GO 300 GPS Receiver
Toshiba Satellite 1410-S173 Notebook Logo
93 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
