Question about Jet Tech Systems STEALTH Dishwasher
Is running the dishwasher through a normal cycle with 1/2 cup of white vinager a good why to clean your dishwasher?
  • 8,197 Answers
That is fine. The vinegar will not hurt it. You will smell the vinegar though. I do it every other month.
Good Luck and Please rate FixYa!
Posted on Jan 07, 2009
Leaving particles all over dishes
The dishwasher may need to be cleaned. Place one cup of white vinager in the dishwasher, without any dishes, and let the dishwasher go through a wash cycle.
Apr 23, 2014 | Westinghouse Dishwashers
How do I rid our lg dishwasher of foul odors?
if every thing else is working good, try first to clean the screen in the bottom and run a cleaning agent through it with nothing in it.
you can find the cleaning agent with the dish washer/laundry soap area in your store (same one used on front loading washers)
or run 1 cup of white vinager through it
Oct 08, 2012 | LG 24 in. LDS 5811ST Stainless Steel...
How do I get rid of mold in the front rubber part?
There are many things that will get rid of it, the most effective is a diluted bleach and a green scouring pad.
Jun 07, 2011 | Maytag Neptune MAH5500B Front Load Washer
I have a 5 year bosch shu43c05uc & my dishes aren't clean any more? i've cleaned the bottom lint container & it still isn''t clean? does my dishwasher need repair?
You should be able to get several more years out of it with a good maintenance call or a Do It Yourself routine on checking your water inlet valve. spray arms, internal filters.
Mar 08, 2011 | Bosch 24 in. SHU43 Built-in Dishwasher
I have a GE Quiet Power 2, Model: GLD5560L00SS that suddenly is leaving all dishes and glasses dirty with dry scum stains. Is there a filter that needs to be changed?
Its not a filter that needs to be cleaned, the scum is a result of dishwasher detergent. You need to run a dishwasher cleaner through it. First fill a cup with white vinager and place it on the upper rack, then run a cycle with no other dishs in the unit. The vinager will be displaced through out the cycle and help to get the scum to go away. I had to do this 4 times to get the scum to go away. You can also use "Dishwasher Magic" and that can be found at most hardware stores.
Jan 07, 2011 | GE 25 in. GSC3200GWW Free-standing...
It smells. How do you clean it?
on the bottom of the tub you will see a round trap, twist it out, you can then clean the filter out and remove the metal filter plate and clean that, after that put it back together an run it empty set to a hot wash and put a coffee cup full of white vinager on the top rack and run it thru a cycle, this will clean it, you might need to do it 2-3 times to get the funk out, good luck
Jun 07, 2010 | Bosch 24 in. SHU66C05 Stainless Steel...
How do you run cleaning cycle
dont bother its a bs cycle
the best way to clean your machine is a cold cycle with 1 cup white vinager
Oct 04, 2009 | Washing Machines
Our glasses are really cloudy. How do we clean the inside of the dishwasher?
This may be a hard water issue, but assuming it's not:
Pour 1 liter of white vinager into your dishwasher and run through a full cycle.
If this fails:
Pout 1/2 liter of CLR into you dishwasher and run through 3 full cycles.
N.B. Vinager is preffered as it's non-toxic.
Other possible issues:
hard water, lime/sediment buildup in hot water tank, not using rinse-aids like "jet-dry"
Sep 08, 2009 | Maytag Dishwashers
Our 2 year old dishwasher won't clean as well as it did when new
If the filter has already been cleaned, try adding a cup of bleach to your next cycle.
Jul 30, 2009 | Dishwashers
The Dishwasher is not cleaning the dishes
run a empty load, on the top rack place a coffee cup full of vinager. Run on hot or heavy duty cycle. Then try again with no more than 1/2 of the soap cup filled. If this works for you it was caused by to much soap
Jul 07, 2009 | GE Dishwashers
Jet Tech Systems STEALTH Dishwasher Logo
64 people viewed this question
Top Jet Dishwashers Experts
Are you a Jet Dishwasher Expert? Answer questions, earn points and help others
